Question about Beko DFN1000X Dishwasher
Settings i dont get the setting purpose and dont understand it what does the settings do cuz my washer takes 2 hours for a small amount of disher
    Master:
  • 966 Answers
Settings should show you how the machine is to function. Do uou have a manual?
Posted on Jul 24, 2013
Someting changed my english language on Facebook to something I dont understand. How do i change it back and block the thing that did it without my consent
First make sure it is not the browser setting.
Language:
on very right in the blue bar click the little arrow, click the 4. option counted from the bottom, click on the second option on the bottom the link on the right
change the password of the account when you are done, use a long one and don't tell anybody.
Mar 15, 2015 | Facebook Computers & Internet
I have inherited a west bend slow cooker model 84624 and dont have a manuel for it. I am concerned with the 300 watt is this normal? Or is that very low? I dont know how long to cook in this or amounts...
  • 1 Use setting 1 (warm #1) only to warm rolls and muffins. At 140 degrees Fahrenheit, this setting should not be used for cooking.
  • 2 Use setting 2 (warm #2) to keep cooked foods warm until they're ready to be served.
  • 3 Use settings 3, 4 and 5 (low, medium high) for cooking. The setting you choose determines the length of time the food will cook. A typical meal with meat and vegetables needs 7 to 10 hours to cook at the low or #3 setting, 4 to 6 hours at the medium or #4 setting, and 2 to 3 hours at the high or #5 setting.
  • All West Bend slow cooker models eventually simmer at the boiling point, or 212 degrees. The setting simply determines how quickly the cooker will reach that temperature.
    300 watt is not a huge consumption of electricity, depending of course on, how often, how long and how high temperature.
    Regards
    Sep 28, 2011 | West Bend 84624
    I have model fs-2919 would like to know what the other dials are for i dont have the booklet thanks for your help
    The three small dials on this watch are all part of a "stopwatch" system. The small dial at the 12 o'clock is for tenths of a second( each half circle completed is one second or 1 whole rotation equals 2 seconds.) the small dial at the 6 o'clock counts a full 60 seconds for each revolution, and the dial at the 9 o'clock counts minutes(one full circle equaling an hour.) when the stop watch is started the 12 o'clock and 6 o'clock dials will start at the same time. you will notice that every half turn on the top dial equals one "tick" on the bottom dial. After the first minute of timing the top dial will stop ticking as it is for more precise timing of things that take less than 1 minute. each full rotation of the bottom dial will then equate to one "tick" of the 9 o'clock dial. hence the three dials counting tenths of a second, seconds and minutes. the setting of these dials is fairly easy once you understand the purpose. on the side of the watch there are two buttons(one top and one bottom) with a setting wheel in the center. When in use the top button starts and stops the stopwatch and the bottom button resets the counters. To set the watch simply pull the center wheel away from the watch all the way(2 clicks) set your minute hand and hour hand and then tap the bottom button repeatedly until the small dials all line up straight up. once that is done push the center wheel button halfway into the watch or one click to set the date. then simply push the wheel the rest of the way in and voila!!! hope this answers some questions
    Apr 05, 2011 | Fossil FS2919 Wrist Watch
    Inside of washer smells bad!!
    Your smell is inside the washer under the cabinet. You must take the cabinet apart and thoroughly clean it. You must have a small leak that has been going on for sometime now for the moister has mildewed. Lysol will kill the smell on this although it must be cleaned first of all
    Apr 28, 2010 | Amana NTW4500V Washer
    Morphy richards electric blanket --how to use it
    the 0 and 3 settings are to set it to come on in 3 hours (0 being off). the 1,3,12 settings are for it to turn off automatically after that amount of hours. I can remember what the 1/2 button in middle is for.
    Jan 27, 2010 | Heating & Cooling
    Setting the onboard clock?
    Turn main switch on (key).
    Push both buttons on the dashboard until the hour indicator starts to blink.
    Use one of the 2 buttons to set the time and the other one as "enter".Then the minutes will start to blink.Same procedure and by pressing the "enter" button it will exit from the hour adjusting mode.
    Jun 18, 2009 | 2008 Yamaha XT 660 R
    Water does not drain from the bottom. I understand that a small amount is normal, however, this is not a small amount. Thanks for your help.
    It worked for me .I have a danby countertop dishwasher.
    I took off the metal top
    I looked under on the left side to find the pump
    I took both hoses off the pump and took off the little fan.
    i took off the little metal bracket behing the little fan. and unscrewed the little pump to take it out.
    the little metal piece that the fan was on wouldn't even move.So i sprayed it down with wd and it started moveing again then a screw fell out.so i found where it went(inside the motor which the fan and metal piece move) got the tweezers and replced it. oiled it some more and put it all back together. Perfect.
    May 24, 2009 | Danby 22 in. DDW396 Free-standing...
    A leak under the washer. model Splendide wd802
    well there is a seal between the tub of the washer and the transmissition you cant see it utill you take it apart so just fill the tub with water and dont let the pumps or motors run if you are getting water from around the transmition that is your problem i have a maytag and that gasket cost just under 70 bucks so much cheaper than buying new washer
    Mar 31, 2009 | Washing Machines
    Bimmis repair
    the small seal set on top of the large seal in the tub, lubercate the seal with some dish washing liquid and slide it down the agaitator shaft the brass side goes facing down
    Apr 23, 2008 | Frigidaire CWS3600AS Top Load Washer
    Dishwashwer not cleaning properly
    You can try one of the cleaners sold for this purpose like glisten, dishwasher magic or jetdry dishwasher cleaner. It may not be getting enough water due to the fill valve clogging up. You can check this by small amounts of water slowly with a cup in the wash cycle and quickly opening the door to see if the upper sprayarm is turning. If more water helps you need to replace the valve.
    Apr 18, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
    Beko DFN1000X Dishwasher Logo
    59 people viewed this question
    Top Beko Dishwashers Experts
    Shekar Avadhani
    Eric Taylor
    Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
