Question about Clothing Accessories
Brother pr620 embroidery machine
The machine grinds, then throws the frame off center. How do I fix this?
  • 4 Answers
SOURCE: Using a Brother ULT 2003
The solution is to take it to an authorized Brother dealer. It sounds like either something wrong with your embroidery hoop sensors, or more likely something is wrong with the brain of your sewing machine. Hopefully after all this time you've done just that. I'd hate to think of a ULT just sitting around collecting dust.
Posted on Nov 22, 2008
talk2ginny
  • 34 Answers
SOURCE: can I transfer a pattern from brother 4000d machine to usb
Welcome to Fix Ya!
Are you trying to transfer a built-in pattern from your machine to a USB flash drive? I'm not sure if built-in designs can be transferred in their original form. You might try editing the design a bit, save it to a memory space, then save it to the memory stick. If you have a manual, it should describe how to move designs from your embroidery machine to your computer, and vice versa.
If you are other readers have time to rate my answer, you'll help me become a better expert. If you can give me more specific information about what happens when you try to upload a design from your machine, and whether you have a manual feel free to leave a comment and I'll check back with you.   Cheers, Ginny
Ch
Posted on Feb 12, 2009
SOURCE: oiling Brother Ultima 2001 sewing/embroidery machine
The only place you can opil an ultim is inside the bobbin case and around the bushings in the front end. Do a search for Anns fix it and you will find more than you will ever need for these machines
Posted on Nov 08, 2009
SOURCE: brother embroidery machine broken
Mine was doing the same thing, it wasn't threading right. The thing that pulls the thread down to the needle was out of place, and it wasn't wrapping the thread around the tension. Hope this helps!
Posted on Feb 19, 2010
chrismyers67
  • 53 Answers
SOURCE: cotton breaks on Brother Embroidery Galaxie 2100 machine
Try turning down your top tension setting a bit. If its at 4 or 5, i would turn it down to about 3 ish. Cotton thread is more brittle than polyester and rayon thread.
Hope that helps :)
Chris
Posted on Jun 06, 2010
Need a part for embroidery frame
Would probably be best to contact the maker of the embroidery frame for parts.
A dealer or repair shop may be able to order what you need.
Jan 03, 2016 | Brother Sewing Machines
Can you show a diagram for threading the PR 650 Brother embroidery machine
Have you tried looking on www.youtube.com ? There may be a video there, OR, try the Brother website.
Feb 10, 2015 | Brother Entrepreneur Pr 650 Embroidery...
Embroidery problem
Hai, 1.You should thick and white or blank cover run a letters embroiderys. 2. After don't remove the frame. 3. Put on the embroidery cloth. 4.Marking. 5.Frame setting with smooth needles. 6.Put the frame. 7.Trace the machine after running and finshed the design.
Mar 23, 2014 | Brother SE400 Computerized Sewing and...
The machine is moving my design over approx. 1.5 inches before it begins to embroider. The design looks correct on the screen and the appropriate hoop is lit up. Help!!!
by default the machine always start with the hoop centered so make sure you have the center of your design in the center of the hoop then when your machine starts it will move the spot where the digitizer started the design. If you do this and hoop size is correct it should stich out fine. you can use this link to download the manual.
User Guide Manuals PR 650 650C United States Brother
Aug 31, 2013 | Brother Entrepreneur Pr 650 Embroidery...
I have a Brother PC-8200 embroidery sewing machine. Last week I had done some embroidering then changed to straight sewing but couldn't get the tension to adjust. Took it in for repairs, and the...
That's a tough call, parts can be pretty high to fix a machine. Have looked around to price out a new embroidery machine, Janome makes some very nice one in that price range. I'd try ebay there is one which is missing the foot control and hoops for $250.00 just search Brother Pacesetter PC-8200 this may be the ticket you already have the foot control and hoops.
Best of luck
Jan 29, 2011 | Brother Disney PE-400D Computerized Sewing...
I have a Brother Ult 2001 and I was right in the middle of monogramming a towel using the large frame when I ran out of bobbin. I took the frame out and changed the bobbin and when I returned the frame to...
My friend just had this problem a couple weeks ago. Here's what we did. We cleaned the bobbin case with canned air lightly. We turned the machine off and disconnected the embroidery unit. Turned the machine on without the embroidery unit and ran a straight stitch. Then we turned it off, reattached the embroidery unit and touched another design of a different size. Attached the hoop without fabric just to see if it would "take it" and it did so we put the right size hoop back on and selected the design we were on originally and it worked. Some times these machines are just "touchy" and don't let you do something and after a "rest" they're ok. I hope this works for you.
Aug 24, 2010 | Brother Sewing Machines
Machine not sensing embroidery frame
Depending on your model of machine this problem is solved by replacing the hoop attachment unit on the hooping arm. (hoop sensor cable is not properly welded)
Jan 14, 2010 | Brother Sewing Machines
Using a Brother ULT 2003 embroidery machine. In the middle of embroidey design if I stop machine the button to restart the machine stays red and I get the msg to "attach the embroidery frame"...
Sep 04, 2008 | Brother ULT2001
Clothing Accessories Logo
95 people viewed this question
Top Clothing Accessories Experts
Da Doc
Tom Chichester
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
