Question about Venturer STS-35S System
Manual the door wont open
How do i fix my drivers door it wont open inside/outside?
Very difficult to do. They sell jimmy kits that can be used through the window trim to get the door to unlatch. A locksmith will probably be able to open it for you or try to get the inside door panel off and manually open door using linkage inside of door.
Feb 27, 2015 | 2006 Mazda 6
Why wont Audi A6 2010 drivers door not open with remote yet all other doors open , only opens with key
Check your owner manual and go to the unlock section, you may be able to change the settings of your choice.
Aug 05, 2014 | 2010 Audi A6 2.0
98 accord door handle broke door will not open
A non electric door, (which?) wont open,lock works ok, handle wont open the door.
What can I do to fix it.
well telling the door to us would help, and options.
so no electric locks,
there are 2 levers. one inside and one outside.
so you pull the door card (inside door covering)
and look at both locks , the inside pull, its it working?
then look at the key lock cylinder. is it connected still
and last are both connected to the latch mechanism.
one can cycle this latch lever inside the door shell.
if that fails the latch is busted.
all this is covered in the FSM ,why not read it.? (under body)
free , too.
http://hondatech.info/downloads/Auto/Manuals/Accord/
Nov 25, 2013 | Honda Accord Cars & Trucks
Rear door wont open on 2000 gmc savanna
sounds like your lock rod clip broke, have to remove door panel inside and release it to open then repair lockrod
Nov 27, 2012 | 1997 GMC Safari
Driver's side door latch wont open door from inside
Go to http://www.hmaservice.com/ and register (vehicle by VIN). Afterward, you'll have access to technical information (manuals, wiring diagrams, service bulletins, etc) about your vehicle.
Jul 16, 2009 | 2003 Hyundai Tiburon
How can i open nissan primera's door,
i have Nissan Primera s manual,03 reg. Battery went dead two days ago, today i tried to open the car with my remote key, it didn't respond as battery was totally dead. I tried to open the door manually with the key,it wont open. Can any one help me please.....?
Nov 12, 2008 | 2002 Nissan Maxima
My doors wont open
disconnect the bonnet switch under the hood behind the right headlight .should stop the alarm.let me know how you get on with this.will the doors open manually with key in door.or they wont open with remote as you did not specify
Oct 12, 2008 | 1998 Ford Escort
LCD door wont open when you push the power on button. Have to open it manually.
Sorry runnigdeer but you always have to open it manually! it's not all automatic this thing!!
Nov 26, 2007 | Jazz DV-169 Digital Camera
Venturer STS-35S System Logo
Top Venturer Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Are you a Venturer Audio Player and Recorder Expert? Answer questions, earn points and help others
