Question about Car Audio & Video
Pioneer gm h200
How to hook it up without the 3 prong remote,ill, and acc wire
5 Suggested Answers
SOURCE: i have a Pioneer GM-H100
I have a gm-h100 amp. The three prong plug is for a remote turn on. Mine has two wires one of which goes to the radio where it gets a power on sigonal (12 volts when the radio is on). the other wire goes to the an accesory fuse where it gets 12 volts when the key is turned on. the amp needs both of these before it will run
Posted on Jun 27, 2009
SOURCE: My pioneer gm-h100 amp does
there should be a wire harness that clips into the side of the amp if you dont have the clip u can just use some end conecters and hook it up to the two pins that are on the side and hook that to the remote wire.
Posted on Aug 20, 2009
kenw392
  • 2226 Answers
SOURCE: i have an old school
If I remember correctly there is a 3 pin plug, the first two pins are remote turn on.
Posted on Jun 23, 2011
  • 231 Answers
SOURCE: can not find where to
This remote wire requires a switched 12 volt .This can be connected at fuse panel and or to radios remote out or power antenna wire.
Posted on Sep 23, 2011
I bought a used pioneer car stereo/cd player for my boat,battery wire marked, acc marked ( what does that wire up too?? ) & remote wire?? wat does it hook too ??
battery(yellow) goes to power that is ALWAYS on.(straight to + on batt) red or acc goes to accessory position of ignition key. (if no acc then wire to ign on(unless you want to listen to it with boat off then wire to batt + also but deck will be always on. REM is remote switch wire(gets power when h/u is on) and is used to turn on the amplifier if you have one or to make electric aerial go up. if you don't have either then don't worry bout it. leave it off but tape up the end.
Jun 18, 2010 | Car Audio & Video
Red light showing up on amp ( pioneer 800 watt GM 7200 amp )
it could be the amp it could be the way you've installed and if you have a sub in an enclosure the wires could be touching the postive and negetive speaker wires what ever the problem is the amp is in protection mode i hope this helps hope its not the amp i hope its just the wiring
Jun 05, 2009 | Pioneer GM-7200M Car Audio Amplifier
I have a used pioneer cd deck. No sound to speakers
The blue wire would be your remote wire to hook up a amp and if you have a wire harness all you have to do is match the colors up.
May 14, 2009 | Pioneer DEH-P3100 CD Player
I need a wiring diagram for a Pioneer GM-A200 Amplifier
For a Pioneer GM-A200, pls use below wiring scheme:
  • Green & Green/Black - Left Speaker;
  • Gray & Gray/Black - Right Speaker;
  • Yellow - Illumination B+12;
  • Red - ACC B+12;
  • Orange - Always ON B+12;
  • Black - Ground/Chassis.
For the 8P INPUT DIN connector:
  • 1 - SWD +B;
  • 2 - Left Input
  • 3 - Audio Ground
  • 4 - Mute
  • 5 - Right Input
  • 6 - UN SWD +B
  • 7 - Illumination B+12
  • 8 - NC
  • Body - Ground
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 23, 2008 | Car Audio & Video
My pioneer gm-h100 amp does not have a remote wire hook up on the amp
Aug 11, 2008 | Car Audio & Video
I have a Pioneer GM-H100 amp and I can not figure out the whole 3 prong thing is there a special wiring for it i have seen mixed comments of this same problem on different website can you please help me...
Jul 23, 2008 | Car Audio & Video
How do i turn on sub mode?
For one thing I hope you know you need an amp to even power subs at all.. The remote wire coming off the rca wiring that you hook your subs up with has to go on the prong 3-in on the top here is a rough diagram: the = signs are power and ground and the prongs are thicker the comma is you remote..
You need a wire coming out of that slot on the wiring harness.. it should be blue. and unless you have a power antenna(comes out when you turn your radio on) then you dont need the blue/blue&white power ant. wire you can just cut it and cap it. if your amp isn't coming on when you turn your ignition to acc then your remote wire isn't properly attached..
May 15, 2008 | Pioneer DEH-P4700MP CD Player
Witch is better
hi there. ill start with the wiring. you should have a blue remote lead going to the back of your head unit, the power cable running straight from the amp to the battry, the earth should be earthed in a fairly decent place, any metal inside the car realy, and then your wires pos and neg from the amp to the subs. the reason why the kenwood might not have much base on it is to my knowledge, there should be a switch somewhere on the amp that will increase or decrease the power input for the speakers, if this is set very low then hense why theres not much base comming from them. if the amp is on and its giving something to the subs it probably isnt the wiring. try checking the amp for the switch first, if you cant find it try the pioneer amp and see if theres any diference.
dont hesitate to contact me if you get stuck
cheers, adam
Oct 31, 2007 | Pioneer GM-7200M Car Audio Amplifier
Car Audio & Video Logo
29 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
