Question about T-Mobile Dash Smartphone
Trouble turning on my cell phone
I turn on the lock on my cell phone so as to prevent accidentally pressing a key on my key board. It was in this mode when it went off due to the battery running low. Since than, I have recharge the battery to the fullest, but the phone refuses to come back on even though I am pressing the power on button.
  • josepet123 Dec 07, 2007
    i truned off ma phone to save the power and when i tried to trun it back on it wouldint turn back on i even tried to charge it and it still wont turn on
  • Yettr Dec 18, 2007
    I was reaching for my phone and it died as i wen to answer it. It charges and everything but it will not turni back on. This phone cost to much for it to just not work like that
  • 76 Answers
I would take out the battery and keep the power button pressed for 15 seconds. After this power cycle, put the battery back in and try to turn it on.
Posted on Sep 25, 2007
6ya staff
SOURCE:
WDT790SAYMO dishwasher will not start. Appears locked. Help
Control Lock On
Use the Lock to prevent your dishwasher from accidentally being turned on. Use the Lock, also, to prevent accidental cycle or option changes during a cycle.
LOCK ON
When LOCK ON is lit, all buttons are disabled.
NOTES:
The dishwasher door can be opened while the controls are locked.
You can turn on the Lock while the dishwasher is running.
To turn on the Lock:
Press and hold NO HEAT DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light flashes 3 times.
To turn off the Lock
Press and hold NO HEAT DRY for 4 seconds. The light turns off.
If the lock light flashes constantly this indicates that a key (or keys) is most likely shorted or stuck. If this is the case the console or touch pad must be replaced. The console is only available in black (part number 3384340).
Jul 31, 2017 | Televison & Video
Tip
How to lock a Samsung Intensity cell phone
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
on Mar 04, 2011 | Samsung SCH-U450 Cell Phone
I screenlocked myself out of my LG optimus dynamic ii phone how do I getin to it
http://img-tf.deviceanywhere.com/tracfone/pub/252610/docs/L39C%20English%20UG.pdf
Locking and unlocking the screen If you do not use the phone for a while, the screen will be automatically turned off and locked. This helps to prevent accidental taps and saves battery power. When you are not using your phone, press the Power/Lock Key to lock your phone. If there are any programs running when you lock your screen, they may be still running in Lock mode. It is recommended that you exit all programs before entering Lock mode to avoid unnecessary charges (e.g. phone calls, web access and data communications). To wake up your phone, press the Power/Lock Key . The Lock screen will appear. Touch and slide the Lock screen in any direction to unlock the screen. The last screen you viewed will open.
Mar 01, 2015 | Tracfone Wireless LG Optimus Dynamic II -...
There is a word "offline" on the upper screen and
Your phone might have switched to offline mode accidentally if your keypad is not locked and you have the phone in your pocket/bag.
Press the power button momentarily to bring out a list of profile options, and select "General";
or you can go to Menu -> Settings -> Profiles and choose Normal Mode;
or you can turn the phone completely off and then turn it back on; while the phone boots up you will be asked if you want to exit offline mode -> answer yes
In order to prevent the phone from switching modes, or making inadvertent calls, remember to lock the keypad when the phone is not in use:
Left selection key + functions key
http://europe.nokia.com/support/product-support/e63/nokia-e63-how-to/get-started/get-started-shortcuts
Mar 16, 2011 | Nokia E63 Cell Phone
My jabra sp700 wont turn on
You've probably accidentally put it in locking mode. Here's what the manual says about it, and how to get out of it:
Locking mode
To prevent accidental key presses that could turn your speakerphone
on e.g. while carrying it in a bag, the speakerphone can be
turned into locking mode. Press simultaneously the Answer/End
button and FM button for 4 seconds while the speakerphone is
turned on. The speakerphone is now turned off and can only be
turned on again by pressing Answer/End button and FM button
simultaneously for 2 seconds.
Oct 20, 2010 | Jabra SP700 Bluetooth Headset
My Jabra SP700 Won't turn on
You've probably set it to locked mode whitout knowing it. Here's what the manual says about that locking mode, and how to get out it:
Locking mode
Sep 24, 2010 | Jabra SP700 Bluetooth Headset
Jabra SP700 will not turn on. Charged until green light came on. Took off charger, and put it back in. Light turned red. Eventually went green again. Will not turn on. Back to red when I plugged in...
Locking mode
Sep 24, 2010 | Jabra SP700 Bluetooth Car Kit
How to stop locking of key pad of samsung s5200
User manual: http://downloadcenter.samsung.com/content/UM/201003/20100312123734359/S5200_UM_Arabic_English_20100312.pdf
Closing the phone automatically locks the
exposed keys to prevent you from accidentally
pressing them. To unlock these keys, press
<Unlock> → <OK>.
Jun 25, 2010 | Cell Phones
How to unlock nokia 2700c
Keypad lock
To prevent accidental key presses, select Menu, and press * within 3.5 seconds to lock
the keypad.
To unlock the keypad, select Unlock, and press * within 1.5 seconds. If
the security keyguard is on, enter the security code when requested.
To set the keypad to lock automatically after a preset time when the
phone is in the standby mode, select Menu > Settings > Phone >
Automatic keyguard > On.
To answer a call when the keypad is locked, press the call key. When you end or reject
the call, the keypad locks automatically.
When the device or keypad is locked, calls may be possible to the official emergency
number programmed into your device.
Jun 05, 2010 | Cell Phones
Is there a waay to lock the keys while it is in my purse?
this should help you out.
Basicall press MENU > *
Lock the keypad
To lock the keypad to prevent keys from being
pressed accidentally, in the standby mode,
select Menu, and press * quickly; to unlock,
select Unlock, and press * quickly.
When the keypad lock is on, calls may be
possible to the official emergency number programmed into
your device.
Enter the emergency number, and press the call key. The
emergency number you have entered may not be displayed on
the screen.
Apr 19, 2009 | Nokia 1600 Cellular Phone
T-Mobile Dash Smartphone Logo
180 people viewed this question
Top T-Mobile Computers & Internet Experts
Ekse
Marvin
Marvin
markpain
Level 1 Expert
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
