Question about Gaggia Espresso Machine Academia Model 1003380, Silver, 1 ea
Can an owner of a gaggia academia get a repair manual for it. i need to get into mine and see why its leeking
Started to leak during the coffe production process. i dont think it leaks when not in use
    New Friend:
You can buy one from america. http://www.shop.partsguru.com/Gaggia-Accademia-SUP038G-Service-Manual-SUP038G-Service-manual.htm Ive got a problem with mine too and thats the only one i found so far
Posted on Jun 17, 2015
How do I replace the coffe scraper and spring?
Kevan I got the manual it says there that an authorized dealer is the one that should do the repairs. http://www.coffeeitalia.co.uk/prodimages/manual/Gaggia-Manuals/Automatic-Coffee-Line/titanium/58_libretto_titanium.pdf Do not dispair when you see the manual, it is in many languages, also English. Good luck Kolbrun
Sep 18, 2013 | Gaggia Titanium Espresso Machine
My gaggia classic steam control knob is inaccurate and fails to turn off the steam completely. the system leaks a lot of water into the tray
you should take out the knob first, than you try to disasembke the SHAFT of valve from the valve body, in this types(small espresso coffe machines) usualy producer use conical valve, without seals she close metal to metal, when you get out the SHAFT you will see one line on the conical end. for repairing it will be enough to visit one metal vorkery where they will take a small amount of brass from end and polish it. then you put it back and work again with your machine. During assembling valve change 2 o rings and put one fitting 1/4'' to block the shaft coming out.
ps: notice you only polish the SHAFT , dont let them to short the more than 0.5 mm
Feb 11, 2011 | Gaggia Classic Espresso Machine
Water leak causes the main power to trip. can you
Yes it can be repaired, I would suggest getting a rebuild O-ring kit for your machine, it comes with all the gaskets and O-rings that you will need for the machine.
May 30, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Gaggia Syncrony logic rapid steam machine leaks water from bottom
Check the chamber under the white plastic valve behind the brew unit, it might be blocked with coffee.
Apr 13, 2010 | Coffee Makers & Espresso Machines
The brew unit is not tamping the ground coffe properly.
Give the brew unit a good wash,then lube all the moving parts with food grade grease.
If you are able dismantle the brew unit and wash in warm soapy water,this removes coffee and any old lubricant.
Feb 21, 2010 | Gaggia Titanium Espresso Machine
Gaggia Coffee Classic Steam Valve Leaking - No Pressure!!
Yes it can be repaired if you have the parts, you will need the complete steam valve with the o-ring that connects to the boiler check the diagram below.
Aug 21, 2009 | Gaggia Coffee In White, White MDF...
Water level light blinking, won't turn on
Have you tried to open the hot water valve to see if the water circuit needs venting?
Apr 28, 2009 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
No operating manual?
Thanks to origin; now have instructions!!
Feb 11, 2009 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Replacement Part
Check one of the followinfg sellers :
Home Page Seaco,Gaggia,Spidem,UNIC,LaPavoni Espresso machines, parts
Gaggia Espresso Machine Parts
or see here GAGGIA Replacement Parts
You usually need to call the seller to get the price and order the part.
Nov 15, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Gaggia Espresso Machine Academia Model 1003380, Silver, 1 ea Logo
922 people viewed this question
Top Gaggia Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Gaggia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
