Where can I purchase a amp for my klh subwoofer GFX 700 Chopper
I replaced the amp before, where can purchase another amp?
4 Suggested Answers
  • 9 Answers
SOURCE: My klh subwoofer has R&L
Yes, you use a subwoofer cable and hook it into the mono rca jack in the back of the sub. or you can use a Y splitter 1 female to 2 males. or if your amp has 2 sub outputs (L&R) then use both. I do believe it's said that if you use the high level input, it's better. I forgot why...
Oh yeah. the difference between the 2 is a high level input allows the currant from the amp to pass through the sub, thus allowing the continuation of wattage to your other speakers.
Low level input is only taking a audio signal from the amp. No power is being sen through the connection.
Posted on Mar 21, 2009
SOURCE: KLH ASW10-120 Subwoofer My KLH ASW10-120
Did you ever find a solution for this problem? I have the exact same thing happening with my KLH subwoofer and I'd love to know how to fix it!
Posted on Jan 26, 2010
SOURCE: my model 765S KLH powered subwoofer keeps blowing
I saw this post. I have the same problem with my 10-100.
http://www.fixya.com/support/t2753393-klh_subwoofer_about_6_yrs_old_keeps
Posted on Jan 09, 2011
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
How to install KLH asw10-20 to a 7.2 receiver
Yes, the 10-120 can use a L & R low level subwoofer input. You can get a short 6" RCA splitter adapter from Radio Shack for a under $10. (1 female input, 2 male outputs) Alternately, just plug the subwoofer output on your receiver to just the low level R channel on the KLH sub.
Jan 20, 2015 | KLH Audio Players & Recorders
Klh subwoofer keeps blowing it's fuse.
Most likely the amp in the sub has blown. It will need repair or replacement. I'd take it to an expert in repairing amps, it's not a job for you unless you're experienced in troubleshooting these things.
Dec 31, 2014 | KLH Audio Players & Recorders
My KLH subwoofer (model ASW8-120B) has stopped working and emits only a low-pitched hum.. I have tried hooking it up using the ''high-level'' 2-wire inputs as well as the ''low level'' RCA plug inputs....
It's unlikely that you can find a shop to repair it for less than the replacement cost ($75ish for a comparable KLH or Sony sub)
If you're up for doing your own soldering, here's a solution for the same problem with the same amp.
If this helps, please hit the "thumbs up" for me!
Jun 26, 2010 | KLH ASW10-120 Subwoofer
KLH subwoofer Model BASSBite V. Has a bad 60Hz buzz
Before you go throwing money at this problem, try to eliminate any external influences like track lighting. I myself am trying to figure out why mine makes a buzz throughout my system when the lights are on. I already replaced the variable light control with no improvement.
Bad cable ground can let airborne electronic noise into the Sub's amp.
Jan 31, 2010 | KLH ASW10-120 Subwoofer
Klh subwoofer asw12 200 powers on but no sound, hooked up my other sub works fine
There's an amp inside the unit, most likely the semicondutor that does all the work has failed in it.
Jan 29, 2010 | KLH ASW12-120 Subwoofer
Dec 26, 2009 | KLH ASW10-120 Subwoofer
Have the KLH ASW10-120 Powered Subwoofer and it is blowing fuses
If it stays on for 3 seconds then it probally is not the transformer. However it may very well be the power amp no way to tell untill we operate. Call Pro Line Music 215-736-8055
Dec 11, 2009 | KLH ASW10-120 Subwoofer
How do I fix a blown amp
big red
check usually the fuse just blows up just change it
Oct 22, 2009 | KLH ASW10-120 Subwoofer
 Grubhead
Grubhead
