Question about Lenovo G450 Notebook
SMART Failure Predicted on Hard Disk 0:ST9320325AS
3 Suggested Answers
  • 6771 Answers
SOURCE: smart failure predicted hard disk2:wds 1600bevs _ 08rst3_si
Smart gives indication of failure but can't give you a time frame, I would suggest backing up critical files as soon as possible since it could go at anytime.
Posted on May 16, 2012
jonsnell4
  • 23154 Answers
SOURCE: hard disk failure
Purchase a new hdd NOW! and copy your data off while it is still there. You may be lucky and be able to use CloneZilla to clone the failing hdd saving you hours of uploading drivers etc.
Posted on Feb 09, 2016
Hard disk failure
Feb 09, 2016 | Lenovo G550 Laptop
Smart failure predicted on hard disk repair
This means either your hard disk is about to fail or it already has in which case you will need to purchase a new HDD (hard disk drive) and then contact acer to purchase recovery disks or if it is still under warranty then contact for service.
Jul 19, 2014 | Acer Computers & Internet
How to resolve problems (smart failure predicted on hard disk 0 : toshiba MQ01ABD050 - (S1))
Copy all the data from the drive to another drive because this one is predicted to fail very soon. Format the drive. That might work, but unlikely since SMART is a hardware problem and format is more of a software driven solution. It has some elements of a hardware issue, but not enough to fix most SMART problems. A low level format might help, but that is not a DIY.
Jul 12, 2014 | Computers & Internet
Acer hard disk failure
Check this site linked here to get more details about the faults with hard disc to Acer, and replacement procedure to the same. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 11, 2013 | Computers & Internet
SMART Failure Predicted on Hard Disk 0: WDC WD3200BEVT-75ZCT2-(S1) WARNING: Immediately back-up your data and replace your hard disk drive. A failure may be imminent. Press F1 to Continue
just means its time to backup all your information, as if the hard drive does fail theres a good chance you may lose some or all of your information.
hard drives aint that expensive around 30 pounds +
and you can replace it with any sata hard drive.
Jun 17, 2012 | Western Digital Computers & Internet
Hard disk failure
try to remove hard disk and then again connect it
Oct 19, 2009 | Computers & Internet
Hard Disk Problem
That failure is predicted by the SMART reporting system. Its a status chip on the drive that reports to apps that can read the smart data from the hard drive. Its not always accurate but it usually is.
Time backup your data on that drive ASAP and then buy a new drive.
Sep 07, 2009 | Toshiba MK1637GSX 160 GB IDE Hard Drive
SMART failure predicted on hard disk 0:
There is a big problem with newer conponents and Win XP versions prior to SP2. Especially with newer motherboards.
You have to make a bootable SP2 disk if you don't already have one. To do this use the slipstream proceedure specified on the Ms website. Many other websites describe the process with easier language.
Slipstreaming is a common practice now. Essentially, you copy your original install disk to the c: drive then download SP2 to C: drive then download the slipstream utility from MS. Running the slipstream utility then inserts the proper drivers (ide and HD drivers too) into the licensed copy you have. You then create a bootable disk from the slipstreamed files you have.
This approach is resolving alot of blue STOP errors and SMART errors.
ALSO, you want to make sure you are installing any drivers provided by the MB manufacturer AND Drive maker.
Good Luck
Jul 29, 2009 | Computers & Internet
When you turn the computer on it says SMART Failer predicted on hard disk 0: HTS54108G9SA00-(S1)
S.M.A.R.T. (Self-Monitoring Analysis and Reporting Technology) is a diagnostic method originally developed by IBM that at that time referred to as "Predictive Failure Analysis". This technology was developed for IBM mainframe drives to give advanced warning of drive failures. Based on this diagnostic, Compaq announced IntelliSafeTM, which was submitted to the ATA/IDE standards committees and the resulting standard was named S.M.A.R.T.
S.M.A.R.T. analyzes many of the mechanical attributes; over time, some failures can be predicted by detecting if the hard disk drive is moving out of tolerance. While the S.M.A.R.T. technology can detect upcoming issues, not all hard drive failures are predictable.
All this means on most modern drives is the hard drive is coming close to the maximum tolerances
I usually switch off in the bios smart monitoring.
This system is trying to predict a possible failure, which may or may not occur..
Mar 30, 2008 | Computers & Internet
Error message at startup !!
SMART stands for Self-Monitoring, Analysis, and Reporting Technology.
If you want lots of details on what it is, and does, take a look at this link:
http://en.wikipedia.org/wiki/Self-Monitoring,_Analysis,_and_Reporting_Technology
It is highly unlikely that you will be able to fix this since it's a hardware problem on the hard drive. The drive may last for years or it may die tomorrow. At a minimum I would back up everything you care about on a regular basis.
If you found this information helpful I would appreciate it if you would rate this solution. I hate to beg, but over half of the solutions I've posted have no feedback. I'm not paid for this I'm just trying to help.
Dec 31, 2007 | Computers & Internet
Lenovo G450 Notebook Logo
99 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
