Question about Panasonic EY3530NQMKW 15.6V Cordless Metal Cutter Kit
EY3530NQMKW I put a fresh charged battery in and cut 3 - 2x4's and battery runs low quick, It's a NEW battery Could it be bad Brushes?
  • jm6047 Aug 06, 2013
    I put a fresh charged battery (OVERNIGHT) in and cut 3 - 2x4's and battery runs low quick, It's a NEW battery Could it be bad Brushes?
    Top Expert:
  • Panasonic Master
  • 45,531 Answers
I would suspect poor quality batteries in the battery pack or memory in the pack from recharging a partially charged pack instead of letting it work to flat condition. New batteries take hours to fully charge so if you just plugged in the charger for a short time before use then the battery pack may nit have been fully charged to start with.
Posted on Aug 04, 2013
    I charged the NEW battery overnight 24 Hrs or more and the same as used batterys
I cleanen carb drained fuel put in fresh fuel charging at 13.8 on meter new sprk plug changed oil runs fine at about1/2throttle starts cutting out at high rpms could valves b n issue as well
Hi, Martie you are a 1 volt low on your charging rate and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition and leaking.
3. Spark plug gap too close or too wide.
4. Faulty ignition coil, module, and or sensor.
5. Battery nearly discharged.
6. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
7. Intake air leak.
8. Water, dirt, or rust in the fuel system, carburetor and/or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor.
12. Loose, dirty, or corroded ignition module connector at crankcase.
13. Faulty MAP, CKP, O2, and/or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damaged intake or exhaust valve.
Good luck and have nice a day.
Nov 20, 2015 | Motorcycles
DC385 does not run when trigger is pulled with a fresh battery installed.
the armature comuttator can be bad on some collectors and even broken you can hear it if you have a short period for the first time hearing a shrill sound then its also eating brushes and much whistling sound until it become hot control the sliding contacts on the purple and brown wires to the brushes and after that it should only make a buzz sound and has no power give not allways the batteries the blame in most causes like the brands MILWAUKEE and PANASONIC have some brushmotors they have allways the cause of problems EY7441 last a little time of 2 years It is almost a short circuit and then the collectors eating the carbon brushes in a few weeks and make a loud piercing sound, bad for the batteries Milwaukee has the same type of brush engines Johnson when there are people who think the batteries are bad ALLWAYS replace the armature if you hear a shrill sound and the machine become hot believe it in 80 % it is the problem new brushes are eaten again in a few weeks even Makita and Dewalt but not so much as the type of Johnson armatures buying new batteries shall not help much more but you can hear simply the difference and the rpm is much better and again much more powerfull AND MUCH CHEAPER look the difference of the 2 armatures left the older less powerfull armature and on the right the later modificating armature as Panasonic and Milwaukee having with much more power new development but MUCH MORE HEAT DISSIPATION and a very short lasting time if its to much charged then its sounds terrible replace it and your batteries are happy. .4a38f402-6535-4bb2-aaff-bf43754c8cd5.jpg
Oct 17, 2013 | Dewalt Dc385 Reciprocating Saw 18v Tool...
Why is my bike clicking and wont start?
make sure you got your terminals tight. then if so its still your battery not charged, just push it til you get jogging speed jump on put it in second pop the clutch it will start let it run about 20 to 30 mins should be enough charge built in your battery to restart it, if not your battery is bad even though its fairly new could be low on water inside it !
Jan 19, 2013 | Motorcycles
My car doesnt start
Sometimes the battery will be good enought to run lights but will not turn car over. I would have battery put on a full charge and see if it holds up. if battery will not hold a full charge it is bad. If your car runs and the battery last a few hours then goes low again, It most likley is the alternator. put battery back on full charge and replace alt, and you are ready to run.
Apr 11, 2012 | Cars & Trucks
Electrical: I have a 2000 Dodge Grand Caravan and the battery light came on . So i hooked up my tester on the alternator and got a low output, than disconnected the negative terminal while the engine
My 2000 Caravan developed this problem after our hard winter so I searched and found that tapping the alternator might reveal that the brushes were intermittent. Sure enough, a slight tap caused the charging voltage to come on at around 14 Volts. A new brush assembly was under $10 on eBay and after finally getting the alternator out and the brushes replaced, re-installed all was well!
Feb 21, 2012 | 2000 Dodge Grand Caravan
I have a 98' Grand Marquis with a 4.6 engine. as
have the alternator checked. if the alternator is not charging the vehicle is only supplied with what power is stored in the battery. once the battery is dead there is nothing to charge it
Jul 26, 2011 | 1998 Mercury Grand Marquis
Battery no charge
Either the battery is old and won't hold a charge or your altenator is not putting out enough to charge the battery. If the car is running disconect the positve side on the battery and if the car keeps running then the battery is bad, if it dies then the altenator is bad. Could aslo be a bad voltage regulator, but those are in the module.
Mar 15, 2011 | 1996 Cadillac DeVille
Altanator keeps dieing.
A fresh charged battery does not mean it is a good battery.The battery is working the alternator to death,replace it,it has a bad cell,or the amps are to low,and has a short in it.The alternator senses the battery is in bad need off charge,and puts all out until the alternator has nothing left,This is the most likely cause of this problem.Also be sure the battery cable ends are shiny clean when replacing the battery.
Nov 26, 2009 | 1995 Mazda Protege
Battery light and brake light come on for no apparent reason. Aren't on after the car sits awhile.
Your problem will be in your alternator, the brake light and charge light coming on at the same time is almost Daihatsu code for the alternator brushes are failing.. Easiest way to determine this is when the two lights come on, leave the car running and pop the hood (don't forget to put the car in park or out of gear with handbrake on) then find yourself a solid bar or stick and give the alternator (rear of engine bay) a solid but not hard tap. If your alternator brushes are failing you will hear the alternator kick in and see your brake/battery lights go out. Don't drive around too much with the two warning lights lit up because you are running on the battery only and your ignition system could cut out at any time when the battery gets too low.
Aug 05, 2009 | 1991 Daihatsu Rocky
Battary light on , engine cut off car won't crank
sounds like it's your alternator, your alternator charges your battery and runs car once it is started. if you have a bad alternator your battery light will come on, and shortly after your vehicle will die, unable to restart without a jump. I would take your battery to autozone or an auto shop to have your battery and alternator tested.
Jan 28, 2009 | 1999 BMW M3
Panasonic EY3530NQMKW 15.6V Cordless Metal Cutter Kit Logo
Top Panasonic Saws Experts
Tom Chichester
ray gallant
Are you a Panasonic Saw Expert? Answer questions, earn points and help others
