Question about Canon Pixma MX410 All-In-One Printer
Can't uninstall Canon MX410 MP Drivers
Hi, I am trying to uninstall my MX410 series printer and it all uninstalled except for the MP Drivers. When I hit uninstall, it comes up with a message "Disconnect the printer cable from the computer and then try again". The printer was wireless and is long gone now. It is certainly not plugged in so I don't know what's going on. I wouldn't worry about fixing this, but because of it my new printer won't install. If it helps, when I go into device manager the entire page is blank. I searched for a solution to this and tried all the suggested fixes with no luck. Thanks for any help!
  • Canon Master
  • 27,725 Answers
Have you tried uninstalling the drivers in safe mode ?
1.
You should print these instructions before continuing.
They will not be available after you shut your computer down in step 2.
2.
Click Start and then click Shut Down.
3.
In the drop-down list of the Shut Down Windows dialog box, click Restart, and then click OK.
4.
As your computer restarts but before Windows launches, press F8.
On a computer that is configured for booting to multiple operating systems, you can press F8 when the boot menu appears.
5.
Use the arrow keys to highlight the appropriate safe mode option, and then press ENTER.
6.
If you have a dual-boot or multiple-boot system, choose the installation that you need to access using the arrow keys, and then press ENTER.
Note
If Windows launches before you can choose a safe mode, restart your computer and try again.
In safe mode, you have access to only basic files and drivers (mouse, monitor, keyboard, mass storage, base video, default system services, and no network connections). You can choose the Safe Mode with Networking option, which loads all of the above files and drivers and the essential services and drivers to start networking, or you can choose the Safe Mode with Command Prompt option, which is exactly the same as safe mode except that a command prompt is started instead of the graphical user interface. You can also choose Last Known Good Configuration, which starts your computer using the registry information that was saved at the last shutdown.
Safe mode helps you diagnose problems.
If a symptom does not reappear when you start in safe mode, you can eliminate the default settings and minimum device drivers as possible causes.
If a newly added device or a changed driver is causing problems, you can use safe mode to remove the device or reverse the change.
There are circumstances where safe mode will not be able to help you, such as when Windows system files that are required to start the system are corrupted or damaged.
In this case, the Recovery Console may help you.
NUM LOCK must be off before the arrow keys on the numeric keypad will function.
Posted on Jul 23, 2013
sandrew
  • 2961 Answers
SOURCE: "Error 1068 Could not start the Printer Spooler on local Computer"
Just to add to CoachTim's excellent solution, i find that removing the printer from the usb port as well as turning it off helps. But make sure you uninstall printer completely from add/remove programmes and check in the folder after that there is no canon printer listed. download this UK driver http://software.canon-europe.com/software/0024838.asp?model= Restart your pc before re installing and re connecting printer.
Posted on Feb 16, 2007
ShineMicheal
  • 131 Answers
SOURCE: Canon LaserBase MF5770 problem
Paste this address in your browser window.You could find some vital information there.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=124&modelid=11147#SupportDetailAct
Posted on Jul 16, 2008
komguy
  • 2306 Answers
SOURCE: Canon MP480- 5011 - Printer Error Has Occurred After Scan/Prt
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints.
Posted on Jul 16, 2009
canontech
  • 1219 Answers
SOURCE: ERROR MESSAGE U051
Print head not installed,
or not properly
installed.
[1401] U051 Print head is not installed. Install
the print head.
Install the print head properly.
It may be that print head is defective or main PCB assy
Posted on Jan 12, 2010
pineworks
  • 4041 Answers
SOURCE: Canon MX310 scanner driver not found
Hi there
You can download a driver from my website then you can use the driver to set your printer up.
Just click on this link and it will download for you, and it is best to save it on your desktop so you can find it.
This is for the MX310 it for XP and Vista.
Click Link = http://www.4all2sell.com/driver/Canon-PIXMA-MX310-All-in-One-XP-Vista.exe
Ones you have downloaded just double click on it to run it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks All files on my website are only there for a limited time.
Posted on Mar 24, 2010
Is Canon Pixma MX410 compatible with Windows 10 Home OS?
The MX410 is fully supported by Canon for Windows 10. You can find the available drivers for the MX410 here: https://www.usa.canon.com/internet/portal/us/home/support/details/printers/support-inkjet-printer/mx-series/pixma-mx410?tab=drivers_downloads . You will need to confirm weather you have the 64-bit (x64) or the now rarer 32-bit version of Windows 10 Home. The basic drivers are listed under the Driver tab. The MP Navigator program is under the Software header. The full software is useful, for many users.
Note: the available software does not include any third-party software that may be on the original discs that came with the all-in-one.
I hope this helps.
