Intex salt water pump
SOURCE: My saltwater pool tastes very salty, but my intex
Your salt is way to high if you can taste it. You will need to dilute with fresh water until you get the salt back down and then clean the cell for continued use.
SOURCE: Where can I get a new motor for an Intex pump model 637 or 12R
first off water should not be getting to the armature area. be carefull with how you are taking care of your pump.
secondly a 1500 gallon pump is very weak I would advise at least 2500 or even the intex 4000
the most important part of pool maintenance is circulation.
if you have time check into electric motor rebuilding in your area
but sometimes that is more expensive than buying new
also if you have a valid receipt and the pump is less than 90 days old call intex and they will send out a new one within 24 hours
good luck
SOURCE: i bought an intex salt water sys the book says add
error 91 also means that your plates may need to be cleaned of corrosion. I had this problem last year.
SOURCE: I keep getting code 90 (low water flow) on my
If your pool has the skimmer system there is a hose coming from the bottom of the skimmer to the wall of the pool which would be your suction to the pump. Disconnect the hose clamp from the suction port that goes through the wall of the pool remove the hose then unscrew the blue adapter on the inside of the pool there you will find a strainer / screen. Whatever gets pass the basket in the skimmer get's plugged up in that screen causing the pump to starve for water causing the LOW FLOW sensor to go off on the Saltwater pump.
Let me know if this helps any.
SOURCE: Low salt alarm on Intex system
I had the same problem and my father just kept adding salt wo telling me and it kept saying low salt-I called intex they said to clean the cell with vinegar as instructed in book, and if that didnt help to call back for a warranty claim on the unit bc I just purchased mine in June. I am currently waiting on it to come in. We had to drain half the pool and refill with water and start over. be careful!
