Question about Whirlpool Amana Refrigerator Water Filter WF401S
Water on floor - french door refrigerator with freezer below
Whirlpool/Amana Model AFF2534FEB4 SN K05075066 Purch 3/31/2011 Yes Icemaker in bottom freezer section; NO chilled drinking water; NO water filtration cartridge; NO water/Ice through door. Problem = Water on floor in front of refrigerator. Bottom drawer Freezer compartment has built-in 1/2" depression to collect condensation from auto-defrost cycle. Depression is full of frozen water which I remove every 1-2 days or else I end up with water on the floor. This bottom compartment has NO drain hole to let condensation water out. Using a dollar bill I verified that the freezer gasket is making 100% contact all around the door. There is an energy saver switch - when I turned it OFF - the problem seems to have stopped.
  • 4 more comments
  • Jimbo213 Jul 24, 2013
    REPOST BY ORIGINATOR:
    @KELLY; @Leo Ponder; @Greggmark1 - - -
    the model # & serial # are in the first line of my post !!!
    Ok sorry - I thought the "suggested solutions" were actual answers by Fixya pros to MY SPECIFIC posting. Now I understand they are system-generated based on key-word similarities.
    Instead of taking apart the whole freezer section, this morning I removed the lower plastic grill [which we always vacuum] and found GOBS of dust bunnies on evaporator coils and in pan. Duh - I feel so stupid. So I vacuumed that area totally with a long nozzle, removed the layer of ice and dried the freezer pan, left the energy saver switch off ... and will check again in the morning and report back.
  • John Tripp
    John Tripp Jul 25, 2013
    See you tried to contact me Jimbo is there anything I can help you answer? appliancepartsse@yahoo.com http://appliance911seabreeze.com/leaking...
  • John Tripp
    John Tripp Jul 29, 2013
    Jim have you been able to get the condensate drain open?
  • Jimbo213 Jul 30, 2013
    Apparently YES because I was able to inject 1 oz of hot water five times into the drain grate and it disappeared. Now at day 3 and ice is not forming in the lower compartment. But I was not able to really run anything like a pipe cleaner down the drain tube to clear any "gunk" because I can't figure out how to remove the upper freezer basket.
  • Whirlpool Master
  • 4,654 Answers
Yes the bottom compartment does have a drain opening but to see it you will need to remove the rear panel covering the evaporator inside the back wall of the freezer compartment. See item location number 11 on page 3 of the parts list. That will need to be removed so you can reach the drain inside the freezer compartment. The fresh food section also has a drain. Here is a=> AFF2534FEB4 Parts List and AFF2534FEB4 User Manual I am here to answer any questions you may have, Thanks Sea Breeze
Leaking Refrigerators
Posted on Jul 26, 2013
Testimonial: "John was very helpful and sent the applicable diagrams. He was not able to provide guidance on how to remove the upper freezer basket so I couldn't take the freezer compartment apart - thus I was unable to follow his disassemble / clean / reassemble instructions. Thus I'm not really sure how long the drain tube will remain clear."
  • Jimbo213 Jul 26, 2013
    Still have ice but build-up pattern shows that frig isn't level. Build-up is highest in front-left corner ... zero ice in back right corner. I'm going to level it up, remove the ice, and check again in the morning. QUESTIONS: (A) is cleaning out the hydrator drain a necessity too? (B) can you give me a guess as to how long it might take a 1st timer to do all the steps [disassemble, clear the drain, reassemble]. I am a pretty good handy-man: am I to expect 1-2 hours or 4-6 hours? Thanks. Jim
  • Jimbo213 Jul 27, 2013
    Thanks - I really appreciate the continued communication and your encouragement. It is now 2 hours since starting. Unplugged refrigerator. Dumped ice tray and left outside to dry. Turned ice maker off by moving arm up. I managed to find white clips [for want of the correct term] and was able to remove door slide [#28] after lifting out bottom basket. Removed 3 screws [#30] on each adapter slide [#29] and removed. The top basket is riding in another channel [#7 I think] that I could not remove and therefore could not remove the top basket. I re-installed the door slide & 3 screws on each side. Then I pulled top basket as far forward as I could and positioned a hair blower at the drain about 10" away and left it for maybe 20 minutes, wiping up quite a bit of water. Tried to push a 12" long cable-tie-wrap down the drain tube - but without being able to remove the back panel I couldn't really hit the drain tube [household wire didn't work either]. I did squirt about 1 oz of very hot water five times into the evaporator cover slots [#11] and I could not see it pooling up in the drain pan so I thought "success???". Replaced freezer door and lower basked. Plugged in refrigerator. I'll report back Sunday. Next I leveled the frig using the two front foot brakes [#6]. Got it perfect side-to-side. Front-to-back it is 1/4 bubble tilted toward the back. I'd still like to know how to remove the top basket. Thanks - Jim
3 Suggested Answers
  • 385 Answers
SOURCE: My Whirlpool GD5LHGXLQ02 refrigerator will not
The screws to take the door apart should be under the rubber seal "gasket" Don't pry off the front cover it will break.
