Question about Sewing Machines
Kenmore sewing machine model 385. 19153
I have misplaced my manual. How can I get a replacement? Model 385. 19153, Kenmore
SOURCE: Kenmore Sewing Machine model # c877.15
I have an old Kenmore and here are the directions from my manual: 1. Draw thread from spool through bobbin winder tension discs. 2. Wind thread around an empty bobbin several times. 3. Place bobbin onto bobbin winder shaft with thread coming from rear of bobbin. Push bobbin winder latch against bobbin until it clicks. 4. Release clutch by turning clutch knob toward you. Start machine.
Posted on Aug 09, 2007
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
SOURCE: Kenmore 10 Sewing Machine
kenmore sewing machines relics
Posted on Jul 13, 2008
SOURCE: kenmore sewing machine model 385 16764
There's a website called managemyhome.com which is sponsored by Sears. It's free to join. Go to the Home Manager column and choose Owner's Manuals from the drop down menu.
You can type in the brand name (Kenmore) and model number of your machine. Not all of them are in there but, I did find the one for the 1950280 question. It's a pdf file.
For the 38516764 question, please double check your model number. I received either no response or a Kenmore Elite dishwasher manual in response to my query.
Posted on Feb 04, 2009
  • 3 Answers
SOURCE: Dropping Feed dogs on kenmore model 19233
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
Posted on Mar 07, 2009
Kenmore troubleshooting
I guess the obvious question would be did you try googling the machine model? Many manuals can be downloaded. You could also call the manufacturer.
Jul 22, 2014 | Kenmore Sewing Machines
Looking for a manual for a Kenmore 158.1355080 Sewing Machine for a friend.
The closest manual I could find was for 158.1355, which is here.
Found using a google search of: Kenmore sewing machine 158 1358 filetype:pdf
Jan 29, 2012 | Sewing Machines
Manual
I found a manual for my 1968 Kenmore on Ebay for $8.
Nov 01, 2008 | Kenmore 11101 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
