Question about Ovens
Whirlpool GMC275PDB1 microwave oven combo
My oven door wouldn't close completely (about 1/2" gap)and left the oven light on. I replaced the door hinges, and it worked beautifully for 2 days. Something happened and now the door stays open about 2 inches and, when opening completely, it drops down beyond where it normally sits. I don't know if the new hinges are defective or if something else may be causing this issue.
SOURCE: Oven door stays slightly open
The unit may be out of plumb ( square to the floor ). I suggest you get a level and make sure the stove/oven is level and if it's not, there are some levelers ( where legs would be on the bottom ) that can be adjusted with needle nose pliers or a cresent wrench. If this doesn'e work, you may have some hinges sprung and need to replace them. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
  • 619 Answers
SOURCE: Oven door stays open
Hi , the oven dorr needs ajustment , lose some attachement bolts ,then close the clearance will shut , so open gently and tightened the bolts.
Posted on Jan 22, 2008
  • 23 Answers
SOURCE: Oven door will not close completely stays open
Hinges may need to be replaced. Rule of thumb, if one is changed, change the other as well. Also try WD40 open and close continuously, it may be stuck. But you will eventually have to change the hinges. Good luck.
Posted on Sep 04, 2009
apart4u
  • 213 Answers
SOURCE: top door of Whirlpool oven Model RB770PXT will not stay 1/2 open
this sounds as though the hinges are worn this might help http://www.apart4u.co.uk/video-tutorials.html
Posted on Jan 12, 2010
  • 189 Answers
SOURCE: kenmore 790.49073400 oven door won't close completely
Hello- You are on the right track. The hinge assemblies are 'sprung' or bent out of shape. Replacing them is pretty easy, so you can do it yourself. Four screws on each side. Be careful, these springs can snap closed and bite ya. Use the little pins that come with the new set to lock hinge so this doesn't happen. Let me know if this info helps- have more if needed- Thanks- Ed
Posted on Mar 19, 2010
Door stays open about 2 inches
Replacing the hinges is risky because you need to be 100% sure the new hinges go back in the exact spot the old ones were.
Otherwise, there might be leakage, which can lead to arcing and possible fire.
The exploded view / parts list is here.
If the hinges are not secure, the door may slip, which can cause leakage or failure to operate correctly.
Also, there is a bulletin about these regarding the door locking _closed_ but maybe it's applicable in this case, too.
Here's the text of the bulletin:
KitchenAid & Whirlpool Electric Wall Ovens And Dual Fuel Range
MODELS: KEBC101K, KEBC107K, KEBC141K, KEBC147K, KEBC171K, KEBC177K, KEBC206K, KEBC207K, KEBC208K, KEBC247K, KEBC276K, KEBC277K, KEBC278K, YKEBC107K, YKEBC177K, YKEBC208K, YKEBC278K GBD277PD, GBD307PD, YGBD307PD, GMC275PD, GMC305PD, RBD245PD, RBD275PD, RBD276PD, RBD305PD, RBD306PD, RBD307PD, AND KDRP407HS
PRODUCTS BUILT BETWEEN CODE DATES: XP22 - XP29
CONCERN: Error Code "F5 E1" or "F5 E7" (door latch not unlocking the door after self-clean cycle).
CAUSE: This problem is caused by defective material in the core of the solenoid on the door latch. The solenoid works properly at normal temperatures, and at the beginning of a self-clean cycle. However, when heated, the plastic core binds the metal plunger, and will not allow it to unlock at the end of a cycle. Once cooled, the solenoid will again work properly. When a technician inspects the solenoid while it is cool, it will function normally.
SOLUTION: Replace the solenoid with service solenoid #4452224.
Jul 23, 2013 | Ovens
I Have a Whirpool Microwave Oven Combo Model RMC305PDQ1 sometime when the oven is cooking the oven latch closed and we can;t open
Despite what the owner's manual says, you should not open a microwave door when it's cooking. You should press the Pause or Stop pad first. Otherwise, you will shorten the life of your door switches.
If you're ever unable to pen the door, then you have a problem with the door latch, spring, etc. that needs to be investigted and corrected.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Feb 27, 2013 | Whirlpool RBS275PD Electric Single Oven
I have a Whirlpool double oven GMC305PRS01 when you turn on the oven it appears to me making all the right move IE it goes into pre heat and starts counting down but the elements are not getting hot.
Member Discussion on Whirlpool GMC305PRS01 Microwave Oven
Whirlpool Wall oven/microwave combo unit Door message
Does anyone know where the 15 amp fuse is? I replaced the 20amp fuse and it worked for a minute or two and then I opened the door and I blew my circuit breaker. I reset my circuit breaker, replaced the 20 amp fuse and now all I get is the Door message. I also noticed that it fused the outside switch on the right side of the door so I had to open the switch up and un-fuse it. This is for a whirlpool GMC305PRS01 Wall Oven/microwave combo unit.
Also if anyone could tell me the correct position the wire is supposed to be hooked up on the switches? I had someone help me take the switch out and they unhooked the wires and now we aren't sure how they are supposed to be hooked up. My light on the microwave doesn't work either. Is it possible the bulb blew when the fuse blew?
Nov 22, 2010 | Whirlpool GMC305PRS Stainless Steel...
My daughter did something to the door... when you close the door and set the time and start the display reads 'DOOR' as if it isn't closed and it won't start. Thanks for any assistance. Whirlpool...
i have seen this a few times. the m/w portion has seperate fuses and sometimes the cartridge fuse can be blown. it is located inside the top above oven. hard to get to without pulling the unit and getting the top off of unit.
others have had a failure in the microwave control board.
Jan 10, 2010 | Whirlpool GSC308PRS Stainless Steel...
Door will not stay closed completely
if the seal is meeting the frame it will be ok, if there is a gap allowing air to escape then the frame itself may have been bent at some pric
Aug 10, 2009 | KitchenAid 27 in. Built-in...
Kitchenaid Superba microwave oven combo close door error
turn off the main power outlet it will work.
Feb 09, 2009 | Ovens
OTR Microwave Magnetron Fan and Interior Light Run with Door Open
Could be a defective door interlock or control board.
Mar 06, 2017 | Ovens
Whirlpool RMC305PDQ1 Oven-Microwave Combo Unit
is this model mounted over the oven as one piece unit?or does it hang above the stove?
Feb 20, 2008 | Whirlpool RBS275PD Electric Single Oven
to check the element it is most likely burnt out
Jan 24, 2008 | Whirlpool GBD277PD Electric Double Oven
Jenn-Air 30 in. Electric Wall Overn jjw8530ddw
lendebr is right...
Same problem here on combo microwave and convection oven. The hinges are a horribly wimpy design. Jenn air has a replacement part thats helps..but the replacment hinges will do the same thing in very short order. 1 month after I fixed ours my sister in law opened the oven door and let go of the door when it was about 2/3 open and that was all it took to tweak the new hinges so the door doesnt close all the way again. i should have clued in when the girl at Jenn air sent me three sets of replacement hinges. I thought it was a mistake..turns out she knew it wasnt going to fix it permanently.
The moral is that Jenn air appliances are POS and I will not ever buy anything from the again..But I will tell everyone I possibly can not to buy anything from them.
Jan 08, 2008 | Jenn-Air 27 in. Electric Single Wall Oven...
Ovens Logo
29 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
