Question about Brother XL-2600
Upper and Lower Thread Tangled around bobbin case
The bobbin thread doesn't seem to be catching properly and just gets tangled all around the thing that moves the bobbin (no idea what they call these things). I have changed the needle, both threads and still having the same problem. Is it possible the bobbin mover thing isn't moving properly?
  • Brother Master
  • 1,564 Answers
It is possible that the "shuttle" isn't moving properly. It's also possible that it has a burr. Since it appears that you not little to nothing about these machines I would take it in and have it serviced. Tell the service person about your problem. Ask them to clean, oil, and time it.... and look for issues with parts. it will cost you about $150 or more if it needs parts.
Posted on Jul 24, 2013
3 Suggested Answers
  • 40 Answers
SOURCE: thread is tangling on the lower bobbin
check the needle first.Bent or spurred needles will result in this action.
Posted on Jun 01, 2010
SOURCE: The lower thread is tangled. Upper thread is
The top thread is fine but the thread on the botton is a mess sometimes is has to be cut out
Posted on Sep 29, 2010
Help with Euro Pro 9000, the thread keeps getting tangled up in the bobbin area..
When I had this problem, even though I have been sewing for years, I was just not threading the needle properly. Make sure the presser foot is raised when you thread the needle. Another reason is that the thread is too old, the needle is not the correct size or type for the material, neither is the thread. Hope this helps. It's usually nothing to do with the bobbin, but the upper thread.
Jul 11, 2014 | Euro-Pro 9000 Mechanical Sewing Machine
Kenmore 158 12271
the bobbin case is not located properly. take it out check the bobbin fits fully inside it.
Feb 18, 2014 | Sewing Machines
I keep getting error E6 on Brothers CS 6000i- I cleaned the thread several times and when I try to restart sewing it happens again. I've removed the bobbin and re-threaded and it keep jammin and beeping....
The motor locked up because the thread is tangled.
Solution:
Remove the tangled thread before continuing the operation.
Clean the bobbin case to remove the tangled thread.
After cleaning the bobbin case, insert the bobbin case properly.
If the needle is bent or broken, replace the needle.
Then, thread the upper thread properly, and continue the operation.
Dec 21, 2013 | Brother CS-6000i CS6000i 60-Stitch...
Machine is showingE6
The motor locked up because the thread is tangled. Remove the tangled thread before continuing the operation.Clean the bobbin case to remove the tangled thread. After cleaning the bobbin case, insert the bobbin case properly. If the needle is bent or broken, replace the needle.Then, thread the upper thread properly, and continue the operation.
brother sewing machine
Sep 22, 2012 | Brother CS6000i Computerized Sewing...
The cotton keeps getting caught up in the bobbin area
try these suggestions
1. change needle--flat side to the back of the machine
2. needle must the correct one for the fabric
3. check the bobbin to make sure it's not damaged or warped
4. check the bobbin case( the thing that holds the bobbin) to see if there
are any burrs on it or see if it's damaged is some way
make sure the bobbin case fit's snuggly into the hookrace
5.it's also possible that the machine could be out of time
Apr 18, 2012 | Sewing Machines
E6. Motor locked up because the thread is tangled. I have re-threaded machine and bobbin; thread still tangles after 2 or 3 stitches. HELP!
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
Jan 18, 2011 | Brother CE4000 Computerized Sewing Machine
I have a brother pe 770 and the bobbin will not catch the thread. The thread will wrapped and tangled up around the bobbin case and bobbin, but will not catch the bobbin at all. I chcked the needle, it is...
You need to sew the first stitch slowly. Lower the needle by hand and take up carefully. Pull the needle thread up and the bobbin thread should be caught in the formed loop and come with it. Pull them both to the back of the machine and sew.
Dec 14, 2010 | Brother PE770 Computerized Sewing Machine
I can't keep the lower thread from getting tangled. I have rewound bobbins, cleaned the bobbin case, made sure the bobbin case is in the correct position, and played with the upper thread tension. When...
Ensure that you have routed the bobbin thread properly. Also, if the bobbin case is not installed properly it will give you this problem. Ensure that the protrusion is touching the spring on the body of the machine.
Jan 27, 2010 | Brother CS-6000
Brother XL-2600 Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
