Question about Car Audio & Video
Beeping noise when playing radio/cd?
I have just got a Peugeot 206 (2005) and whenever I try to play a CD or put the radio on, a loud beeping starts and doesn't stop until I turn the cd/radio off. Any ideas/how to fix? Many Thanks
    New Friend:
  • 8 Answers
Sounds like the unit will have to be reprogrammed with the cars VIN number. Your Peugeot dealer can do this for you.
Posted on Jul 23, 2013
MediaMan85
  • 163 Answers
SOURCE: cd player and hot (high temperature) CD's
As with all electronics... anything can happen (even unexplained). There are two things to think abou tin this expensive experience.
  1. 1.CD's are made of plastic and metal... excessive temperature can cause them to warp, but not as bad as the old vinyl.
  2. Mosy electronics have an acceptable operating temperature. Although the unit may work outside these limits, it is not recommended. ex:My Sony DVD R/W has a range of about 40-95 F. Being in Houston I am sure the upper limit is reached OUTSIDE the car. Inside you are probably pushing 120+.
It may not be convenient but if you have to leave discs in the car, try putting them in a case in the trunk, out of direct sunlight. And let things cool down inside the car before trying the CD player.
I have not seen this before but like I said, anything is possible.
MM85
Posted on Jul 21, 2008
  • 53 Answers
SOURCE: "err" with CD player
it sounds that your lens could be damage or your loading mechanism, 1st try using a cleaner to clean the lens if that does not work , your either need to get the factory stereo service or start thinking of a new radio
Posted on Jul 13, 2009
kenw392
  • 2226 Answers
SOURCE: A Clarion car radio cd player in an 206 Peugeot
the cd mech. is bad. you need to replace the cd mechanism.
Posted on Sep 18, 2009
  • 4915 Answers
SOURCE: E20 error code
E20  error is a problem with the focus on the CD reader.
If the error only occurs on one CD then it's most likely a problem with a smudge or scratch on that CD and not the CD player  lens .
Try cleaning the CD thoroughly with iso-propyl alcohol
Posted on Nov 06, 2009
  • 90 Answers
SOURCE: beeping sound in the background of the radio music
Hi
Looks like the sound suppressor which is connected between the player and the battery has failed.
Usually found on the RED wire connecting to the power supply close to the battery.
You will need to change this.
Regards
Berry
Posted on Feb 01, 2010
Why has the cd player has stopped working,it only goes from tape to radio and back again.
Do you have a digital display? Are there any lights on the player to tell you it is playing? Have you tried to open the CD drawer? There might be a button on it, so you can put a CD in it. I suggest you try to put a CD in it, because it might play automatically when you insert a disc. If that doesn't work, come back and let us know.
Apr 27, 2014 | 2004 Peugeot 307 1.6
Makes beeping sound
It means that radio wasn't coded to you car - you'll have to visit a dealer or someone with peugeot planet (or diagbox) interface, and have your car's VIN coded into your radio.
Jul 26, 2013 | 2005 Peugeot 607 2.2
I bought a second hand radio/cd player for my citroen berlingo from a scrap yard when i turn it on i get a loud beeping noise although the radio/cd work
The Car VIN number has to be Security Linked ..from car radio to your car`s ECU
Can only be dealt with by your Main Dealer or a Radio Decoding Service only
Apr 03, 2010 | Car Audio & Video
Radio/cd
I bought a new deck
Jan 05, 2009 | 2006 Ford Focus
Dvd drive not working
Typically, the grunting would indicate a bad drive. Replace it. They're fairly inexpensive nowadays ($20-$30).
Jan 03, 2009 | Siemens Computers & Internet
CD Changer noise
That sounds like a bad ground wire. You may have mice eating wires. Try gently shaking the changer to see if its a loose connection. the noise will go away if its a loose connection there. if not it may need a pro to find the wire problem. if you have access to the cd changer wiring, unplug it entirely and see if the noise goes away.
Feb 02, 2018 | 2002 Volkswagen Beetle Turbo S
2 questions
Hold down the Display/Menu function button (one of those three buttons on the left of the unit) for about 3-4 seconds until the display reads "t set". When this appears, push the track forward button once (>>|) so the display reads "beep"; now press the play pause button (>||) once. The display will now say "on", push the track forward button (>>|) once to make it read "off"; now push the stop play button. You're done. Enjoy the silence.
Mar 14, 2008 | Sony Walkman D-EJ100 Personal CD Player
How do I make my alarm on my Bose Wave Radio play the FM Radio instead of the usual beeping noise?
When you choose the alarm button on the back row of buttons in the middle you get 4 options, no alarm, beeping, music, beeping & music. These are represented by icons on your front panel the note and the ))) sign.
Regards
Derek
Dec 20, 2007 | Bose Wave Radio
Car Audio & Video Logo
146 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
