Question about Sansui Televison & Video
Sansui remote control for plasma serial sty0432
Want to buy have tv but no mote control
SOURCE: Need a remote control code for a Sansui TDC2075 TV/VCR/DVD combo
Contact Fox International parts at 1-800-321-6993
or Sansui troubleshooting hotline at 800-289-0980
thanks
Posted on Nov 13, 2007
headstrong
  • 233 Answers
SOURCE: remote control
Yes you can get a universal remote
but take a look here
thanks for rating
Posted on Jan 14, 2008
SOURCE: NEXXTECH 2 IN 1 BIG BUTTON Universal REMOTE CONTROL TV code for sansui tv
Have a solution for you.Turn your TV on then Press and hold 'P' on remote until light stays on. Press device to be controlled (TV/Cable) light will flicker but stay on. Now keep pressing channel up (up to 300 times) until device changes channel. Then press Enter to save code. Hope this helps
Posted on Jun 21, 2008
  • 54 Answers
SOURCE: Help for Sansui URC-3605 one for all remote control codes. Need T.V code.
You will find all codes and needed information here...
http://www.hifi-remote.com/manuals/
Just look up your model number and wallah!
Posted on Aug 17, 2008
Kindofcheap
  • 241 Answers
SOURCE: HD4208T111-PDP 42in plasma TV's remote control
HI here you go it is the best
http://www.partstore.com/
please feel free to rate my help
Posted on Aug 29, 2008
My VIZIO TV will not turn on. Ren=mote batteries check fine.
Hi Ranjana,
To check the remote control, please press any key and see it's led through the camera of your mobile phone. You will see purple light blinking if the remote control is ok. If the remote control turns out to be good, it is the TV which needs attention.
Good Luck
Dec 03, 2015 | Vizio 42 in. LCD TV
Naxa remote control code with RCA remote
You will need the name serial no. of the unit and you have to look up and match it to the re-mote should be instructions with the remote.
Aug 26, 2014 | RCA RCR612 Universal remote control,...
Wii screen says press a but nothing happens after that-fresh batteries
You'll then have to either buy another sensor or wii mote.
Try it with a friends wii mote.
If it still doesn't work you need a new sensor.
If it still persists even after buying a new sensor, thenn its a system problem and you'll have to service it or something.
Mar 10, 2013 | Nintendo Wii Console
Just got a new wii and it was working fine but now the controller has stopped working and the wii wont connect to the tv???? Can you help????
Hello!
First: Check to see if the batteries are good, easiest way to do this is try putting different batteries in that you know are good.
Second: If your batteries are not the problem, then first, open the memory card door (little door on the front of the console under the CD slot) and press the red button(or known as the sync button) and open the battery case and press the little red button(or known as the sync button) and it should reconnect.
Third: If the Wii is showing that your Wii Mote is connected but it isn't responding, make sure your Sensor bar is in a clearly visible location in front of or on top of the TV. Make sure that it is properly plugged into the Wii in back.
Fourth: If none of these resolved the issue it is likely that your Wii Mote is just flat out broken. If you just purchased your Wii I suggest contacting Nintendo to RMA (return) the Wii Mote for a new one.
May 30, 2011 | Nintendo Wii Console
Our Wii remote hand is not appearing on the screen. We don't know what to do?
Make sure all devices are connected to the Wii Station correctly and securely. Make sure the batteries in the wii-mote are working and the light is on.
Trying moving the wii-mote sensor to the top of the TV if its on the bottom or vice versa and try again.
If none of that works try bringing the wii-mote to a friend who has a console and trying it there, if it doesn't work then there might be something wrong with that wii-mote. If it works then ask someone to bring a wii-mote to your console and try it, if that doesn't work then there might be something wrong with the console or the receiver.
Good Luck!
Mar 11, 2011 | Nintendo Wii Console
There is a problem with the remote connecting to the game/tv
I would suggest buying a new wii-mote or re synqing ut sencor bar to ur remote
Mar 11, 2010 | Nintendo Wii Remote Controller
Controllers wont sync
If you have pressed the sync button on wii, then on the wii-mote, and it still didn't sync, try unplugging the Wii console for few minutes and try the process again.
There is another syncing mode, but you have to have at least one wii-mote connected to the wii. You press the home button and the click on the wii-mote on the screen. There will be a reconnect button. Press that and then press both the 1 and 2 buttons on the wii-mote[s] you want to connect. This is the ONE TIME ONLY connect mode, used when playin on a friends Wii. Once the Wii is powered off, the wii-mote wont be connected any longer and will still be the default wii-mote for your wii system [not on your friends]. Hope this helps.
May 10, 2009 | Nintendo Wii Console
Wii remote won't let me swing or box
if the remote sensor doesnt work, then it wont register with the game console. there is sort of an accelerometer in a wii mote that can sense the changes in angle and height and things like that. that accelerometer could be broken due to dropping of the controller(unlikely) or overshaking(very unlikely) or just bad production(sort of likely). just call the nintendo customer service and confirm the problem with the controller and ask if it is possible to refund the item for a new one or you could just buy a new wii mote. also, you could try using a friends wii mote to make sure that your system is recognizing the controller.
Oct 12, 2008 | Nintendo Wii Console
Televison & Video Logo
62 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Electro Med Services...
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
