Question about Lands Phones
How do I look through the caller id on my Comdial Edge 120?
I need to look through my caller id list to get a number. I do not have an attendantextension passwword.
  • 65 Answers
SOURCE: Caller Id does not always show up
call panasonic 1-800-211-7262
Posted on Feb 05, 2008
SOURCE: getting caller ID off of this phone
I need to learn how to recall the numbers that called us - in other words i need to learn how to use the caller ID feature off of this phone the panasonic kx-t7453
Posted on Mar 28, 2008
SOURCE: how do i record the main greeting on a comdial edge 120
I just went thru this.
Push the Voicemail button, hit # until it asks for mailbox #, then hit 70 for password. Wait for main menu, then hit 3 for options. Then hit 2 to record your greeting. Now the tricky part,,, I don't know if these are all programmed the same way, but it will ask for the number of the box you wish to change, ours is 800, then follow along.
good luck!
What I'm trying to find out is how you can import a prerecorded message (mp3) as your greeting.
Posted on Jan 23, 2009
Vit Avaya BP
  • 211 Answers
SOURCE: turn off caller id
Unfortunatly the only way to do it is to take line access off that phone and have a button call pickup to access ringing line. In this scenario extension wont ring Reffer to programming manual on support/avaya.com Cheers
Posted on Jun 10, 2009
  • 32 Answers
SOURCE: External caller ID does not display on either line talkswitch 284
Log into your TalkSwitch Management Software.
Go to Telephone Lines.
Under each incoming line make sure that Caller ID is checked.
Click File> Save
Hopefully this will fix it for you.
Posted on Jan 20, 2010
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
How do you check voicemail on the comdial 7260 edge 120?
There should be a voicemail/Vmail button on the phone. From there, you dial in the extension and password.
Jul 02, 2014 | Comdial 8324S-PT Corded Phone
Uniden cordless phone caller id quit working
Using the Caller ID and Redial Lists
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information.
Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
Dec 02, 2012 | Uniden Cordless Phone
How do you block numbers
Most of the telecom service providers offer call blocking features. In addition to this, most of the vtech cordless phone sets have built-in features through which you can block incoming calls from a specific number.
    • Create a "Call Block List" on the vtech phone and store the Caller ID information of unwanted callers in the list. The numbers you feed in the block list will get a busy signal every time they try to call you.
    • Ring up the customer service of the telecom company that is providing you the phone service. Tell the representative that you want to get your incoming calls blocked from a specific number. The company will then add that number to a list of blocked numbers for your particular phone number. In the future, every time an unwanted caller tries to ring you up, he will hear a recording saying the number has been blocked.
    • Visit the website donotcall.gov. Add your phone number to the website's list of phone numbers that cannot be reached by telemarketers and businesses.
Jun 12, 2011 | Vtech 5.8GHz Cordless Phone with Digital...
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
Caller ID
The unisyn system needs an add on caller id module, If your system does not have that it cannot pass caller id info.
Dan
Jul 31, 2009 | Comdial Unisyn 1122S Corded Phone
Comdial 7260 Incoming number displayed not the name.
Call your telephone company and explain the problem. They will give you a code to put on your phone.
May 21, 2009 | Comdial 8324S-PT Corded Phone
How do i record the main greeting on a comdial edge 120
good luck!
Jan 07, 2009 | Comdial Lands Phones
Caller id recall
To redisplay the Caller Id Number, press the Line button again.Caller ID Scrolling is possible if you have a MIF-F(C)-10 card in the system and you have a Scroll key programmed on the phone. If you need further assistance, let me know.
Aug 27, 2008 | NEC Electra Professional ETW-16DC-2
Lands Phones Logo
98 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
