Question about Hunter Ceiling Fan Remote Receiver 85112-01
Bought new remote& reciever,how to install it
Repo house owners took remote ,i bought a new one how do you install new reciever?
    Genius:
  • Hunter Master
  • 1,617 Answers
What model of fan do you have? It's a 5 digit number starting with a 2.
Posted on Jul 24, 2013
Harbor breeze ceiling fan w/lights&remote
Did the fan have a remote when it was purchased? If so, you already have a receiver in the fan somewhere. You'll have to find it to see if you can set the new transmitter to the same frequency.
Jul 23, 2013 | Dryers
I just bought a repo house which has a grundfos circulation pump u p 15 installed at the water heater. House built 2005 4260 sq. Feet. House has 4 showers only one of them gets hot water. All sinks get hot...
that pump is likely to be a hot water return pump not a booster pump. it sound like a large property so its likely the hot water system requires balancing to get the hot water to the extreme areas. If all the hot outlets have some form of isolation valve try closing all but the affected areas and see if hot water comes out. If so only open the closed outlets enough to give you reasonable flow. This hopefully will force the hot water to the affected areas.
May 20, 2010 | Home
Chamberlain Whisper Quiet garage remote won't work
There isn't a trick but you must make sure you got the right remotes for your opener. The receiver which is part of the logic board can quit working and it sounds like this may be the case in your situation.
Sep 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
No remote control
I'm sure you can buy a new remote for that fan, but you will have to access the remote reciever in the fan itself so that you can get the switch sequence so that you can match it with the remote you purchased, it should work fine.
P.S. Dont tear the hell out of the package just in case you have to return the remote. I find the easiest way is to cut the plastic package close to the cardboard on three sides with a box cutter.
May 17, 2009 | Casablanca Fan Bel Air 3811T Ceiling
My garage door opener remote range limitted
Yes the receiver can go bad over time and lose range. Most likely the receiver cost plus the labor will cost as much or more than a new unit...depending on who does the repair. FYI another cause of reduced remote range can be signal interference from other sources which would be a little harder to track down unfortunately. Wireless routers, new appliances anything with electronics are a possible source of trouble.If you or a neighbor bought any new gadgets there's a small possibility of thatbeing the issue. But based on the age of the unit that's my first guess.
Rustym62
Apr 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to purchase a 2007 Chrysler 300 owners manual
Your local Chrysler dealer, or you might try ebay. Also, wrecking yards usually have them used from the wrecked vehicles.
Apr 21, 2009 | 2007 Chrysler 300 AWD Sedan
Blackberry curve 8300 no signal only sos.
I took it to the original operator who checked the imei ,and they told me the data package was cancelled because the phone was under a business plan of 2 years and someone unlocked the phone so they blacklisted it.
Now I have to make a new contract and all will be resolved.
Thanks hope this helps.
Mar 19, 2009 | RIM Blackberry Curve 8300
Will drop pin remote work with rolling code opener?
GET A CHAMBERLAIN OR LIFTMASTER SECURITY PLUS.
DON'T GET A UNIVERSAL THEY ARE USSUALLY A WASTE OF TIME.
Mar 14, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Hampton bay fan with remot problem
You can try the universal receiver. The white, black, and green wires are the house wires. The receiver must match to these on one side. The wires on the other side go to the fan/lights. It is possible that one of these has come loose. If you try the universal, make sure the dip switches are in the same positions on both.
Or,
Take the fan down, and remove the receiver completely, from house wires and fan. (Make sure the breaker is off first!) Then wire the fan directly to the house wires. The blue wire on the fan is for lights. Wire it with the black wire in the same wire nut.
I'm assuming you have a wall switch that powers the wires coming from the ceiling.
By the way, I have never seen anyone control two fans with lights with one receiver. Usually each fan has its on.
Feb 09, 2009 | Hampton Bay 52 In. Ant. Brass Redington...
Alpine mrp-m450 Amp won't stay on
im having the same problem with my amp, I took it to best buy and they said the amp was recieving power and recieving signals from the deck and i had everything hooked up right but that in the circuit board all the connections were blown, meaning i have a blown amp, i hope this isnt your problem but it definetly sounds like it. GOODLUCK
Nov 12, 2006 | Alpine MRP-M450 Car Audio Amplifier
Dryers Logo
131 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
