Question about Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 2800 - Paper Jam
The machine flashes Paper Jam, and will not operate at all. All points have been checked, but no paper jam is evident. The machine has been unplugged to re-set and still nothing is able to clear the message and restart the machine.
  • 1 more comment
  • Loretto Aug 29, 2007
    Nothing appears to be knocked off course. Another possibility told me was the fuser may have come to its end of life. A decision to order a new unit was made by management.
  • HOWARD REVELSON Aug 15, 2008
    TO COPY,AFTER PAPER TO BE COPIED IS PLACED IN THE PROPER MANNER-I PRESS THE COPY BUTTON AND THE WORDS NO DOCUMENT APPEARS.
    I'VE NEVER HAS A PROBLEM WITH THE MACHINE BEFORE
    CAN U HELP
  • cdp033 Mar 31, 2009
    have same issue and see the physical sensor came out but don't know where it go back? does anyone know where to place this back into machine?
    Scholar:
  • 41 Answers
It could be one of two things. First and most common is one of the sensors is dirty/stuck and a quick round of compressed air will usually take care of it. This is especially common if you have been running 3 hole punched paper as the loose punches tend to cover sensors. Recycled paper also tends to leave some dusty residue and that will, in time, obscure the sensors, along with a dusty environment or if the machine is on the floor. Another possibility is one of the physical sensors got knocked off course a bit. This could be caused by pulling out jammed paper too roughly or running lots of heavy paper through the unit. I would do a visual inspection for any bent or crooked parts.
Posted on Aug 29, 2007
SOURCE:
Where can I get a Brother Intellifax with a bad
1-800-BROTHER should get you to an authorized repair center.
Nov 06, 2009 | Brother IntelliFAX 2800 Laser Fax
I had a paper jam. I removed the paper jam already but computer says it still there. How do I reset it?
It's possible there's still a small piece of paper or dust stuck in the paper feed. Try blowing the area out with compressed air.
Aug 31, 2009 | Brother IntelliFAX 2800 Laser Fax
Paper jam message but there is no paper jammed. opening and closing cover doesn't work.
hi,are you sure no paper jam ok check very very small paper in your machine or clean the sensor.
Apr 28, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Brother Intellifax 2800 Paper Jam Issues
Pull open the doc feeder and look for an obstruction. A wayward staple, paper clip, push-pin, post-it note?
Sep 27, 2008 | Brother IntelliFAX 2800 Laser Fax
Paper jam
Lift the operator panel up and look for the receipt.
Aug 29, 2008 | Brother IntelliFAX 2800 Laser Fax
Check Paper
Check paper can also sometimes mean a jam. Remove the drum unit from the machine and check for a piece of paper inside the machine.
Also with this machines feed path it can mean that a foreign object can fall down the back and obstruct the paper.
Feb 12, 2008 | Brother IntelliFAX 2800 Laser Fax
Pls open cover = Please open cover. Probaly has a jam - Open the cover remove the drum/toner unit and check for jammed piece of paper under of in the drum unit.
Jan 24, 2008 | Brother IntelliFAX 2800 Laser Fax
uplug from the wall and replug to remedy this problem
Dec 31, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
603 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
