Question about Garden
Craftsman ys4500 I have a Craftsman ys4500 riding mower with 20hp intek engine and it won't turn over. I have checked the fuel lines as well as checked the carburetor for any debris and to see if float was stuck. I have also changed the spark plug, battery, air filter and changed gas even though it was only in the tank for a month. I have also attempted to spray carb cleaner in the intake to get it to turn over but no luck. The mower ran fine a month ago and has been stored since but now won't start though it tries to crank as if its close to turning over. Any help would be appreciated as I am hitting the wall and am out of ideas as my experience in small engine repair is extremely limited.
    Top Expert:
  • Garden Master
  • 42,623 Answers
Pull the fuel hose and check for fuel flow to the carby
check all safety micro swiitches
Posted on Mar 31, 2017
3 Suggested Answers
smartr10U
  • 1305 Answers
SOURCE: Craftsman mower with 20hp B&S Intek won't start/run
That throttle cable issue sounds like it may be the culprit. the cable housing (the outer casing for the wire throttle cable) may not be anchored correctly. Which may be allowing you to move the throttle without any change at the butterfly control on the carb. make sure the cable housing is anchored at both ends.. by the throttle control and at the carb area.. That may be your problem... hope it is that simple...
K
Posted on Jul 23, 2009
  • 11 Answers
SOURCE: I have a Craftsman 42 in. 15.5 hp lawn tractor
check an see if the cabuerator is getting fuel and check make sure sparkplug is getting continous fire from the coil
Posted on Sep 13, 2010
Craftsman 20hp lawn tractor blades won't engage
check to make sure your cable is in tact its called a pto clutch cable about 20 buck on ebay it may be broke inside
Sep 26, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman riding mower turns over but won't start
unplug the connector from the side of the engine and try it if it fires on starting fluid then the problem is one of the safety switches
Apr 22, 2012 | Craftsman Garden
I have a craftsman Dlt 3000 riding mower with a 20hp kohler v twin . engine starts and runs for 5 seconds and shuts off
no model # on my DLT3000. Replaced rear fender a few years ago where the model # used to be. I can't get the right parts w/o model #. It was by my dad sometime between '04 and '07. It's red w/42" cut, 20hp koler pro motor.
Sep 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Engine hesitates and dies when hot, restarts fine, then dies agai
Check the fuel pump.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Craftsman Garden
Craftsman YS4500 20HP mower, was mowing and it just stopped running and since it won't turn over at all, completely dead. I replaced the battery, suspect there may be a blown fuse? Where is the fuse...
under the hood right behind the stearing wheel colum there is a place for fuses and relays, you may have a bad relay or safty switch, check to make sure the seat switch is plugged in all the way that is the most common problem i see with these when they come in for repair
May 01, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
K
Jul 23, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How to remove snow blower from Craftsman YS4500 garden tractor
Go to www.managemyhome.com to download the manual for free. Just type in the model # 944606950.
May 21, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Riding mower will not start
Hi
Starter drive is stuck. Clean by spraying brake kleen on starter drive and blow drive with air. Might
have to remove starter to clean. Check for missing cogs on starter drive.
Mar 29, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
