Question about Sterling Forge SFP40PT Gas Patio Heater
Where to order parts?
Where can I order a new thermocoupler for a Sterling Forge SFP40BR Patio Heater?
  • 8 Answers
SOURCE: Sterling Gas Heater
It sounds like you have a short somewhere. Possibly just a pinched wire? Scroll to the bottom of this page and download the installation / troubleshooting guide for more information.
http://store.h-mac.com/sttudegasorp.html
Posted on May 22, 2008
SOURCE: Where can I order parts
Langendorf Supply Company
Posted on Nov 16, 2010
  • 4736 Answers
SOURCE: YESTERDAY I BOUGHT A THERMOCOUPLER FOR MY QVF 45
Loosen the thermocouple nut where it goes in the control valve. Re-tighten it only finger tight and with the appropriate wrench, turn it ONLY a 1/4 turn more.
If you have it to tight, it will not heat up and open the gas valve. Make sure not to cross thread it.
FYI: Gas control valves on this type of heater rarely go bad. Unless, the control knob is forced in an inappropriate way.
Posted on Jan 21, 2011
Therinnaiguy
  • 1420 Answers
SOURCE: I have a Sterling heater
ACE hardware, Tractor Supply, H Depot or Lowez should have what you need. Bring the old one with you. You may have to purchase one a bit longer, just keep the extra coiled up out of the way.
Posted on Mar 02, 2011
  • 4736 Answers
SOURCE: I have a sterling forge
Doug - Patio heater parts are pretty universal from one manufacturer to another. Especially so, for the parts you need. AZ Patio Heaters carries a large selection of universal fit parts, as well OEM parts.
Here's a link to their website http://azpatioheaters.com/home.php?cat=2&gclid=CLOGyd-DnKgCFQl_5Qod_29hHg
Hope this helps you find what you need.
Posted on Apr 14, 2011
I have a sterling forge propane patio heater and the burner screen is rusted out. The screen is 10 3/4 inches in diameter and I don't find any that size. Also the dome is 36" with a center hole for...
Apr 14, 2011 | Sterling Forge SFP40PT Gas Patio Heater
I have an endless summer patio heater the pilot lights but the does not stay on when you turn the knob to start the heater. Got it on once but then the flame blew out and could not start again
You need to replace the Thermocouple. Endless Summer Patio Heaters are manufactured by Uniflame, which is owned by Blue Rhino. You can order the Thermocouple direct ly from either company. Just make sure you have your Model Number handy.
Mar 06, 2011 | Endless Summer 2009 Open Flame Patio...
My heater lights but then does not stay lit (goes out after about 30 seconds). Any suggestions??
Sounds like the thermocouple is failed or really dirty with soote. When the flame lights and the thermocouple is in touch with the flame...it will create a minute amount of electricity which is sensed by the controler of the system. If it does not sense the flame then it will time out and shut off the gas supply regulator valve and pilot tube!
Oct 07, 2010 | Berkeley Forge G-PH001PSS Open Flame Patio...
Pilot assembly parts or thermocouples
Hardware store thermocouples don't work on patio heaters. The fittings are not the same thread and they are not set up for the anti tilt safety switch. You'll need to purchase the parts from Blue Rhino.
Jan 29, 2010 | Endless Summer 233000 Open Flame Patio...
The pilot light will not turn off after the burner is on... I think it over heats, because it will just shut off after several minutes.... any suggestions? Thank you
The pilot light must remain on, even when the main burner is on, to keep the thermocouple hot. If the thermocouple cools off, the gas flow shuts off. It sounds like something is interrupting the gas flow. If this is an LP heater, try replacing the regulator.
Dec 11, 2009 | Berkeley Forge G-PH001PSS Open Flame Patio...
Can you telll me how many BTUs is has?
There is a UL plate on the heater it should strate the BTU's on it I did find this for you Berkeley Forge G-PH001PSS Open Flame Gas Patio Heater. Patio, Alimentation: Gas, Open Flame, 12000 BTU
Oct 12, 2009 | Berkeley Forge G-PH001PSS Open Flame Patio...
Need parts: pilot assembly and thermocouple
THe thermocouple either has 2 wires or a coppr tube going to the gas valve. They can be bought at a good hardware store or a plumbing supply. The length of the wires or copper tube will be the determining factor as to which one you need. As these thermocouples, when heated generate a small electric charge tha keeps the gas valve open. Should cost no more than $10-15 USD
Oct 10, 2009 | Berkeley Forge G-PH001PSS Open Flame Patio...
Need cover for heater
If you google berkeley products there is a phone # to call in Calif.
Sep 05, 2009 | Berkeley Forge G-PH001PSS Open Flame Patio...
Outdoor patio heater won't stay lit
I'm told by Charmglow that the problem is the Thermocouple. iHowever,it took me several calls to get someone to admit this. They are sending a new thermocoupler. My heater is less than a year old and under warranty--but it's a shame things like this happen.
Originally I was told it could'nt be the thermocoupler as they normally last at least 5 years.
Try it--as it may solve your problem as well.
Sep 21, 2008 | Heating & Cooling
Berkeley Forge Outdoor Propane Heater Sunrise Model SR1001
I believe the company is out of business but I just got my heater fixed using a local gas service company. Took them a while to find a compatible thermocouple assembly but he found it so there is hope.
The unit works like new now except for the ignitor but not a big deal as it works fine to light the pilot with a lighter.
Jun 10, 2008 | Berkeley Forge G-PH001PSS Open Flame Patio...
Sterling Forge SFP40PT Gas Patio Heater Logo
53 people viewed this question
Top Sterling Heating & Cooling Experts
Paul Carew
bobalix
deton8 von Splosion
Are you a Sterling Heating and Cooling Expert? Answer questions, earn points and help others
