Question about Sony STR-DE898 Receiver
Reset sony receiver - Sony STR-DE898 Receiver
    Genius:
  • Sony Master
  • 1,054 Answers
Should just have to hold the power button
Posted on Jul 24, 2013
How do i reset a sony STR-K740P receiver??? - Sony Str-k740p Radio Receiver
Tuner reset
You can change the AM tuning scale to 9 KHz or 10 KHz. After tuning in any AM station turn off the receiver. Hold down the Preset tuning + and - ve together.
All preset stations will be erased when you change the tuning scale. To reset the scale to 10 kHz (or 9 kHz), repeat the procedure. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Dec 12, 2016 | Sony Audio Players & Recorders
My sony ericsson c902 hev probem to sending end receiv msg
Try performing a 'Master reset' to restore your phone settings back to default.
Select 'Menu' > then select 'Settings' > then select the 'General' tab > then select 'Master reset'.
You will then be asked to choose between 'Reset settings' or 'Reset all'.
'Reset settings' will restore your phone settings but will keep all of your personal data.
'Reset all' will DELETE all of your personal data and restore phone settings.
Try just 'Reset settings' first then try to send a message to yourself, this will test if your phone is able to send and receive messages. If messaging still won't work, try 'Reset all' then try to send another message.
If it still won't send or receive messages, I recommend you give call Sony Ericsson Customer Service a call, their worldwide phone number list can be found at:
http://www.sonyericsson.com/cws/corporate/common/contact/phonelist
Mar 11, 2011 | Sony Ericsson Cyber-shot C902 Cellular...
It is not possible to turn om my Sony STR-KS2300 AV receiver after tun it of. Switch on again is only possible when i pul out the mainplug and put it in again.
standby supply issues. weak 5 volt or currupted microprocessor. does the owner manual have any reset procedures (soft reset) .call sony customer service to check.
Feb 28, 2010 | Sony Audio Players & Recorders
Soon as i turn power on my sony receiver goes straight to protection mode can i disconect the fuse to reset it
Resetting probably won't fix it, Sounds like it needs output transistors and some resistors and/or fuses
Nov 28, 2009 | Sony STR-DE705 Receiver
Need to retune my sony digital receiver model vtx d800u cant retune need factory reset pin number
SONY VTX D800(U)
Full Reset (Also clears Pin)
LEFT
RIGHT
YELLOW
BLUE
MENU
Go to Technical Information
Go to Manufacturer Information
Press Red
Oct 01, 2009 | Sony Televison & Video
Sony str db870 master reset
If the power of the Receiver is ON, press Power to turn OFF the power. Then, hold down the MODE + button and press the Power button together.
S.F Intialize appears in the display and all sound fields are reset at once.
Sep 22, 2009 | Sony STR-DB870 Receiver
How to hard reset a sony str-DE898
I couldn't find anything about a Lock Code in the manual but here's the general setting-reset procedure:
Turn OFF the receiver
Hold down the I/0 for 5 seconds - "PUSH ENTER" appears on the display
Press ENTER
Apr 08, 2009 | Sony STR-DE898 Receiver
My sony v333es say protection panel power off
Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
  1. Check the speaker wires and speakers for proper connections.
  2. Reduce the volume level. IMPORTANT: If the receiver is played back at maximum volume level it may enter the protect mode. Maximum volume listening will cause the receiver to run very hot and may drain the output capacitors.
  3. Disable the surround sound option if both the A and B speakers are being used simultaneously.
  4. Ensure the top of the receiver has proper ventilation to keep it from overheating.
  5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Some receivers provide compatibility with the higher sampling frequencies through alternate connections. Consult the owners manual for specific information.
  6. Unplug the AC power cord for about 1 to 2 hours to reset the output transformers.
If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Dec 03, 2008 | Sony STR-V333ES 5.1 Channels Receiver
Not showing letest call(received,missed call,answered,dialed or all) history
I would try a master reset again and if that doesn't help. Try updating your phone's software with the Sony Ericsson update service....which is free.
Nov 03, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Sony STR-DE898 Receiver Logo
44 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
