Question about Dexter 9857-147-001 - Ir Control Board
Repair where can I gets parts for this control board, I need a motor relay
    Problem Solver:
  • 13 Answers
Did you try a parts store or wear you bough it is the relay on board or on the motor
Posted on Jul 24, 2013
Testimonial: "the relay is on the board and I have tried everywhere, parts stores, repairs shops that wont sell me parts. to emron themselves. the dryer manufacturer will only sell me a complete board for over 500.00. I did find a complete board for 395.00 still I think I can repair it myself without having to send the board in."
What does flashing red LF mean on freezer
Kenmore Refrigerator Error Code = Er 1F
Error Condition = The fan for the ice compartment failed
Repair or Check = Icing fan blocked - ice fan motor is defective - wiring in the circuit is defective - control board has failed
Parts Needed = Ice fan motor - Wiring harness - Power control board
Kenmore Refrigerator Error Code = Er IF
Jul 05, 2017 | Washing Machines
What does LF flashing red mean
My treadmill not running after 7 seconds diplay shows L5
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
It is common to see this error as and L5 error, but it is actually an LS error. The following information will define this error and give you the possible solutions to fix this issue.
LS Error with No Belt Movement on Landice Series Treadmills
LS Error on Landice L-Series Treadmills with No Belt Movement Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. If this error occurs with no belt movement, the causes for the LS or L5 error are:A) Faulty upper display board or faulty relay board
B) Improper speed control wiring
C) Improper motor control wiring
D) Worn or faulty motor brushes
E) Faulty pwm/relay combo board or faulty drive motor
Corrective Action A) Enter Open Loop Speed mode and set treadmill speed to confirm proper line voltage to pwm board and that the green BELTSW light is lit on the relay board. Replace upper display board or relay board if necessary.
B) Inspect speed control wiring and correct wiring if necessary:
  1. Checking purple wire from V+ on pwm board to P3 on the relay board
  2. Checking orange wire from P1 on pwm board to P1 on the relay board
  3. Checking brown wire from P2 on pwm board to P2 on the relay board
  4. Confirm P3 on pmw board has no connection
C) Inspect motor control wiring, checking wires from motor to A+ and A-. Correct wiring if necessary.
D) Inspect motor brushes verifying brushes slide freely, are at least 3/8" long, are curved and have no burns or cracks. Also check the brush springs and verify that the brush copper wire is not burned or broken. Replace both motor brushes if necessary.
E) Inspect motor turns and is not seized up or has a broken shaft. Replace motor if necessary. Also verify at least 90VDC present from the black (A+) wire and white (A-) wire from the pwm board to the drive motor. If voltage is present, replace pwm/relay combo board. If no voltage present, replace drive motor.
Details about LS Error on Landice Series Treadmills with Belt Movement
LS Error on Landice L-Series Treadmills with Belt Movement Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. This error can occur with belt movement but speed will not increase. Causes for the LS or L5 error with belt movement are:A) Speed sensor is out of adjustment
B) Speed sensor is damaged or faulty
C) Display cable is damaged or faulty
D) Improper speed control wiring Corrective Action A) Speed sensor should sit parallel with the flywheel and gap between speed sensor and flywheel should be within 1/16". Adjust speed sensor if necessary.
B) Inspect speed sensor connector to relay board. Check for pushed pins or loose wires. Repair or replace speed sensor assembly if necessary.
C) Inspect upper harness or display cable connector to relay board. Check for pushed pins or loose wires, giving specific attention to pin 5 (brown) and pin 9 (green). Repair or replace display cable if necessary.
D) Inspect speed control wiring:
Correct speed control wiring if necessary.
Oct 13, 2015 | Exercise & Fitness
I am getting a F01 code on my whirlpool duet steam Dryer. MOD: WGD9600TWO
The F01 error indicates a primary failure of the control board. Try unplugging the dryer for a while (20-30 minutes); this will reset the control board if the problem was caused by a power surge. This will reset the internal breaker on the dryer. If the error recurs, the main control board needs to be replaced. However, you should inspect the wiring and the motor just to make sure that no other parts have been damaged by whatever caused the board failure.
If the model number of your dryer is WGD9600TW0, then the control unit is part w10141671. See http://www.searspartsdirect.com/part-number/w10141671/0026/110.html . Sometimes, you can repair the old control board by soldering a jumper wire (16 AWG) across a damaged solder connection for one of the relays. However, if you aren't careful, other parts on the board may be damaged beyond repair.
I hope this helps.
Jul 23, 2015 | Whirlpool Dryers
Tappan microwave vent motor and cooktop lights not working
see this test . God bless youThis microwave oven repair is only for over the range(OTR) models. First, with microwave still installed, gain access to the control board and check for voltage from the fan relay. If you are not getting voltage from the fan relay on the control board, and your display says fan is on, then you need a new control board.
Again, this microwave oven repair is for OTR models. If you know your light bulbs are good and your display is telling you that they should be on, check the light relay on your control board. If no voltage is found at that relay, then replace the control board. Otherwise your problem is in the light socket, wiring, or wire connectors. You can get to all of that by unscrewing 6-8 screws under the unit and taking the bottom panel off.If voltage is present and the wiring that you can see looks good, then you will have to take the unit down and test for voltage at the fan itself. If the voltage is present there, then test the motor itself and/or start capacitor for the motor. The fan motor assembly will slide out of the top of the unit after you take it down and unscrew 2 screws. Below, in the list of component testing, you will see how to test the motor and start capacitor. get the part from
www.repairclinic.com
Apr 04, 2013 | Tappan Microwave Ovens
MY GE MICROWAVE WON'T HEAT
check every step and fix it God bless youOK, get ready, this micrwave oven repair can take some time. This is where you must be able to read a wiring diagram and do some "live" checks on parts. First easy check is to make sure power is coming off your control board at the MW relay. Make sure of the wires and test here, if you have 120 volts at this point, you have ruled out a lot of parts that could be the problem. You have now ruled out any switch problems, control board problems, or a thermostat or 2.
