Question about Refrigerators
Ffhs2611lbo why is my frigidaire blinking 4
Noticed when laundry room is dark you can see a blinking red light under the area of the lint trap on Frigidaire stackable washer/dryer model FFLE1011MW1. Just curious to what that may be.
I did some research on this. It appears the blinking red light is to indicate there might be a problem. The "blinking" is actually an error code. A certain number of "blinks" is indicative of certain types of errors. This is similar to a cars "check engine light". A car is scanned to get the code, which can help lead to the problem. I found a common source for dryer codes according to the blinking red light here:
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134859700e.pdf
I hope this helps :-)
Jan 28, 2016 | Frigidaire Washing Machines
Frigidaire dishwasher
Thank you for your post, Melissa Androes!
From the information you have provided on your Frigidaire dishwasher the wash, dry, and clean light is blinking along with a 4. This could mean that the dishwasher is pausing for the heater to become energized. If this code has been flashing for a long time I would suggest performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for roughly ten minutes. If you continue to experience issues with your dishwasher I would recommend consulting with technician for a diagnosis to be completed. I hope this information is helpful. -Matt
Feb 20, 2015 | Frigidaire Dishwashers
Frigidaire FFBD2406NW0A then clean wash drying and 4 hour led lights are blinking
I appreciate your post, friend!
I understand that the clean, wash, and dry buttons on your Frigidaire dishwasher are blinking along with the four LED light. This appears to be a delay start cycle. I would recommend pressing the cancel button. If that does not clear the lights you can perform a reset and to do that you would need to disconnect power from the dishwasher for roughly ten minutes. I hope this is helpful. -Matt
Temp at 9 goes to 4 and blinks
Do you have a seperate control for the freezer? What is it set at?
Jul 10, 2013 | Frigidaire FRS3R5EMB Side by Side...
Lights blink but nothing works
Hi, disconnect the power supply for few minutes, say 5 minutes and then turn it ON. Check, if that helps. If not kindly revert with more details :-
1. Which light is flashing?
2. Is there any message like ' CL ' or anything you could see?
3. How old the machine is?
4. Is there any sequence in blinks like 7 blinks then pause and then 7 blinks?
Let me know,so that i could provide you with more accurate diagnosis.
Jun 21, 2011 | Frigidaire FDB520RH Builtin Dishwasher
Frigidaire dishwasher had blinking lights then nothing
there is no fuse in the unit but u can unplug and plug into power 2 c if resets.
Aug 18, 2009 | Dishwashers
Freezer control is set at 9 and ref. control is set at 7 or 8 and when you close door ref. side resets to 4 and blinks. water is dripping in freezer side. this is a frigidaire model frs3hr5hb2 less than...
if its less than one year old you should be able to call for warranty service and have your machine fixed for free.
go to www.frigidaire.com and search for servicers in your zip code. If you have no luck with that let me know, i can further assist you.
May 15, 2008 | Frigidaire Refrigerators
Frigidaire refrigerator temp blinking
Have the "guys" correct the faulty installation. They failed to check operation before leaving.
Dec 10, 2017 | Refrigerators
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
