Question about Ovens
Door stays open about 2 inches
I have a Whirlpool GMC275PDB1 microwave oven combo. The oven door would not close completely so I replaced the hinges, and it fixed the problem for 2 days. My wife baked a cake and as soon as the cake was done she opened the door, and tried to close it. Now it stays open about 2". I also noticed that when it is completely opened, the door sits/rests lower than usual. I already called the supplier to reorder new hinges, in case they are defective. My concern is that something else may be causing this issue. Could there be something else beside the hinges, that is causing this new/old problem, of the door staying opened.
  • Ovens Master
  • 9,047 Answers
Replacing the hinges is risky because you need to be 100% sure the new hinges go back in the exact spot the old ones were.
Otherwise, there might be leakage, which can lead to arcing and possible fire.
The exploded view / parts list is here.
If the hinges are not secure, the door may slip, which can cause leakage or failure to operate correctly.
Also, there is a bulletin about these regarding the door locking _closed_ but maybe it's applicable in this case, too.
Here's the text of the bulletin:
KitchenAid & Whirlpool Electric Wall Ovens And Dual Fuel Range
MODELS: KEBC101K, KEBC107K, KEBC141K, KEBC147K, KEBC171K, KEBC177K, KEBC206K, KEBC207K, KEBC208K, KEBC247K, KEBC276K, KEBC277K, KEBC278K, YKEBC107K, YKEBC177K, YKEBC208K, YKEBC278K GBD277PD, GBD307PD, YGBD307PD, GMC275PD, GMC305PD, RBD245PD, RBD275PD, RBD276PD, RBD305PD, RBD306PD, RBD307PD, AND KDRP407HS
PRODUCTS BUILT BETWEEN CODE DATES: XP22 - XP29
CONCERN: Error Code "F5 E1" or "F5 E7" (door latch not unlocking the door after self-clean cycle).
CAUSE: This problem is caused by defective material in the core of the solenoid on the door latch. The solenoid works properly at normal temperatures, and at the beginning of a self-clean cycle. However, when heated, the plastic core binds the metal plunger, and will not allow it to unlock at the end of a cycle. Once cooled, the solenoid will again work properly. When a technician inspects the solenoid while it is cool, it will function normally.
SOLUTION: Replace the solenoid with service solenoid #4452224.
Posted on Sep 24, 2013
  • William Miller
    William Miller Sep 24, 2013
SOURCE: Oven door stays slightly open
The unit may be out of plumb ( square to the floor ). I suggest you get a level and make sure the stove/oven is level and if it's not, there are some levelers ( where legs would be on the bottom ) that can be adjusted with needle nose pliers or a cresent wrench. If this doesn'e work, you may have some hinges sprung and need to replace them. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
  • 619 Answers
SOURCE: Oven door stays open
Hi , the oven dorr needs ajustment , lose some attachement bolts ,then close the clearance will shut , so open gently and tightened the bolts.
Posted on Jan 22, 2008
tzweeb
  • 318 Answers
SOURCE: Jenn-Air electric wall oven door opens slightly when in bake mode
you either have a bent door hinge or a broken door spring.
check the hinges by opening the door and see if it opens past 90 degrees. if it leans towards the floor then the hinges are bent.
if not then your door springs are broken off. you can check this by seeing if the door "feels" heavy when opening.
either way the door should close tight against the frame when up and the light should not come on without opening the door.
Posted on Jan 22, 2009
  • 25 Answers
SOURCE: Last year, my 8 year old Whirlpool oven door would
Are you replacing the hinge guides as well? The hinge is usually only one half of the problem. When you remove the door, look into where the upper long arm of the hinge resided. You will see a little runner wheel. Touch it with a thin screw driver and see if the wheel feels loose. I'll bet at least one of them is!
Posted on Jun 25, 2009
  • 157 Answers
SOURCE: oven door will not stay closed
replace hinges
Posted on Jun 30, 2009
Oven door won't quite close tightly. I can push it about another 1/4 inch to close it completely.
You need to replace the hinges in the door. Go online to a spares website and enter make and model and order new hinges. You can replace them by unhooking the door, just takes a little effort, you might need to flick back latch on hinge and lift out. Remove inner door panel, usually 4 screws and remove. then change hinges. The 2 big pieces are the hinges.
  • images?q=tbn:and9gcsg1plmaxnucdapg-xpimmjauz_p4kgblmyf6iotcmgyh-hv4v3
Mar 09, 2011 | Ovens
How to remove door for whirlpool oven RBS305PDB2
open the door about 1/3 of the way and lift it off the hinge pins. it helps to have two people do this. when it is time to replace it, put the hinges in that 1/3 open position and slide the door back down on.
Oct 02, 2009 | Whirlpool RBS305PD Electric Single Oven
Oven door will not close completely stays open about 1/4 inch
Hinges may need to be replaced. Rule of thumb, if one is changed, change the other as well. Also try WD40 open and close continuously, it may be stuck. But you will eventually have to change the hinges. Good luck.
Sep 03, 2009 | Bosch Ovens
Door will not stay closed completely
if the seal is meeting the frame it will be ok, if there is a gap allowing air to escape then the frame itself may have been bent at some pric
Aug 10, 2009 | KitchenAid 27 in. Built-in...
Jenn-Air 30 in. Electric Wall Overn jjw8530ddw
lendebr is right...
Same problem here on combo microwave and convection oven. The hinges are a horribly wimpy design. Jenn air has a replacement part thats helps..but the replacment hinges will do the same thing in very short order. 1 month after I fixed ours my sister in law opened the oven door and let go of the door when it was about 2/3 open and that was all it took to tweak the new hinges so the door doesnt close all the way again. i should have clued in when the girl at Jenn air sent me three sets of replacement hinges. I thought it was a mistake..turns out she knew it wasnt going to fix it permanently.
The moral is that Jenn air appliances are POS and I will not ever buy anything from the again..But I will tell everyone I possibly can not to buy anything from them.
Jan 08, 2008 | Jenn-Air 27 in. Electric Single Wall Oven...
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Whirlpool GBD307PDS Electric Double Oven
Oven door does not close
I had the same problem. The first time the Tech. came out, put a new hinge in and it held until Nov. 07. ( 8 months ). Then the left hinge brakes when I opend the door and it crashes to the floor. Bending the right hinge and the metal doorliner. Jan.7,08 everything was fixed. On 1/11 after no more then 10 openings & closings the hinge broke again. This time I heard the crack of the braking metal after opening the door 2 inches. It now sits in my kitchen propped-up with a stick, waiting for the repairman. I am sorry I have no solution , but there must be a problem with the hinges. I forgot to tell you that it started with a door that did not close, like yours.
Ingrid
Jan 06, 2008 | Jenn-Air JJW8230D Electric Double Oven
Ovens Logo
85 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
