Question about Refrigerators
Samsung rfg298 screen on front shows 88 98 and won't let me use any of the functions including changing from water to ice
espressonist
  • 1711 Answers
SOURCE: MY NEW SAMSUNG FRENCH DOOR
There is a special troubleshouting Guide special publication in the web for this problem.
You need to reset the ice maker. The ice maker reset button is located on the bottom of the ice maker assembly. remove the ice bucket and then press and hold the reset buttong for three seconds.
Sumsung have a link for this.
http://support-us.samsung.com/cyber/popup/pop_troubleshooting.jsp?idx=137116
We had a couple of insues for this new models ice makers and it seems that something is wrong from the manufacture so our advice is to get in touch with sumsung since there might be a complete update on this matter and if you mention it while you are in the Guarantee period you will be supported free in the future if the problem remain.
take care
Posted on Sep 18, 2010
  • 38 Answers
SOURCE: change water filter indicator came
This unit has water dispenser and ice maker? If yes, you must get all the air out of your water line, how to do this is keep fill water glasses until you get a good flow of water and no more air, also the water may drip some what so. until all the air is pushed out of the line your ice maker can not make any ice, please let me know what you find. Thanks Rick...
Posted on Jul 26, 2011
machinetech7
  • 1344 Answers
SOURCE: ice maker won't make ice but water is cold and works at dispenser.
Note: Always make sure your filter is current if you have one. Not doing so will cause water to not despence properly
Pull the machine out and remove the lower back cover. Locate the water valve. With the water turned on and connected remove the 5/16" water line (the bigger one) and then have someone else press the water in the door. If the cylinoid is operating correctly it should spray water out.If so, you just verified that the valve and electrical portions are working properly and either the filter is bad or the resevoir, , located inside the lower refrigerator side is frozen. If no water comes out but the valve vibrates, then the valve is bad. If no water and no vibration, continue reading.With the machine plugged in but the wires that go to the valve for the dispenser off take a volt meter and place a lead to each wire and have someone press the panel in the door as if getting water. The reading should go from 0 to around 115-120 a/c.If your not getting electricity down there at anytime than thje door switch is bad.
Testing the ice maker:
As far as the smaller line (1/4") you have to manually advance the ice maker and wait for it to call for water with the 1/4" line disconnected from the valve. You can do this by getting a jumper wire, removing the cover of icemaker, which you jsut grab and pull off, and using the jumper wire insert one end of the wire into the cirle marked m and the other in the cicle marked n. Leave there until you hear a click and sometimes see a little spark behind the modular head wheel. Also if you see ice in the maker that hasn't dumper and the teeth of the icemaker are facing any direction other than two o clock position, the icemaker is bad. Also check the fill tube to be sure the no ice is blocking water from coming in.
Posted on Jun 02, 2012
  • 313 Answers
SOURCE: Frigidaire PLHS69EE552 ice maker won't dispense water to make new ice. Water dispenser works fine.
You need to replace the ice maker
Posted on Jul 25, 2012
  • 7 Answers
SOURCE: water won't dispense but ice maker works
Most likely the valve has failed. Usually located in the back of the refrigerator, near the bottom - otherwise, follow your water line (feed from the house water supply).
Posted on Aug 02, 2012
Samsung RFG298 Freezer Drawer is not sliding out all the way.
Look for an obstruction on the slide-rails, or ice building up on one of them... Maybe this will help, LG and Samsung use a lot of the same designs. (garbage)
LG Refrigerator Freezer Replace Lower Drawer Gear 4403JA3005A
Dec 11, 2016 | Samsung Refrigerators
I have Samsung refrigerator RFG298 series the ice maker stopped working and sounds like a dog barking when it's running any ideas what it could be ?
Possibly the gear drive faulty in the ice maker, or it could be the dispensing chute has ice blocking it from closing properly. Completely empty the ice tray and make sure there is no ice anywhere in the tray, guides or ejection chute to the front door. On some, there is a little button under the icemaker for testing and forcing an ice maker operation. Press it and see if the ice tray rotates and reloads with water.
Nov 20, 2016 | Samsung RFG298HDWP French Door...
Samsung RFG298 hdwp showing error code 1 E was told its the freezer sensor what does this do?
It tells the main control board the current freezer temperature. The board then turns on the compressor and fan if needed to satisfy your selected compartment setting.
May 09, 2014 | Samsung RFG298HDWP French Door...
Rfg297aa won't make ice
Ice maker quit making ice. Ice tray in feeder was empty when I pulled it out. Water is working when I choose water but apparently no water is getting to freezer unit. What else can I check or do?
Oct 28, 2012 | Samsung RFG297AARS (285 cu ft) Bottom...
Ice maker will not make ice Model number
  • When it Won't Make Ice
    • 1 Get a thermometer and see how cold it is in there. If your freezer is fewer than 17 degrees F, it won't make ice. The freezer temperature setting may be too high or the thermometer is broken and not calibrated correctly. If adjusting the temperature fails to work, call a Kenmore technician.
    • 2 Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
    • 3 Turn your refrigerator around to look at the back side to see if water is getting to the water inlet valve behind the fridge. If the water is not properly connected, there's no water to make ice.
    • 4 Use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve.
  • Hope this tips will help you.
    Have a nice day! : )
    Aug 28, 2011 | Kenmore Refrigerators
    My kenmore side by side refrig is not allowing water to the spigot on the front of the door and the icemaker does not make enough ice. I have replaced the water pump but still no water to the spigot. The...
    There are many things that can go wrong with a Kenmore refrigerator ice maker. Your ice maker may be leaking. It may not make any ice at all, or the ice that comes out smells or has an odd appearance. The problem may have an easy solution, or it may require a technician's expertise. The troubleshooting tips in this article will minimally make you aware of what is likely the source of the problem. You may be able to fix the problem yourself and save a bundle.
    Hope this may help you.
    Have a good day: )
    Jul 19, 2011 | Kenmore Refrigerators
    No ice being produced
    1. Get a thermometer and see how cold it is in there. If your freezer is fewer than 17 degrees F, it won't make ice. The freezer temperature setting may be too high or the thermometer is broken and not calibrated correctly. If adjusting the temperature fails to work, call a Kenmore technician.
    2. Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
    3. Turn your refrigerator around to look at the back side to see if water is getting to the water inlet valve behind the fridge. If the water is not properly connected, there's no water to make ice.
    4. Use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve.
    Have a good day : )
    Feb 02, 2011 | Refrigerators
    Refrigerators Logo
    18 people viewed this question
    Top Refrigerators Experts
    John Tripp
    John Tripp
    Brian Coughlan
