Question about Razer Video Game Consoles & Games
Usb power surge
USB port got knocked with mouse in, now neither the port nor the mouse work, claimed a "USB power surge" and no idea what to do.
babb
  • 104 Answers
SOURCE: Power surge on hub port error msg
The printer is the problem, obviously but, also try using a different USB cable to see if that doesn't help! When plugging up th cable, look for anything out of the ordinary! If changing the USB cable doesn't resolve the situation then it could be something shorted out in your printer and you need to take it to a service shop for repair! regards, babb
Posted on May 15, 2007
jackboy
  • 2985 Answers
SOURCE: Power surge on USB port
This appears to be a PC problem-
Disconnect all other USB devices then try
Come back
Posted on Jun 10, 2008
  • 1019 Answers
SOURCE: power surge on usb port
unless your a very competant motherboard components repairer.
this is beyond repair. i,d suggest taking it to a repair centre, where they will replace the motherboard. and unfortunately a large invoice to go with it. probably more cost effective to look at a replacement laptop.
Mike @ Compurepair.
Posted on Jul 31, 2008
SOURCE: Mouse Doesn't Work in PS/2 port
CHECK BIOS TO MAKE SURE IT DID NOT TURN ITSELF OFF WHEN YOU PLUGGED IT INTO THE USB.BIOS MAY HAVE TURNED IT OFF TO PREVENT A CONFLICT.RICHARDM69
Posted on Dec 07, 2008
SOURCE: Western Digital Passport 160 GB external HD won't load.
WinXP SP2 blocks the use of the drive because it thinks it draws too much power. But there is a simple procedure to override this (from WD site):
"Problem:
Under Windows XP, an error message of "Power Surge on Hub Port" or "USB device has exceeded the power limits of it's hub port" is displayed when connecting a USB device to a USB port on a computer or Hub.
Cause:
Under some computers, USB devices are only allowed to draw a maximum of 500 milliamps (mA) per connection from the USB port on the computer system or from a USB hub. Under the Windows XP Operating System, with the release of Service Pack 2, if a device attempts to draw more than this (500 milliamps), a USB port balloon message is displayed to indicate this over current condition. When connecting a USB device that draws power from the USB bus, a very brief over current condition is sometimes detected by the OS, and the warning message is displayed.
Resolution:
This message has no affect on the functionality of the USB port. The USB hard drive should still function correctly on the USB port regardless of the error message. To prevent the USB Power Surge Alert message from displaying, please complete the following steps:
Click on Start.
Click on Control Panel.
Double-click on the System Icon.
Click on the Hardware Tab.
Click on the Device Manager button.
Click on the + next to Universal Serial Bus Controllers to expand the selection.
Right-click and select Properties on any listing that displays USB UNIVERSAL HOST CONTROLLER.
Click on the Advanced Tab.
Check the box that says: Don't tell me about USB errors."
This works fine, and the drive works fine afterwards. I suspect it actually draws less power than they say. Maybe it has a brief power draw spike on startup, but it's running power seems less. In any case, it works fine without the Y cable. I do think it is tacky that WD doesn't give the cable for free, since my $7 Sabrent 2.5" Hard drive enclosure came with a y cable.
But most likely the drive will work fine for you. It is a lovely quiet drive, and takes up no space at all.
Posted on Mar 20, 2009
Gaming mouse cannot detect
try to plug into every usb slot... see if your mouse can still work or not... but i recommend you to bring that mouse and claim for it warranty....
ps; if you plug your mouse into the PS/2 port, u need to restart your pc. i hope this will help you.
Jun 13, 2012 | Computers & Internet
My computer suddenly started signaling that a power surge problem, a usb hub has exceeded the power limits. i was told to uninstal the usb ports and install again. i did and starts to work when i plug in a...
If you are using a usb hub it could be the problem; try disconnecting the hub. Try to plug the pen drive into a usb port on the pc not on a hub. If the usb hub has a separate power supply make sure it is working. Hope I was of some help, Thanks for using FixYa
May 11, 2011 | Computers & Internet
My HP mouse is plugged in and the red light is on but I do not see the arrow on the screen. What is wrong?
Hmmm... if you are using a different mouse on the same pc and it works odds are your HP mouse is fried. Just out of curiousity and to confirm that the USB port that the HP mouse was connected to is not damaged, insert the Logitech wireless USB receiver into the HP's port and see if it still works.
If it does I suggest replacing the HP mouse. There are a number of factors that could've killed the mouse from USB power surge to rough handling, etc.
BD
Sep 02, 2010 | HP (A2839B) Mouse
I am getting a power surge on th ehub port
Uninstall the SP2, or just mouse over the START menue and right click then chose properties then costumize then find the power surge then thick ALways hide...i beleive there is un update for this but you will need to llok for it as it is bug in windows.
Apr 29, 2010 | Panasonic CF30 Notebook
The USB port on my DELL Latitude C400 does not recognize the mouse
try to use otehr usb ports on your computer. check if the light on the bottom of the mouse lit up. open device manager. under mouse - delete otehr mouse components then restart computer.
Mar 08, 2010 | Dell Latitude C400 Notebook
Hp nx6110 laptop error power surge on hub port
OK if you have anything plugged into the USB Ports at bootup, unless Keyboard or Mouse, remove everything, and see if it boots normally, if it does, then the "Hub" you are using may be faulty, or a device you are using is drawing a lot of current at switch on and overloading the USB bus, that can only supply 500mA. If it still does it, and you do use a USB KB & Mouse, then remove them one at a time & reboot, between, and see if it was one of them causing the problem. If you have nothing attached then your internal USB bus is flaky.
Feb 16, 2010 | HP Compaq nc6120 Notebook
When i plug my usb mouse or the webcam on my new motherboard my PC does not open,.while the ps2 mouse it works,.moments ago i restart the PC and it has a message POWER SURGE ON HUB PORT!!.HOW can i solve...
you are connecting your mous mous or web cam through a usb hub which is not having power to run the device instead you should attach a device directly to the system or use a hi speed usb 2.0 hub
Sep 16, 2009 | XFX GeForce 6200 Graphic Card
Some USB devices draw excessive power from the USB port, especially USB scanners. When this happens you need a powered USB hub, connect this to your computer's USB port and connect the USB device into the powered USB hub, you should not have any further error power surge problems.
Apr 27, 2009 | Compaq NX6110 TFT XGA Notebook
Power surge on hub port on my computer
Try unplugging everything from the hub and if that doesn't work then disable the hub.
You can either buy a new hub or buy a USB card. Both get the same results.
Oct 22, 2008 | E-Machines eMachines Desktop PC
Mouse and keyboard not working / recognized by computer
If its an USB keyboard and mouse, try to insert keyboard in upper port and mouse in lower port USB.
Sometimes when they Both are inserted in port in same line, they are unable to Fetch equal amount of power.
Try this and do restart your computer, after inserting them in USB ports.All the Best
Jul 02, 2008 | E-Machines T3624 PC Desktop
Video Game Consoles & Games Logo
61 people viewed this question
Top Razer Video Game Consoles & Games Experts
James Wishart
Are you a Razer Video Game Console and Game Expert? Answer questions, earn points and help others
