Question about Yamaha P85 88Key Portable Digital Piano
Factory settings reset
My Db 3 to my F# 3 chromatically won't play "/
    Top Expert:
  • Yamaha Master
  • 3,141 Answers
That will most likely be a loose ribbon conncetion between the keyboard and the felectronics. If you are not an experienced tech, I suggest taking it into the shop. It's easy to cause a bigger problem poking around inside if you aren't sure what you're doing.
Posted on Mar 25, 2016
Needs to be looked at
Posted on Jul 25, 2013
My Ewi is playing most of the patches in Bb and some in others keys. How can I fix it? I 've reseted and nothing changes
You may need to do a factory reset. It sounds linke a transpose setting has been invoked. Read your manual under the word "transpose". A factory reset, if required, usually involves holding one or more buttons or keys down while turning on power and holding them until the reset is acknowledged.
Jul 20, 2012 | Akai Ewi4000s Electronic Wind Instrument
Dean razorback db electric guitar knobs
the knob closest to the neck is your volume. And the other two are tone. one is tone for bridge p/u & other is tone for Lead p/u. which is which can vary. you'll just have to listen. hope this helps
Jan 31, 2012 | Dean Razorback Db Electric Guitar
How to use korg chromatic tuner ca 1
Here is a download of the manual:
http://pdfservicemanual.com/download/http://www.korg.de/uploads/tx_softwarecenter/CA1_Handbuch.pdf
Let me know if you have specific questions, and I'll be happy to help!
Regards,
PvT
Sep 25, 2011 | Korg CA1 Chromatic Tuner
G5 is flat. How can I bring it up to pitch?
Is your question about G5 ppc mac. or about Suzuki g5 motor cycle.-------------I assume its about g5 ppc mac.-------
Try downloaded the latest version 2.5.1 to update the 2.2 version;.---------- 1) Open Finder and go to the Macintosh HD -> Library -> Receipts folder. In here you'll see the Pitch 'n Time Pro 2.5.1 Installer.pkg file - delete this.
2) Go to the Macintosh HD -> Library -> Application Support -> Digidesign -> Plug-Ins folder. In here you'll see the Pitch 'n Time Pro.dpm file - delete this.
3) Run the Pitch 'n Time Pro installer again.
----------------- If there is no installer.pkg. File.Then However,you will see these other two files as follows :---Pitch 'n Time Manual.pkg-------
Pitch 'n Time PlugIn.pkg--------
Delete this files.-------- Then try installing latest version and see.--------- ------------- Check out, keep updated, thanks.Helpmech.
Jul 31, 2011 | Suzuki 25Note Chromatic Tone Chime Set
How to factory reset mpd18
Heres how to restore your MPD24 factory defaults using the Vyzex software:
1. Plug in your MPD24 with USB cable, and then open the Vyzex software.
2. Click File > Open
3. Select Factory SET.SQS, and click open it.
4. You should now see BFD Lite and other details on the Vyzex MPD image.
5. As long as you're on the DATA tab, you should see a PUT SET button available. Press it to transfer the factory presets to your MPD24.
6. An overwrite warning will be displayed. Press YES to overwrite your damaged MPD24 presets with the factory presets.
You'll see a progress bar filling up for about 10 seconds, and then once it disappears, that's it!
You're all done - Enjoy!
Jul 29, 2011 | Akai Professional MPD18 Steven Slate...
Hi, i have a acoustic guitar and i am trying to tune it but i do not know how to use the Matrix Chromatic Tuner SR-1050
Hi
Simply turn the tuner on using the power button. Play an open string note close to the tuner (no more than about 1/2 metre away) - for instance the low E on string 6.
The built in microphone will pick up the sound and, if your guitar is reasonably close to being in tune the led light labelled 'E' will illuminate on the lower scale on the tuner along with one of the three other leds to indicate whether the note is flat (b), in tune (green) or sharp (#).
Due to harmonics any or all of these three leds may flash but it is the one that is on the most that matters.
Adjust the tuning peg until the green is on constantly when you play the string.
Move on to the next string
Note - if the string is more than a semitone sharp or flat a different light may flash (e.g if the low E string is 3/4 of a tone flat the D light will come on).
If you wish to tune your guitar to another instrument that is not at perfect pitch (and perhaps cannot be easily adjusted - like a pipe organ) you can use the calibrate button to adjust the setting of the tuner. This temporary recalibration will be lost when the tuner is turned off.
Mar 01, 2011 | Matrix Auto Chromatic Tuner Sr1050
Brand new chromatic tuner tu-3 pedal, plugged guitar into input and it powers on. Guitar plays through the amp, but when I hit the footswitch the check light and tuning bar do not light up.
Change the battery first. It could be dying and just barely have enough power to come on at first, but not to do anything else. If that doesn't solve it, you've got a defective one and you can go exchange it.
Feb 24, 2011 | Roland Boss Tu-3 Chromatic Tuner Tu3...
Open Questions:
See all Yamaha P85 88Key Portable Digital Piano Questions
Yamaha P85 88Key Portable Digital Piano Logo
213 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
