Question about Minn Kota Trolling Motor E Drive With 20 Inch Shaft 2 Hp
Shear pin on minn kota 2 hp e drive
Prop spins slowly when throttle on full and makes a slight clanging noise...is shear/drive pin broken? can anyone answer on how to replace?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Minn Kota Master
  • 1,190 Answers
Remove prop and look !!
Posted on Jul 10, 2014
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    Minnkota endura c-50 shear pin size
    You can get the appropriate pins in the prop not kits sold by minn Kota or thru major retailers.
    Trolling Motor Replacement Props Minn Kota Motors
    You will find prop nut kits here just follow the link.
    Sep 28, 2014 | Minn Kota MinnKota MK110P Marine Portable...
    Have a 3 hp. minn kota, prop wont turn, hard to
    I have the same trolling motor and the same problem.
    It seems the factory grease gets hard inside the motor where the shaft spins and acts like glue. I removed the long screws, carefully pulled the case apart, cleaned out the old grease (which was more like hard plastic) and packed the bearing area with lithium grease. I also lubricated the "O" rings and they were not damaged or brittle so I re-used them and put the unit back together being careful to tighten the screws properly. I have had no problems since. Also be sure to check the connections to the battery, for some reason that motor is very sensitive and wants a really good connection to the battery posts and sometimes all you need to do is re-tighten the connection if the motor does not run at all.
    By the way, I contacted Minn Kota regarding the 3Hp and was told "hp" stands for high performance and the motor is not 3 Horsepower.
    Jan 19, 2010 | Minn Kota Boating
    Prop spins slow on any speed on the foot pedal
    There is a good chance that the control board is bad. This is a common problem with these units. I have replaced my control board twice. When the control board goes out, some function of the unit will not work correctly while other functions work fine. The first time mine went out, the prop motor would not work. The last time the board went out, the unit would only steer right.
    May 27, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    The prop will turn on my minn kota endura 44 but it has no power is there a shear pin on this motor
    Odds are you have sheared the pin (slides through the prop shaft) holding the prop, or you have damaged the slot on the prop that the pin sits in.
    Prop is secured to the shaft with a metal nut, or flat plastic wing nut. Remove the nut to remove the prop. You may have to pry, slightly, the prop from the motor housing. Removed, you will see a whole in the shaft where a pin should be located. If the pin broke, it probably hit the floor when the prop was loosened. If the pin is intact, examine the rear side of the prop and look for damage to the plastic slot where the pin would sit making contact.
    If you've snapped the pin, you can make a replacement with a nail using a hacksaw. Replacement pins can also be ordered from Minn Kota. If the back side of the prop is damaged (recess for the pin to sit), the prop is toast. Replacement props are often carried by Walmart, and include a new pin.
    If neither part is broken, perhaps the prop was just not seated on the pin correctly allowing the prop to freewheel.
    May 04, 2009 | Minn Kota Endura 30 Freshwater Transom...
    Minnkota trolling motor prop removal
    remove the nut and the prop will come right off. Just be careful not to loose the shear pin.
    Apr 22, 2009 | Minn Kota Endura 30 Freshwater Transom...
    Minn Kota Trolling Motor E Drive With 20 Inch Shaft 2 Hp Logo
    179 people viewed this question
    Top Minn Kota Boating Experts
    Mike Marcotte
    Mike Marcotte
    Andrew Taylor
    Andrew Taylor
    Colin Stickland
    Colin Stickland
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
