Question about Acer Aspire E380 ASE380-UD500A PC Desktop
Motherboard connectors Recently purchased the motherboard from an E380 and am trying to install it in my case. The connectors for the power switch, reset switch HD LED and power LED are not labeled on the board. All I see is a section labeled front panel. Does anyone know which pins are which? Thanks
  • 349 Answers
SOURCE: Pin settings for Acer Veriton 5600g motherboard
go to this site download vt5600.pdf file when downloaded sellect point 4 upgrading you computer,\system boards\mainboard layout\veriton 5600g mainboard layout.
http://www.acerpanam.com/synapse/data/7117/documents/vt5600.pdf
good luck
terry
Posted on Feb 20, 2008
leecom72
  • 4806 Answers
SOURCE: mismatch connection,plug vs pin after swithing motherboard
Hi there.
On the motherboard look for the front panel, it should be marked PWR and coloured green, also the plug that connects to it should be marked PWR_SW.
Have a look at these pictures for an idea >>>>>>
Good luck and thanks for using FixYa!!
Posted on May 19, 2009
tbirdfan1
  • 3051 Answers
SOURCE: acer motherboard diagram needed
hello there here is a weblink that will get you going in the right direction
i know you have the acer motherboard but the pins will generally be the same ok?
here is a pdf downloadable flile that will help you.
best regards michael
  1. [PDF] A7V133-VM3051k - Adobe PDF2.gif - View as htmlSupports Socket A-based AMD. Athlon™/Duron™ processors. North Bridge ... p.37 System Power LED Lead (3 pin) 22) RESET (PANEL) p.37 Reset Switch Lead (2 pin) ...dlsvr03.asus.com/pub/ASUS/mb/socka/km133a/a7v133-vm/e698_A7V133-VM.pdf
Posted on Sep 16, 2009
  • 508 Answers
SOURCE: I am about to switch out the motherboard for m5640 aspire 1
New motherboard will have a picture of the pin connections and where they connect on the motherboard. Just follow these connections, also the wires leading from the from the front of the case to the motherboard are labelled as to what they connect to. As a final note, the white wire on the connectors is usually always the ground wire, so look at the drawing carefully to see which side is the positive and make sure that the coloured wire goes to the positive side not the white.
AS ALWAYS INFORMATION IS FOR EDUCATIONAL PURPPOSES ONLY AND WHAT YOU DO WITH IT IS UP TO YOU.
Posted on Jan 14, 2010
  • 17 Answers
SOURCE: I have a Reclaimed motherboard G45T-AM2 and have
google the brand name of the motherboard and add the words front panel connections to motherboard.
Posted on May 11, 2010
Trying to install an ASUS H81M-C Mainboard with Intel core i5-4460. No way to turn on. Mainboard's Power led is on. Nothing happens at all. All connections are OK. Anyone has an idea? Thanks.
When you say that all connections are ok, you understand that we have to verify as this is the most common problem that occurs when installing motherboards. Obviously you have the large connector from the power supply plugged in since you have the power led on the motherboard. This is good. There is also the ATX 12V CPU 4-pin power connector that must be connected just above and to the left of the CPU. But the most often messed up arrangement are the front panel connections to the motherboard at the lower right corner. This is a 9-pin connector block (actually 10, but top right corner pin not there and bottom right not used).
In the link attached, go to page 26 of the pdf, which is page 1-18 of the manual. At the top of the page is a drawing of the connector block. The green power led takes the first two pins in the top row from the left. The connector plug should have a green and a white wire. The green is the positive and goes on the left pin of the pair.
Right below that is the two pins for the HDD light. This plug should have red and white wires. The red wire is positive and goes to the left pin of the pair. Going back to the top, the power button is the remaining two pins. These wires can vary in color from case to case, but if you don't see a label, just follow them back to the power switch to figure out which pair they are. This connector can be installed either way, there is no fixed polarity. The remaining two pins are for the reset switch, which some cases have and some don't. This connection does not to be used.
If you have everything correct and the unit still won't power up, then you need to verify that the power switch is working. If you have a reset switch, it is easy to test, just switch the reset and power button connectors and press and release the reset button and see if the board powers up. If you don't have a reset switch, remove the connector from the power button pins and carefully short them together for a brief second, which simulates pressing the power button. If it still doesn't power up, then there is something wrong with the motherboard.
One last thing, if the front panel connectors are all installed into one plug (which some manufacturers like DELL does, and you are installing this motherboard into their case, be sure to verify that the wires on the connector goes to the appropriate front panel switches/indicators, as these connector blocks are not fully standardized.
Nov 23, 2015 | Intel Computers & Internet
Power supply diagram for ht 2000 motherboard
http://www.ebay.com/itm/ECS-HT2000-AMD-AM2-Socket-mATX-DDR2-800-Motherboad-w-NVidia-Graphics-/251260314586?pt=Motherboards&hash=item3a804823da
1) Uses one 24-pin ATX main power cable.