If you do not have power from that MW relay on the control board, you must trace the wiring back to see if the proper voltage is going through your switches, any thermostats, and arriving at your control board. Your wiring diagram on your sheet will show you where and what to test. Below is a general switch test troubleshooting guide.
mwswitchtest2.jpgIf the proper voltage is coming into your control board and you are not getting voltage at the MW relay, then you need to replace the control board. If voltage is interupted by a thermostat or switch from your testing to the control board, then replace that part.
Now, testing from the MW relay on to your transformer, high voltage capacitor, magnetron, and diode.Do not do any voltage reading from the secondary side of the transformer on, this can be a deadly microwave oven repair if you do not follow directions. This can result in electrocution and the "blowing-up" of your voltmeter, only do OHM testing with the power off and the capacitor discharged. Someplace in this circuit, usually before the transformer, you will have another thermostat to test. It is usually mounted on the magnetron. Do a quick OHM test to see if it is open or closed.
Now to test either the transformer, high voltage capicitor, magnetron, and diode, you must test each part separately. A good rule of thumb, if your capacitor is bad, change the diode also. Another note, if you are working on an OTR model and you have determined to be one of these "heating" circuit parts, you can not test these parts until you take the unit down. If you don't have the parts with you and you have to order them, order the magnetron, capacitor and diode and you will have a 90% chance of solving the problem. If it is an older microwave, order the thermostat also, most times you can return un-used, un-opened parts. Check with your parts supplier. This way you only have to take the unit down once.
To test these parts, scroll down this page and you will see a chart with component tests. Follow the instructions to find which part(s) are defective in your microwave oven repair.
Microwave Runs, Heats, but turntable does not move This is a fairly easy one. First, make sure the turntable coupler under the glass dish is not broken. Second, on the control board, find the turntable relay and test for voltage. Some turntable motors are 24 volts DC, so make sure your testing the correct voltage. If no voltage from the control board, then replace the control board. Otherwise head towards the turntable motor.
On OTR models, you can get to the motor by un-screwing the bottom panel on the microwave. On countertop models, there will either be a knockout or screw on access panel. Check for voltage at the motor. If no voltage, check the wiring back towards the control. If voltage, then replace the turntable motor. The component list below also shows how to test a turntable motor.
Apr 02, 2013 | GE Microwave Ovens
I have a problem with a motor control board for a wascomat washer, made by frigidare. the motor control board is part # 134149200. the thermister on the board tdr1 gets so hot it melts the solder and falls...
The NTC thermistor is a current limit device. If there is too greater load, (motor getting tight/bearing tight) too much current will pass and it will get hot.
Some have a relay that sit a contact across the NTC to stop this from happening and if the relay is faulty, it will get too hot.
Jun 13, 2017 | Washing Machines
Kenmore elite dryer 11063942101 works if I force the switch to stay in the on position but won't start by just pressing the switch. Replaced pust-to-start switch. Same problem. Vacuuming out the areas...
The problem is definitely not the motor but rather the motor relay or the electronic control. Either the motor relay is not working to close the motor circuit or the electronic control is not powering up the motor relay to serve its function.
The motor relay and the heater relay are identical and can be used interchangeably. The heater relay may be used in place of the motor relay if the dryer heats up when the start switch is held on. It indicates that the heater relay is working.
Disconnect power to the dryer then pull the end cap trims off then remove the control panel securing screws. Once the screws are removed, rotate the control panel up to the rear of the dryer.
Disconnect the wires and remove the relays then put each in the place of the other. Refer to the component layout diagram for the location of the relays.
Reconnect the wires then rotate the control panel down back into position then plug the dryer in and start it. The dryer should start and continue to run when the start switch is released since the working heater relay is used but will not heat up indicating that the motor relay is not working. Otherwise the fault is in the electronic control.
Replace the faulty component and it should address the problem. The relay (heater/motor) is part number
3405281 and the electronic control is part number W10116565.
Squeeze on the electronic control mounting bracket as shown then pull the board up to remove.
Insert the new control board and gently press it down into position. Transfer the wires from the old board to the new board one at a time.
Simply unscrew the relay to be replaced then secure the new one into position and transfer the wires.
Rotate the control panel down and secure it back into position to complete the repair.
Aug 30, 2010 | Dryers
Dacor DMT2420 turntable not rotating.
It may be a bad turntable motor or coupler, or the motor may not be getting power due to a bad connection or relay on the control circuit board (which we repair).
The service manual is here and the parts list is here.
You can order Dacor parts by part number from the Pros here.
Dec 07, 2009 | Dacor DMT2420SS Microwave Oven
Maytag Neptune MAH5500BWW Will not spin
maytag neptune washers do have a motor problem and they have a kit to replace the motor and motor controller.
when the motor fails, it wont wash or spin. most units have a 5 year parts warranty and should be replaced with a free part, but you will have to pay an authorized servicer to do this.
if it is over 5 years then i would call maytag and see if they will help you with an authorization for repair.
most of the time they will provide the part for free. just call the 800 # and ask for help. they wont send you the part but might give you some help with the parts.
Jan 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Dexter 9857-147-001 - Ir Control Board Logo
66 people viewed this question
Top Dexter Dryers Experts
Dan Webster
Dan Webster
Are you a Dexter Dryer Expert? Answer questions, earn points and help others
