Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Demo mode for profile side by side refrigerator
4 Suggested Answers
SOURCE: ge profile refrigerator
my refrigerator model #gss221fphbb not cooling
Posted on May 12, 2008
  • 1314 Answers
SOURCE: Demo Mode
try unplugging it then plug it back in
Posted on Jul 19, 2008
rogrrabbit
  • 986 Answers
SOURCE: We just purchased a ge profile refrigerator today,
You have to go into the Diagnostic mode to see if you can reset this issue or if the main board in back is bad. Here's how to do it:
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all 4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test. Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
First, run the control and thermistor test:
Control and Sensor System Self-Test (0 7)
This test checks all five thermistors located throughout the unit. Once the test is initiated, the test code (0 7) will stop flashing and the thermistor test results will appear on the freezer display in the test order listed below. The thermistor test sequence number will not be shown on the display. If the unit is not equipped with the Quick Chill option, the third thermistor (quick chill) will display a 0 and 3 audible beeps will sound at the temperature control panel. This is not a failure if the unit is not equipped with the Quick Chill option.
Thermistor test results:
• P = Pass
• 0 = Failed
• S = Short to 5 VDC
• B = Bad amplifier
When testing has been completed, do the following :
• Enter code 1 5 to completely reset the system. Then press the Hold button (or any other button than a temperature button) to accept the code.
When you're done, unplug the refrigerator for 10 seconds and plug it in....if it does not run, the board is bad.
Posted on Jun 14, 2009
Tip
How to reset it out of demo mode
If your not getting any response out of your control pane you will have to do the following
The refrigerator may be in Demo mode which disables the compressor to save electricity when the refrigerator is on the showroom floor. To cancel Demo mode, press Freezer and Arctic Select Zone buttons for 8 seconds. You will hear a chime.
on Dec 25, 2008 | Samsung RM255LASH Side by Side...
It is showing a code: OF followed by oF
Your refrigerator is in demo mode. For a detailed description of how to get refrigerator out of demo mode, press the two button on the upper left side of display for 3 to 5 seconds or until the OF dissapears. If your refrigerator does not have a display on the front side, do a search for "how to take samsung refrigerator out of cooling mode/ demo mode" and it should give you several options available for your model of refrigerator.
Hope this helps
Mar 03, 2015 | Samsung RS265TDRS Side by Side...
Can't get out of demo mode
On most, if not all similarly styled refrigerators, demo mode is toggled off and on by holding a combination of buttons on opposite sides of the display. Which buttons can depend on manufacturer, model, and display or button layout. For most LG refrigerators, it should be the "Refrigerator" and "Ice +" buttons. Hold them until they sound a beep to indicate a change in the demo mode status. It should not take more than 10 - 30 seconds.
If that does not work, and there are other buttons on opposite sides of the display, then try the other opposite pair of buttons.
Apr 05, 2013 | LG LFX25978ST Bottom Freezer French Door...
The temperature display keeps on flashing and will not stop. It is on both the freezer side and the fridge side.
Either the fridge's controller is trying to indicate a failure, or a temporary power failure has reset the fridge and it's demo mode. Demo mode is the mode used in stores where the lights and stuff will work but the motor doesn't run. Exiting demo mode may be as simple as unplugging it again for a few minutes, but you should look in the troubleshooting section of your manual to find out for you specific model.
Feb 27, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
How to turn off demo mode
How do you turn off the Demo mode on the electrolux side by side refrigerator??
Jul 09, 2009 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Resetting the demo mode
turn off with OFF sw.
Press WARMER / COLDER sw for 5 seconds
While maintaining warmer / colder turn ON with ON sw.
SHOULD NOW TURN ON
May 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Floor model will not come out of demo mode.
If following dirctions from your owners manual does not do the trick. I would call for a tech to look at it. Every thing is control by dispenser board on a PSS26P
Jul 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Demo Mode
Jul 19, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ge profile refrigerator
May 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
