Question about Sony Boombox Am Fm Tv Weather Band Cassette Radio Cfm-165tw
Where can I find a new ac adapter for a sony radio model #cfm-165tw?
How to connect HDTV antenna to an old Sony Am Fm Radio Tv Receiver, Model Tv-413?
yes there is an coax to ant adapter. Check walmart or Radio Shack if they are still in business.
Apr 06, 2015 | Sony Am Fm Radio Tv Receiver, Model...
How can I buy a new antenna for model sony cfm-165tw
Many boombox antennas are attached by a small screw through the pivot point. This is usually a #1 Phillips screw. Some do not have a swiveling antenna; for these you have to remove the back of the case to get at the attachment screw. Keep the screw; it's guaranteed to fit when you attach the new antenna.
The hard part is finding a replacement. If you have the pivoting/swiveling antenna, the Radio Shack 28" Replacement Telescoping Antenna 270-1405 ($5.99 online) will probably work. You might even be able to use it for a non-pivoting antenna that telescopes into the inside of the case.
Jul 22, 2014 | Sony Boombox Am Fm Tv Weather Band...
Battery/Ac adapter issues for Sony VAIO Model
So I gather the laptop does not run when the battery is in and the AC adapter is not connected? Laptop batteries tend to ware down over time and will need to be replaced as they end up not being able to hold any charge. Look online for a new replacement of the battery under the model number of your laptop
Aug 13, 2013 | Sony VAIO PCG-K33 Notebook
I have had a Sony ICF SW7600 for the last 18 years. Now, it only wishes to work on batteries and not on the AC adapter anymore. What can be the problem and how to fix it
I have the exact same problem here in Europe with my perfectly with my Sony shortwave after 18 years. If I fiddle with the ac adaptor in the radio plug, it works for a while. I have replaced and soldered the yellow tip adaptor twice in 18 years and hopefully the problem is with the power plug and not the radio plug.
Any help is appreciated.
Dec 20, 2012 | Sony ICF-SW7600 AM/FM/SW Radio
I need to find a new ac adapter or at least the model number for it
Hello
buy a 9VDC output AC adapter. You can use anu company's adapter, provided the voltage rating shoule be 9VDC 2Amps. OK.
Dec 23, 2011 | Sony S2 Sports ZS-XN30 Radio/CD Boombox
Where can i get a replacement AC adapter for my sony walkman MZ-R70?
You web search for "Sony Walkman MZ-R70 ac adapter".
Lacking a perfect match find a 3vdc power supply somewhere like Radio Shack or eBay. They make universal ac dc adapters. Look around.
Aug 10, 2011 | Sony Walkman MZ-R70 Personal MiniDisc...
Sony ICF-SW35 needs an AC adapter. 220VAC in, 4.5
CLICK HERE
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 19, 2010 | Sony CDX-GT320 FM / AM / XM Radio / Sirius...
BROKEN ANTENNA BROKEN AC/DC ADAPTER
I just started to put some stuff on ebay and I have new one ac/dc adapter Model # ae9512
Good Luck!
silverrockny (my ID on ebay)
Store nameon ebay: The right Stuff Store
Oct 27, 2007 | Emerson iP100 Clock Radio
Sony Boombox Am Fm Tv Weather Band Cassette Radio Cfm-165tw Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
