Question about Cub Cadet Garden
Valve clearance for a kohler courage 23
Where to set valves on a 2006 kohler courage 23
SOURCE: DGS 6500 w/26hp Kohler Courage surging
i HAD SIMILAR ISSUES WITH MY 2500 SERIES CUB CADET....IT WAS THE CARB.....REPLACED, AND ALL HAS BEEN WELL...THINK IT WAS APROX 200.00
Posted on Jul 26, 2009
  • 376 Answers
SOURCE: what are the valve clearance settings for a
Intake and exhaust both at .004
Posted on Oct 09, 2009
huffman49
  • 235 Answers
SOURCE: MY NEIGHBOR KOHLER COURAGE 20 LTX1045 WILL TURN
check and see if it's getting spark by removing the plug from the engine and keeping it plugged into the wire,lay the plug on the head and turn the engine over and look to see if the spark is jumping accross the gap. if it's blue your ok if it yellow you'll have to replace ignition modual..good luck
Posted on Apr 10, 2010
nova2nv
  • 197 Answers
SOURCE: cant set valves clearance...
Set both intake/exhaust valves at .004 with piston 1/4 inch past top-dead-center on compression stroke if this machine has a Briggs in it
Posted on May 22, 2010
philwalker78
  • 608 Answers
SOURCE: How do you reset the change oil light on a kohler
Hi, the light will cancel automatically after another two hours use. Regards Phil.
Posted on May 11, 2011
How to adjustvalves on kohler22 on craftsman
Gary, they may be hydraulic and not require adjustment, check the attached links, they will help determine and show how to.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://outdoorpowerinfo.com/engine_specs/kohler_valve_clearances.asp
How to Adjust the Valves or Valve Lash on Kohler Courage XT Lawn Mower...
Work on the Cub Cadet i1046 Kohler twin setting the valves
Owners Service Manuals
Apr 14, 2016 | Cars & Trucks
What is the specs for the valve clerance on Kohler courage 23 motor
COURAGE SV720 Air Cooled Vertical Crankshaft V-Twin OHV 0.101/0.152 mm (0.004/0.006 in.) http://outdoorpowerinfo.com/engine_specs/kohler_valve_clearances.asp
Mar 18, 2016 | Garden
How do I adjust the valves on my courage 21 engine
This might be a little late...but this is from the service manual.
With engine at TDC of compression stroke, insert
correct size flat feeler gauge (see below) between
appropriate valve stem and rocker arm. Tighten
adjustment nut with a wrench until a slight drag is felt
on feeler gauge. Hold nut in position and torque set
screw (T15 Torx drive) to 5.5 N·m (50 in. lb.). To
prevent damage to nut, torque Torx screw only.
Perform adjustment procedure on other valve.
Clearance Specifications-Valve
Intake Valve 0.127 mm (0.005 in.)
Exhaust Valve 0.178 mm (0.007 in.)
Oct 19, 2014 | Husqvarna Garden
Kohler courage v twin 22 hp on my Troy built Ztr starts fine but loses power when cutting grass
bad valve seat needs valve job motor is overheating looseing power or under load
Aug 06, 2014 | Garden
Can the overhead valves on a 16hp sears craftsman with a kohler engine be the reason why it won't start and if so, can I adjust them
Valve clearances will also effect the decompression valve in the engine, if they are too wide the valve lifter will not work and the battary will not have enough energy to crack the engine.
Jun 27, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Valve clearances
mine has hydrodrolic lifters no adjustmetn
Aug 21, 2012 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Garden Logo
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