Apr 19, 2017 | Canon Office Equipment & Supplies
Why has PIXMA MX410 printer stopped working? Re-installed Canon PIXMA MX410 All-In-One Printer on hp pavilion 23 widow 8 x 64, system would only print but menu solutions would not. Then printer stoppe
Driver issue. Uninstall and reinstall driver for win 8 64 bit - should work if same worked before. Did you try a system restore to time when printer was working properly?
Sep 11, 2017 | Canon Office Equipment & Supplies
Hello, i'm trying to install canon mp drivers
You may not have enough room on your hard drive to install the drivers. If you have a previous canon printer driver installed, you have to completely uninstall it, too.
Sep 03, 2017 | Canon PIXMA Office Equipment & Supplies
My canon MX 410 is printing blue as pink
the fast and sure way is to reinstall both the program and the printer drivers. when uninstalling, make sure to delete user settings as well if the uninstaller ask for it. next, reboot your computer and reinstall drivers and software.
if the problem's still there, you can try replacing the cartridge again. if it's still not better after a few full page color prints, the printer is broken.
Dec 20, 2012 | Canon Pixma MX410 All-In-One Printer
I can not hook up from my laptop for Remote printing on my wirless network to my cannon MP 830 it use to before I shifted cable companines. Also can not hook my laptop manually to NEW SAMSUNG TV it is a...
Good day! Sorry for this late reply as we have been experiencing typhoon in our area and we had lost power for 3 days.
Connecting Canon MP830 to your wireless network to be able to do wireless printing.
The best thing to do is to uninstall your current printer drivers, download the latest drivers from Canon support site then install it.
Step1. Uninstall the current printer drivers:
  • Click on START.
  • Click on Control Panel.
  • Control Panel Window will open.
  • Make sure the Control Panel Window is in Category View.
  • Click on Uninstall a program under Programs.
  • Scroll down and look for program/s relating to your Canon Printer, uninstall all of them if there are more than one.
  • Double click to uninstall.
  • Follow the instructions if it has one.
  • After uninstallation, the program will be removed from the list
Step 2. Download and install the latest driver:
  • Click >>HERE<< to go to the download page.
  • On the download page, select your OS (Operating System)
  • Click on Drivers after you select your OS.
  • Now, download and install the driver.
  • Double click the downloaded file to start the installation if it does not start automatically.
  • Follow the instructions during installation.
Hooking up laptop to New Samsung TV 7000 Series.
I need to know what kind of cable are you using to hook up the TV to your laptop?
Sep 25, 2011 | HP Office Equipment & Supplies
Hi everytime I try to scan something my computer
Please follow the link to uninstall and reinstall the drivers for your device.
Installing Devices on PCs and Laptops
Mar 22, 2010 | Canon Pixma MP480 All-In-One InkJet...
I have a cannon 160 printer but when I click on it, the screen to ask about scanning or print doesn't show.
I have a mp470. Try this before the driver download. Click Start, click all programs, select Canon utilities, select mp navigator, click on mp navigator again. On my pc this opens a window where I can select Scan/import from the platen or from a memory card. If this does not work here is a link to Canon to get your drivers. Note: turn off and uninstall your MP160 before installing the new drivers. Select your operating system from the list and select your desired drivers.
I also have a mp470. Try this before the driver download. Click Start, click all programs, select Canon utilities, select mp navigator, click on mp navigator again. On my pc this opens a window where I can select Scan/import from the platen or from a memory card. If this does not work here is a link to Canon to get your drivers. Note: turn off and uninstall your MP470 before installing the new drivers. Select your operating system from the list and select your desired drivers.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=13368
Feb 16, 2010 | Office Equipment & Supplies
It seems that if i uninstall drivers and installation program i can get the scanner to work for a couple of scans. then the scanner seems to lock up and not work until i go through this process again. is...
Hi--
What you have to do is uninstall everything for the Canon MP....then turn off the printer...and UNPLUG the cable that connects the printer to your computer. Now re-install both the software and the drivers (go to the website to get an updated driver & software at www.canon.com). Now, once that is completed, turn the machine back on and plug in the cord that connects the printer to your computer (this is when it automatically downloads the driver needed for the software to work- MP navigator- and the scanner) Hope this helps.
Jul 18, 2009 | Canon Pixma MP500 All-In-One InkJet...
I need to download the software/Canon Pixma MP 240 series printer
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=2610&modelid=17161#DownloadDetailAct
go to this site and put in your operating system and you will get the drivers you require. I would uninstall the all of the older drivers reboot then install the new drivers. Remember not to connect your print to your computer until the new installing driver tell you to.
Hope this does the trick for you, good luck. Please leave a rating, thank you kindly
Apr 27, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Canon Pixma MX410 All-In-One Printer Logo
703 people viewed this question
old marine
old marine