Motherboard installed in computer case, the motherboard connector for the 24-pin ATX main power cable; is to the Right of the Blue IDE (PATA) connector.
(Right side of motherboard)
General example. Note that color does NOT matter of connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
2) Uses one 4-pin ATX +12 Volt power cable,
Motherboard installed in computer case, the whitish square 4-socket hole connector, to the Bottom/Left corner of the Processor socket; is the 4-pin ATX +12 Volt power cable's motherboard connector.
General example. Note color does NOT matter of connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
THAT, would be considered a Power Supply diagram of the motherboard.
They are the only two power cables that plug into the motherboard.
The front of your desktop computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.
Power On switch, Power On LED, (Light Emitting Diode), Harddrive activity LED, and a Reset switch IF used.
Regards,
joecoolvette
Apr 15, 2013 | ECS HP MCP61PM-HM Nettle3-GL8E 6150SE AM2...
Good Afternoon, I have a Dell Xps 420, I replaced the PSU with a 500 W Rocket, still the solid amber light. I then replaced the motherboard with a brand new motherboard from Dell, still the amber...
Here are some ideas for you to try.
1. Make sure your motherboard is up on motherboard standoff screws so that it isn't directly touching the case. Follow this link if you don't know what a motherboard standoff looks like: http://www.mountainmods.com/brass-motherboard-standoff-10-pack-p-203.html
2. Unplug all peripherals including RAM, video card, hard drives etc.
3. Make sure both the power supply's ATX 20/24 pin connector is plugged in to the motherboard along with the ATX 12V connector.
4. Make sure the power connector, reset switch, and pc speakers are installed into the motherboard correctly. If the power connector is installed incorrectly the PC will not boot up. Look at p.103 of the motherboard manual. The power connector is located at label 5.
5. If you are hearing any beeps after you press the power button post that information and if you're seeing any lights on the top bezel please post that information as well.
6. Either switch out the power supply or buy a power supply tester to make sure the power supply is good. They only cost $20 or so if you buy one from Newegg or Tiger Direct.
7. Make sure the processor fan is plugged into the motherboard.
Hope these ideas can provide a breakthrough for you.
Good luck and thanks for using FixYa.
Mar 02, 2011 | Dell XPS 420 PC Desktop
There is no power switch on the enhance atx 1123b that I have . What actually powers it up?
Just about every power supply I've owned doesn't have a power switch. The power supply is turned on by one of the wires in the 24 pin connector. According to this it looks to be pin 16 and how to turn it on:
"Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF."
Hope this helps
Ray
Mar 01, 2011 | Enhance Technology ATX-1123B, Enhance...
Get no power with intel d875pbz in rosewill tu155 case
You don't have the power switch connected where it belongs. There's one set of pins where all the front panel connections go. This information is from the manual for this board, available from Intel here.
Hope it helps. Thanks for using Fixya!
Feb 12, 2010 | Intel D875PBZ Motherboard
Comp. does'nt turn on. power is good
Your question fails to provide sufficient information.
.."doesn;t turn on power good...."
do any lights on the pc illuminate
was it working before, and did it close down correctly
has it possibly been hit by lightning
have you recently opened the case to install new hardware?
Possible causes of a failed power up.
dead power supply
a video card not seated in its slot correctly
dud motherboard
motherboard installed incorrectly
no Bios battery on motherboard
faulty wall switch
faulty power pack switch
no ram installed
and on and on
thanks for using FIXYA
Oct 10, 2009 | Intel Motherboard
M2N MX SE Plus Motherboard
Read the labels for the connectors on the motherboard.
Polarity does not matter for the POWER and RESET buttons.
If the lamps for AC-POWER or HARD-DRIVE-ACTIVITY do not light-up when you expect them, then reverse the connector.
Try the PC SPEAKER connection one way, and then shutdown
the computer, reserve the connection, and start the computer.
If the "beep" at start-up is better, leave it as-is.
If the "beep" does not happen, or is quieter/distorted, reverse the connector.
May 21, 2009 | Ultra Products Ultra M923 Full Tower ATX...
My motherboard can't turn on and me had changed power supply with new one.Can you help me how to check power on motherboard.Thank you. I bought a new case for my ATX motherboard. I installed the power...
the chances are that the power supply is not enough for the motherboard. or the main power connector has only 20 pins. the newer version of motherboards requier 24 pin power connector.
Mar 24, 2009 | Computers & Internet
Help no power
This is a typically problem when you don't have the motherboard proerly seated. Some part of the board must be touching the metal contacts when you screw down the board to the case which causes a short. Try to reseat the motherboard and also make sure you're using washers in between where you screw down the motherboard to the case. That should fix your issue (Unless there's something wrong with the motherboard all-together).
Oct 05, 2006 | A-Top Alien Gaming ATX Case
Acer Aspire  E380 ASE380-UD500A PC Desktop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
