Question about Camping, Backpacking & Hiking
What should the compression be on a husqvarna 350 chainsaw
  • 2692 Answers
SOURCE: stop button not working
A stop button is just an on off switch or a monitary off(Short) switch which shorts out the primary to the coil. Either the switch is broken , the ground wire not making good ground or the primary wire to the switch is off. You can get any two position switch, (for example from radio shack) and replace it withhe noew on if the switch itself. Trace the two wires to see if they are connected. Most likely is the ground one is off or disconnected.
Posted on Feb 28, 2009
  • 582 Answers
SOURCE: i have a husqvarna 350 chainsaw, it wont cut straight.
THE ONLY THING THAT CAUSES A SAW TO CUT ON A CURVE IS THE CHAIN IS SHARPER ON ONE SIDE THEN THE OTHER AND IT PULLS THE SAW CHAIN TO ONE SIDE CAUSING THIS PROBLEM.
THERE IS NOTHING WRONG WITH THE SAW, IF YOU USE A FILE TRY A FILE GUIDE THEY WORK GREAT
Posted on Sep 17, 2009
Testimonial: "thanks "
rwvanlue
  • 486 Answers
SOURCE: My Husqvarna 350 chainsaw won't stay running.
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 25, 2009
Testimonial: "Excellent info"
SOURCE: 350 chainsaw will not start and run, getting fuel
check set screws on the side of carb turn the all the way in the turn out till idles or check the screen in the muffler
Posted on Feb 04, 2010
dontbother10
  • 2220 Answers
SOURCE: trying to find out what year and model my 350
I am faily certain 967 01 18-00 has to do with the EPA.
If 03 4103750 is the serial number then;
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
03 4103750
03 = year produced – 2003 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
41 = week produced – October (05-11)
03750 = 3750th unit Husky produced that week (not saw, unit)
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 26, 2010
How much compression should the saw have?
What Causes Too Much Compression on Poulan Chain ...
homeguides.sfgate.com > ... > Other Types of Mortgages
Many makes of gasoline-powered yard tools, including Poulan chain saws, use two-cycle, or two-stroke, combustion engines. ... Pull the rope out and oil it to see if that helps the problem. ... How Much Compression Should a Stihl 066 Have? ... Pull Starter on a Poulan Chain Saw · Oil Pump Removal on a Poulan Chain Saw ...
The Timber Trades Journal and Saw-mill Advertiser
Nov 26, 2015 | GCSP Husqvarna 340 345 346 350 353...
Can I take piston and rings out of a 41 husqvarna and put it in. a husqvarna 350 chainsaw
No. The 41 uses a 40 mm piston and the 350 uses a 44mm piston.
Mar 21, 2015 | Husqvarna Garden
Husquvarna 350 chainsaw won't stay running
There could be a couple of things wrong. Check fuel filter and fuel lines for integrity. Then check air filter. Replace sparkplug with proper resistor style plug. If the saw will still not run, check compression, should be between 120 - 145 lbs.
Still nothing, check to make sure ignition has good ground where it mounts on case.
May 10, 2014 | Husqvarna Garden
Fuel/oil mixture ratio huskvarna 350
With Husqvarna two stroke oil it should run at 50-1, with other two stroke oil run it at 25-1 as we do not know the quaility of other oils, always try to use Husqvarna oil.
Nov 25, 2012 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Compression ratio for husqvarna 455 rancher chainsaw
be careful check the compression on that engine it has a compression release valve on the side of the cylinder the release builds up with carbon and it sticks dropping the compression
Aug 27, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a husqvarna 350 that wont start, wondering if anyone can tell me what is the factory compression rating?
Hi and welcome to FixYa, I am Kelly You should have 120 PSI or greater compression. There is a ported compression release so you may see as little as 110 PSI but it is best to see 120 or greater.
The Owners manual is here:
http://www.northerntool.com/downloads/manuals/195946.pdf
carb basic settings are on page 29 of the manual.
The saw has a Zama C3-EL18 carb.
The manual for the carb is here:
http://www.zamacarb.com/pdfs/TechGuide_2007.pdf (Click and wait 2.50 mb)
Your carb is the C3
The workshop manual for the saw is here:
http://www.scribd.com/doc/8152011/Husqvarna-Chainsaw-Workshop-Manual-340345346XP350351353 (Must have a facebook account to download but can be viewed online)
Thanks for choosing FixYa,
Kelly
Sep 23, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Saw stalled after last cut,and seems to have lost compression
Doesnt sound good, remove the two muffler screws, remove the muffler, check the condition of the piston through the exhaust port, any signs of scuffing, or piston damage and the cylinder will have to come off for possible replacement. Cylinders are very expensive so you need to consider wheather this is a viable repair.
Mar 07, 2011 | Husqvarna ChainSaw 18 in Bar 32 HP Model...
Husqvarna chain saw not starting. Seems to have lost compression. What should the compression be?
If its lost compression i would remove the two/three screws holding the muffler, take a look through the exhaust port at the piston, if there is any sign of scuffing or damage it is going to be cylinder off.
Nov 21, 2010 | Husqvarna ChainSaw 18 in Bar 32 HP Model...
Feb 03, 2010 | Husqvarna Garden
Camping, Backpacking & Hiking Logo
789 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
