Coleman electric furnace
I have a coleman evcon furnance/ac unit. the unit is not coming on. I replaced the thermostat still nothing. Replaced the indoor blower relay and capcitor still nothing. replaced the outdoor unit dual relay still nothing. When I push to activate at the outdoor unit contactor the unit outside runs and the coils inside cool but still no blower.
  • grong Jul 24, 2013
    I did remove the blower from the system tested the blower and it works on all speeds. I checked the voltage at the thermostat and only get 2.6 MV. Now I am thinking it could be the transformer. Any thoughts.
    Top Expert:
  • Heating & Co... Master
  • 34,255 Answers
You don't say whether you replaced the blower but that could be the next thing to check
Posted on Jul 23, 2013
Testimonial: "Did not replace the blower but did check it outside of the system and it works fine on all speeds. Only getting 2.6 MV at the thermostat. Wondering if I could have a bad transformer."
  • 49 Answers
SOURCE: Intertherm E1EH-015HA FURNACE no heat
Sounds like a downflow electric furnace? If so it sounds like you have 15kw worth of electric heat, you might have a defective heating sequencer, witch is what they call a dual on one plate.
Posted on Nov 28, 2007
ngafm
  • 166 Answers
SOURCE: coleman mobile home electric furnace
Peace,
It seems you need hands on servicethis time !
ngafm
Bless You,
Please leave me a rating before you sign off!
Thank You
Posted on Sep 07, 2008
  • 38 Answers
SOURCE: outside carrier unit doesn't come on when thermestat on cool
The board is bad, what you can do is splice into the common (blue) and Yellow t-stat wires and connect them directly into the contactor and hopefully the reversing valve engages, giving you cooling for the time being
Posted on May 18, 2009
james3751
  • 614 Answers
SOURCE: squirell cage blower motor runs all the time
Relay. You may just have it wires wrong but relays are easy to replace. Rus
Posted on Jun 14, 2009
  • 415 Answers
SOURCE: AC unit outdoor fan motor does not come on as it
It sounds like the contacts of the contactor are burnt/pitted. When this occurs, it can allow enough current to operate the fan motor but not enough to operate the compressor.
Posted on Apr 07, 2010
When i turn up the thermostat the furnance doesnt come on
have you replaced the board? Need more info. Have 120 volt power? check small fuse in board. Make sure blower door is closed, it has a cutoff switch.
Sep 29, 2014 | Coleman 7990-319p Evcon Gas Furnace...
Coleman Evcon furnace. Can i make it circulate air?
Your thermostat should have a "continuous blower" setting. Use that instead of fooling around with the A/C setting
Jul 17, 2013 | Coleman 7990-319p Evcon Gas Furnace...
I have a Coleman Evcon Elec Furnace with the added AC Unit. The blower works great with the AC but only on & off with the heat, what could this be?
Replace the sequencer...which is just a series of snap disc relays that are staged. The first snap disc should kick on the first element & low speed of blower. Depending on how many elements you have, determines how many snap discs are on the sequencer. It could be a 2,3,4, or 5 stack. Generally the coil is 24 volts.
Dec 01, 2012 | Coleman Evcon Furnace Control Circuit...
The thermostat clicks but the a/c won't turn on. I
You need to check the breaker for the A/C in the electrical panel, and have the fuses in the disconnect located near the A/C outdoor unit.
Apr 03, 2010 | Coleman Heating & Cooling
My furnance is acting up you turn it on it clicks on then lights the flame gets big then seconds later the flames go out and the blower kicks on what could be the problem ive had several people look at it...
If the fan takes too long to come on, the high temp limit may be opening. Could be a defective limit, hard to say without more info. Another possibility is a mis-adjusted heat anticipator. A normal setting would be around .45 amp. The heat anticipator is inside the cover of the thermostat (older, analog style). Good luck.
Nov 28, 2009 | Tools & Hardware - Others
I have an coleman evcon furnace when i turn a/c on the outside unit will run but the inside wont run
put the just the fan on turn off the ac and the heat and just fan on make sure the blower motor works cause thats really the only thing you utilize from the furnace in the summer and let me know
then if so does your heat work fine
May 30, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
