Question about Refrigerators
Maytag ice2o the door alarm of my maytag went off I pressed the door alarm button only (F_C and F showed) and it stopped but it continued to do so. Eventually it started doing this again and then the inner light stopped working. so I unplugged it and plugged it in again but nothing has chanced! HELP
SolutionGuy
  • 331 Answers
SOURCE: The ICE2O has gone crazy
Billy, your HV control board has failed. (I know this because I serviced one just last week for the same symptoms and promptly diagnosed and repaired it.) The board can be accessed from the back of the fridge. Roll it out from the wall and look about 2 feet up from the floor on the left hand side. You'll see the cover held in place by 4 1/4" screws. Remove 3 and loosen the last one, rotate the panel out of your way. The board is a snap to remove and replace. The part number you will need is #12920710 and is available at your local appliance parts retailer. It lists for ~$150.00. The kit DOES come with instructions to program it once the repair is complete. Read these completely BEFORE doing the repair so you'll know what to do when you've got it back online.
Posted on Aug 13, 2007
SOURCE: icemaker clacking and flapping constantly and display lights going wild
See my post under the problem section. MAYTAG IS PAYING FOR THE PART AND LABOR FOR A NEW HV BOARD. ALL YOU HAVE TO DO IS CALL THEM. YOU DON'T HAVE TO SPEAK TO A MANAGER OR ANYTHING JUST A CUSTOMER SERVICE REP!!!!
Posted on Nov 30, 2007
  • 3 Answers
SOURCE: Too much bleeping
The alarm is caused by either temperature disorder, check on your thermostat settings, or it is being caused by unbalanced level of freon gas in the system, or the door of the freezer does not shut correctly.
Thanks
Nikunj Pattni
nikunj@qool-point.co.kr
Posted on Nov 17, 2008
aasc
  • 1606 Answers
SOURCE: GE Profile model PFS22MISBWW stopped working, panel problem?
Replace the main control board on the back of the refrig . PT# WR55X10656 . It's behind a panel about 10" x 6" .
Posted on Aug 08, 2009
  • 19 Answers
SOURCE: The ice and/or water won't stop coming out the
It sounds like the actuator for your dispenser switch is sticking. To fix it you will need to get inside the dispenser housing, which involves removing the decorative front panel on the dispenser.
It's kinda tricky to get this thing apart, and it's even harder to get it put back together if you've never done it. I'd recommend calling a repairman.
Posted on Sep 28, 2010
What is causing the anti-theft alarm light flashing/horn blowing go off?
the remote key would be the easiest (and cheapest) thing to try first but i don't think that a low battery in the fob would activate the alarm randomly , i'd get the OBD codes read as will point to which part of the anti theft/central locking system is causing the issue
Apr 07, 2015 | Lexus RX 300 Cars & Trucks
Ge refrigerator ice maker has stopped making ice
The water valve on the back of the refrigerator is bad, one controls water for the ice maker and one controls water for door water
May 11, 2014 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
I just bought a 2001 Subaru Forester, I put the key in the door lock to unlock the door and the alarm went off and won't stop. How do I turn the alarm off?
I would try to close the door and press the unlock button on the kay fob. (If it has a remote intergrated with the key). This should unlock the door and turn off any anti-theft devices.
Jul 27, 2012 | Car Audio & Video
Maytag MFI2266AEU Water and ice dispenser locked, control panel
Door Panel Locked
Press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue pressing Freezer "-". You will see PE _ _ _ _.
Press Freezer "-" until PE # # # # shows on the panel.
Using Freezer "+" to move cursor, Refrigerator "+" and "-" to change numbers, bring all numbers to "0". Press Freezer "-" until PE and numbers blink. Unplug refrigerator for 45 seconds, never beyond 1 minute or you'll have to start over.
Look inside refrigerator door and locate the serial sticker. To the right of the serial number is the CODE ####. Plug in your refrigerator.
Press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue to press Freezer "-". Using the same method as above, enter the four digit CODE number you found on the serial sticker. Press Freezer "-" until PE and numbers blink. You have just reset your panel. Unplug for 45 seconds. Plug in refrigerator and you should now have full use of your door panel.
This unit has a built in safety timer mechanism. If it dispenses water for two minutes, it assumes it is flooding your house and shuts the panel down. If you are filling a pitcher of water, just stop dispensing halfway through to reset the safety timer.
Feb 01, 2010 | Maytag MFI2266AE Side by Side Bottom...
How can I disarm a prestige car alarm system without the remote? The owner cannot find the remote. The battery went dead and when we jump started it the alarm went off. If the drivers door is closed it...
find the program button and turn on ignition without starting the engine and press and hold the button till it goes steady
if it has a swith turn on and flip the switch till it goes on solid 1 or 2 x
Dec 10, 2009 | Prestige 2 Button Remote Security System...
Programming hv board
I have the same Maytage MFI2568AEB on the inside top left of the refrigerator the code is 0302, i still cannot enter the code, showing PEO OOO.
Jan 10, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Lights flashing all cooling appears normal ice maker flap continually opens and shuts no water buttons not operational
As I mentioned before my Maytag was doing the same thing, I called Maytag expecting a big fight but they were really nice about it.
This is a recall problem and even if your warrenty is up Maytag will repair it at NO COST to you.
They shiped me the HV board and sent a repairman who had it fixed in about 10 minutes with a newley designed HV board.
Oct 28, 2007 | Maytag (MFI2568AEW) Bottom Freezer French...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
