Question about Waterway Champion 1 1/2 Hp 230v Energy Efficient Pump
Waterway pump not priming
I have a waterway frame 56 that is cavitating. I have checked ALL the seals and connections on the suction side. The Impeller is spinning freeley, I have used a drain jet and the skimmer lines do not seem plugged ( waterflow looks pretty good ) When the pump starts it will not prime, and the water coming in from the inlet is really foamy, If I shake a bottle of water it gets really foamy, we have not used a foaming algecide, the only thing we have done different is to add calcium ( at the suggestion of Leslies Pools employees ) we have a vinly liner with a clearly caribean system so there is no chlorine, and we have never had calcium in the pool before. Speaking with the folks at leslies was not helpful, I was told that even if there is something in the pool ( like calcium that will cause foaming ) that it will not cause a priming issue
  • tony corbett Jul 24, 2013
    One more thing, we also just installed a generic cartridge, could this cause the priming issue I have described?
  • 372 Answers
Foam will definitely keep a pump from priming. Why do you think it's the calcium causing the foam? I have added large amounts of calcium to pools and I do not recall ever having any foaming issues.
Check to see if your impeller may be clogged. Take the lid off of the pump and fill the basket up with water. Leaving the lid off, start the pump for three seconds and then turn it off. The water should be sucked away almost instantly. If the water level drops slowly you have debris clogging the impeller. If that is the case the pump needs to be opened and cleaned.
Posted on Jul 24, 2013
Testimonial: "Thank you for confirming the foam issue, The reason we think its the calcium is that its the only new thing in the equation. I have have done as suggested and the water was sucked out of the pump instantly, "
3 Suggested Answers
  • 990 Answers
SOURCE: Installing seal kit on hot tub waterway pump and
I can't say for sure if it is on your model and I don't rember where it is located. But some of these had impellors that had a allen screw that locked it to the shaft. I know this is not much help but I hope it helps.
Posted on May 10, 2010
MOTORWIZJ
  • 1343 Answers
SOURCE: Describe your champion waterway
SOUNDS LIKE YOU HAVE A SUCTION LEAK , CHANGE SHAFT SEAL AND WHEN YOU START PUMP RELIEVE AIR OFF OF FILTER. THIS HELPS PUMP PRIME FASTER
Posted on May 25, 2010
What is the flow rate (GPM) of an Executive 56 Waterway pump Model PF-50-2N22F?
Waterway Executive 56 Spa Pump, 5 HP, 230V
Waterway Executive 56 Frame spa pump wet end
assembled to a 56 frame, 5hp, 2-speed 230V spa motor
This Spa pump has a 2-1/2 inch intake and a 2 inch discharge for plumbing
(but measures 3-1/2 inch and 3 inch- see bottom of this page)Manufacturer Part No. 3722021-13 Other Part No. PF-50-2N22C
Features:
  • Executive spa pump wet end designed specifically for 56-frame spa motors
  • Two double shielded ball bearings with moisture resistant grease for quieter operation and longer life
  • Two speed spa motors have four sets of insulated windings for increased efficiency
  • 56 frame spa motor for added strength, cooler operating temperature and longer motor life
  • Large 2-1/2 inch intake for improved flow performance and reduced noise
  • Large 6-1/2" diameter wet end for higher head pressure
  • Split capacitor, (start and run) for less energy consumption
  • Thermally protected to extend life expectancy of hot tub motor
  • Highly versatile wet end can be rotated every 90 degrees
  • Viton seals
  • Three year manufacture's warranty on spa motor and spa pump wet end
Jun 05, 2015 | Waterway Garden
Prime
Hi to prime your pump you fill the strainer basket with water and make sure all connections are tight with no leaks. Once you seal the lid turn on your pump and it should prime. If you have an issue you can force water through the suction line by putting a hose in the skimmer and force the water through your suction line. Time to Open the Swimming Pool
Jun 06, 2013 | Waterway 1 HP HiFlo Above Ground Pool Pump
Need to change seal on pf-40 waterway pump
can change but water leaking into motor it will start to squeal bad bearing just change whole pump
Dec 26, 2012 | Waterway 5HP Executive 56 Frame Spa Pump...
I have a waterway mustang 56 pump. Pump just hums but does not start up.
check the capasitor under the small cover on top of the motor look for bad wire or swelling anywhere on the capasitor the motor will not start if it is bad
Aug 31, 2010 | Waterway Spa Pump Executive 56 Frame 4hp...
Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge : My Executive 56 spa pump (1-l/2 years old) is leak...
Thank you for posting your question here on Fixya.com.
There is a seal in there that a local pump repair shop can fix for about $30 - $50 with parts and labor. Waterway pumps use a 1000 seal that is not a seal the homeowner is usually successful at replacing themselves.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
May 18, 2010 | Waterway Spa Pump Executive 56 Frame 4hp...
Is any one else out ther with a Waterways 56 pump replacing them every 3 years also?
The UK versions of the Waterway pumps seem to be very reliable. The only known issue is with the Run/Start capacitors which tend to fail but they're easily replaced.
Over the years I've heard of many pumps being changed unnecessarily.
Regards,
Ian.
http://hottub.synthasite.com
Jan 31, 2010 | Waterway Spa Pump Executive 56 Frame 4hp...
How do i remove impellor
The impeller in my 4 HP, 2-speed Waterway Executive High Performance 56 pool & spa pump has a brass coupling embedded in the back side. This coupling can be unscrewed from the motor shaft by keeping the shaft from rotating while turning the impeller in the reverse direction. Then the seal can be tapped out.
Oct 08, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
REASSEMBLED WET END OF WATERWAY PF401A22C-LEAKS- NEED DIAGRAM
I've never seen a reassembly diagram for this particular pump but I'm guessing that you've installed the mechanical seal incorrectly.
Where is it leaking from exactly?
Kind Regards,
Ian Kime.
Apr 03, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
Waterway Champion 1 1/2 Hp  230v Energy Efficient Pump Logo
89 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ian Kime
Ian Kime
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
