Question about Homelite Pressure Washer. 2700 psi 2.3 GPM Gas Pressure Washer
This is a machine wont start are a regular basis
This machine is two months old and has only started twice. Fresh gas is used, oil level good(freshly added) Instructions followed to the letter. First time started without a problem. Second time a few tries. 3RD AND 4TH TIME NOTHING
  • 41 Answers
Make sure there is spark on spark plug
Posted on Jul 23, 2013
Put in place for oiling machine
Difficult to advise without knowing the make/model.
First, consult your owner's manual. It will have directions on how and where to oil your machine. Oiling the machine in the wrong place could cause damage. Be sure to use fresh, good quality oil recommended for your sewing machine (NO WD-40, cooking oil, old stinky brown stuff in the can, household oil, motor oil). Apply only 1-2 drops each spot specified. Repeat every time you start a new project or every 6 months if the machine is not in regular use.
Sep 26, 2016 | Sewing Machines
Pfaff 297-1 sewing machine runs very slow.
Your machine appears to be mechanical, not computerized. If so, more than likely your machine needs a thorough cleaning and oiling.
Might be best to take it for a standard service.
If you have the patience and time, you can try fixing it yourself. Consult your owner's manual, clean as instructed, and using Fresh good quality sewing machine oil, apply 1-2 drops as directed.
Wheel on right side that controls the needle up and down is very tight...
In the future, be sure to clean and oil regularly (every 40 hours of sewing, every 6 months if not in use). Use ONLY fresh good quality sewing machine oil, applying 1-2 drops of oil each spot. Consult the owner's manual for instructions.
Dec 27, 2015 | Sewing Machines
Thehook assembly will not move when you turn wheel
Could be a multitude of issues depending on your machine make & model. If it is an older mechanical machine, it most likely seized due to lack of regular cleaning and oiling. Consult the owner's manual for maintenance instructions and use ONLY fresh good quality sewing machine oil & applying only 1-2 drops of oil each spot.
You can take it for the standard sewing machine checkup service.
If you have the patience and time, you can try fixing it yourself:
http://www.fixya.com/support/t25934410-wheel_right_side_controls_needle_up_down
Dec 24, 2015 | Sewing Machines
Lawn mower instructions why wont it work
check for spark at plug if spark at plug then squirt some starting starting fluid in carb see if will start it should run long enough to burn out starting fluid if does check for water in gas if is drain tank and carb bowl put in fresh gas not and repeat not old gas you were using strat lawn mower if still dosnt start rebuild carb and add and additive called seafoam to the gas this is good stuff follow instrution on bottle
Sep 02, 2014 | Garden
11 hp 5700 watt generator wont fire
If you could not start in spite of oil and gas change, checked gas supply, spark plug, ignition cables and coils (magnetos) and so on whitout success, then try this:
Your generator has a low oil level protection, which stops the ignition of the motor.
After "a couple of years" sitting without or with old oil, the level switch may have got lazy or stuck down.
If your oil level seems to be good, while measured, find the oil switch and try to shorten or disconnect it.
If you succeed in running the generator change or repair the oil switch.
I hope that this will be helpful, because I don't have your device in front of me, but some people rank such an answer with 2 thumbs, which means useless. Better dont rank.
Jul 22, 2010 | McCulloch FG6000MK 5700Watt 13 HP 338CC...
Havent started my bike in 6 months all the lights work but wont start and yes it has gas
is it fresh gas or what was left in the tank when you last used the machine if it is the later drain the fuel & fill whith fresh fuel clean Or better still replace the plugs also after being laid up for six months the oil willhave started to go tar like I recomend you change it let me know how you get on.Geoff
Apr 16, 2010 | 2000 Harley Davidson XL 1200 C Sportster...
My 2year old toro 6.0 lawn mower wont work i just took it out from the shed, it was in there during the winter and now wont work. it worked perfect before why is this not working someone told me its debris...
did you burn all the gas out at the end of year last year if not bad gas will leave deposits in the carburator.here is a simple sugestion drain any gas out of it thats in it .put fresh gas in it and 2 table spoons of marvel mystery oil in gas tank you can get it at any auto parts store crank it untill you are sure fresh gas oil mixture is in intake wait an hour and let the fresh gas\oil mix do the work.pull plug dip it in fresh gas put plug back in and try to start it this often works if it dont you could have leaves .dirt .rust .or debris on surface of flywheel ,or a bad sheer pin on flywheel the sheer pin is whar times the engine on most small engines good luck i hope these sugestions help
Apr 29, 2009 | Toro Lawn Mower With Toro Power Tools
Chain saw starts with starting fluid only but will not run.
Hi lwhssh:
Suggest you drain the fresh gas/oil and add a fresh batch but first add a gas stabilizer to your batch of gas/oil in the storage container. You will probably still need to use starting fluid for a few times When 2 cycle engines sit for a long period of time, the gas/oil mixture undergoes a change and tends to leave a residue on the delicate parts of the carb. The gas stabilizer will help that.
I always do the following for 2 cycle engines when I put them up for the winter. Empty the gas container on the device and then start it to use up any gas left in the fuel lines and carb. this keeps any residue from forming.
Hope this helps Good luck Loringh PS please leave a rating if appropriate. Thanks
Nov 28, 2008 | Garden
Homelite Pressure Washer. 2700 psi 2.3 GPM Gas Pressure Washer Logo
407 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