Posted on Jun 09, 2011
imufo2
  • 3773 Answers
SOURCE: Have a Whirlpool refrigerator/top freezer model
Check drain in the freezer which probably runs through the Ref. Pour water in Drain in back of
freezer and see if it drains. some may be getting inside ref.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Posted on Jul 21, 2011
What causes ice build up in bottom of freezer with french doors and then leaks out
sounds to me like a bad door seals causing condensation and leakage
Aug 23, 2014 | Whirlpool Refrigerators
My bottom mount french door refrigerator, the upper part does not cold, it's warm
Sorry your having trouble so soon!
First thing you need to check is inside the freezer section.
The freezer fan, the fan is W10128551 and should be running
along with the main compressor. Since the freezer is working,
I would check the food on the top drawer or on the freezer door shelf.
They too might be soft..without the fan.
I would You tube 'evaporator fan motor replacement Amana bottom freezer model' Yes I know it say's Whirlpool, but your unit is really
a Amana designed unit. I would give this a difficulty of 3 out 5 wrenches.. Take your time..
John Wright
Jul 27, 2014 | Whirlpool GX5FHTXT Bottom Freezer French...
My whirlpool French door fridge is leaking all over the floor. The drip pan underneath is bone dry. I can't find the drain hole inside the fridge to see if it is clogged. Is letting it thaw for tw
there is a water tube connection at the bottom of door on hinge side that has a spring and allows it to swing with door. it also has a fitting there so the door can be removed.it is the tube running inside the door to the ice water dispenser. if it has one, it can leak at the fiting
Jul 07, 2012 | Whirlpool GX5FHDXVY Stainless Steel (248...
Water leaking from whirlpool gold refrigerator
When refrigerators leak water it usally is a sign that the defrost drain found inside the rear of freezer and behind the rear panel of freezer has become clogged with ice or gunk. Sometimes the pan below refrigerator has a crack and allows water to leak onto floor. Please click here=> Leaking Refrigerators Just What may Be HappeningYou will at times see water build up inside freezer bottom especially on bottom freezer refrigerators. This will take a little reading over to understand what may be happening. Click Here=> Leaking Refrigerators
I will be here should you have questions, Thanks Sea Breeze
Feb 16, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
Amana AFB2534DEW freezer is working but refrigerator is not cooling at all. I vacuumed under the refrigerator and don't know what to do next.
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Oct 02, 2011 | Amana AFB2534DE Bottom Freezer French Door...
Water leak on floor
Typically on this model the drain hole Under the evaporator cover gets clogged. Remove the cover off the rear of the refrigerator and pour hot water into the drain until it goes down quickly. To remove the cover u will have to remove all the freezer shelves and the icemaker. Remove the covers screw and u should see that at the bottom u will have a block of ice down below. The refer goes onto defrost every couple days and will leak the melted ice onto the floor
Jul 06, 2011 | Amana ABB1927DE Bottom Freezer...
I have a whirlpool refrigerator Model GI5SVAXVL01. (2 door upper- Freezer on bottom). SN K01668079 About once a week there is a puddle of water on the floor right front side of refrig. I cannot tell where...
After looking carefully at the exploded views of this refridgerator
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Refrigerator-Parts/Model-GI5SVAXVL01/1198/0161000?pathTaken=&prst=0&shdMod=GI5SVAXVL01
I believe your problem is caused by a leaking hose or fitting for the water dispenser
Pay close attention to items # 11 and 19 on the diagram labeled Refridgerator door parts
Try turning off the water supply to the dispenser and see if the problem is resoleved... if so you know thats where the problem is
Jan 21, 2011 | Whirlpool Refrigerators
Light clicking sound from outside whirlpool french
Check the fan blade on the fan in the freezer. It could be an object or ice, frost, anything. If this is an Amana Whirlpool, definitely check to see if the fan blade is no longer tight on the motor shaft and has moved forward and hitting the guard in front of it. ( yes, amana whirlpool )
May 12, 2009 | Whirlpool Refrigerators
Brand new Amana French Doors Refrigerator is too cold.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Dec 11, 2008 | Amana 25" Cu Ft French Doors Bottom...
Whirlpool Amana Refrigerator Water Filter WF401S Logo
365 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
