Question about Carrier 38CKC024 Air Conditioner
Carrier leaking cARRIER CD5AXA036017ABAA PAN LOCATION
5 Suggested Answers
  • 182 Answers
SOURCE: I have carrier infinity 18
Carrier carries a 5 yr parts warranty.I'm not a big Carrier guy but the are not an inferior product from what I've seen.I'd contact another company that is a Carrier dealer for a second opinion.
Posted on Aug 05, 2008
  • 415 Answers
SOURCE: looking for evaporator coil cd5axa036017abaa
It is unfortunate that Carrier is failing to stand behind their unit. Are you getting this information from the local Carrier Distributor or from the Carrier Syracuse Plant? If you have not done so already, try contacting the Carrier Syracuse Plant......be sure to obtain ALL records from your service company to accompany your letter to Carrier. They will need specific installation, start-up, and all service dates to include specifically the type of work performed and the materials used. Your dealer should provide to you at your request.
If it doesn't pan out, then look into service companies and products in your area that have a better reputation and warranty offer. You can install a coil from a different manufacturer than the outdoor A/C unit. It simply needs to be matched up. If your unit has been leaking for 3 years, you have been paying extra utility costs due to poor performance. You have also exposed your entire system to moisture which, if not properly dealt with, will lead to problems with your compressor and/or metering devices. A reputable company will help you address these concerns at time of coil replacement by removing the refrigerant in your system, testing for acid, installing a filter drier, evacuating the system down to 500 microns, and recharge using virgin refrigerant.
Here is link to a site giving you Carrier's C.E.O.'s name and contact information. Hope this helps. :-)
Posted on Mar 26, 2010
  • 674 Answers
SOURCE: Water in the drip pan- what is causing it?
I assume you are talking about the indoor unit. One function of the a/c system is to dehumidify the air. Condensation forms on the cooling coil and runs to the drip pan. There should be a drain line on the drip pan that drains the pan outside. These sometimes become clogged causing the water level in the pan to rise. Try some mild drain cleaner to open the line. Hope this helps. Let me know what you find.
Posted on May 22, 2010
  • 1033 Answers
SOURCE: where is the drain pan on a carrier weathermaker 8000?
Hello, the drain line will be located under the unit near the condenser coil. Sometimes it can get blocked and the condensate will settle toward the front of the unit and leak from the unit. Also, make sure the unit is tilted back in the window about a 1/4 inch aswell.
Posted on Jul 12, 2012
1999. How can I replace front diff seal?
on the actual front diffr, pinion or the front transfer case seal
the front seal is like the rear.
its a crush cage.
that means when you remove the pinion yoke/flange big bolt
the crash cage is destroyed. also wrecking pinion gear to ring gear back lash..oops.. big big mess-up there...$$$$$$
and such cage must be replaced.
questions????????????
how can you be sure its leaking, when the engine this old loves leak oil
i bet that oil on the ground does not small at all like the nasty stink of hypoid GL5 gear lube. I BET
why not post how to find leaks first
and not do $1000 damage
no engine size posted G16? J20?>
The G16, ill demonstrate (coin toss)
Distributor 2 , o-rings leak like made, all do this old !!!!
same with the 60k mile service and valve cover gasket
all leak, for that reason alone, on all 1990s era
next is cam seal
crank seal
pan seal (or pan is rusted thru as many see (today)
oil pump seal
and gawd forbid the rear main seal , engine.
easy peasy japanezzy
why not ask your mechanic to sniff that oil first and save a fortune
guessing.
see man pulling axle to remove pan
wana do that?
http://www.fixkick.com/axles/Pan-drop/pandrop.html
to replace this seal, remove the carrier first
then take it to a shop that can rework the carrier
the correct way.
Jan 25, 2016 | Geo Tracker Cars & Trucks
Carrier ductless condensation leak
look at the base of the pan where the hose meets the pan for blockage to the drain
Aug 27, 2012 | Carrier XHB123D X/Y Series Heat/Cool Air...
Where is the drain pan on a carrier weathermaker 8000?
Jul 11, 2012 | Carrier XHB123D X/Y Series Heat/Cool Air...
I have 2 Carrier Air V A/C units on my houseboat. On both units the outside drip pan overflows and leaks water on the deck. How can I install a drain hose to route the water overboard instead of making a...
Without seeing the setup and possible routing of drain lines, i would suggest a 120 volt condensate pump. Then you could route the condensate overboard at a convenient location or into another drain on the boat.
Sep 05, 2011 | Heating & Cooling
My drain pan is leaking
You need to access the evaporator coil on the inside of your air handler and unplug the drain for the condensate. It should be the 3/4 inch line, if the 1/2 inch line is capped then it is not doing anything and has probably been abandoned.Open up the unit and clean the drip pan and drain hole where the 3/4 line starts. This should clear up your water leak problem.
Also
Water leak due to dust block in air filter,cooling coil,drain pan and blower wheel.
Jun 29, 2011 | Carrier 38CKC060 Air Conditioner
Looking for evaporator coil cd5axa036017abaa . three years of recharging rather then fixing now the coil is out of warranty and Carrier and service company will not stand behind product.
Hi, if you have a leak in the evaporator coil which this happens a lot and they came out and didn't try to make any attempts in finding and repairing the leak or they found it in the coil and didn't order a new one, this is against the law by E.P.A standards. They must make every attempt in making the repairs if it means replacing the coil, no if, ands, or buts!! Keep your receipts on them charging the system. Now that its out of warranty, I would call them and bring this up about not changing out the coil when the leak was found. I am sure they used dye to locate it.I have found more leaks in the evaporator coils then I care to count, and had to replace the coil. This is something you can't do on your own I must say, as it takes special equipment to do this job. I would call the Enviormental protection agency and tell Carrier you will do this, and report them. I bet they will stand behind it then. You have to get tough with them. I am a air conditioning contractor and know the law. The E. P. A. will get them on the ball trust me. This is bull+)_(*&%!* !! Don't let Carrier walk on you, this coil should have been put in the schedule to be changed out right away, not to continue to charge it to get you through. This is a 3 ton split system. Stay on them, this will be covered if you make the call and stay on them. The E. P. A. are very strict on this as this is why they have stopped us from venting freon into the air, they have very strict guide lines we must follow and Carrier did not follow them on your unit. Please keep me posted, and the best to you.
Sincerely,
Shastalaker7
Mar 26, 2010 | Carrier 38CKC030 Air Conditioner
I have carrier infinity 18 central air and worked good for one year and second year summer season its out of purion gas and we had an authorized person to recharge with purion gas and worked for a few days...
Aug 05, 2008 | Carrier Heating & Cooling
Carrier 38CKC024 Air Conditioner Logo
53 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
