Question about Electrical Supplies
What is spark plug no for clarke G1200
Type no of spark plug
3 Suggested Answers
SOURCE: hi, i have a clarke generator g900 ,no spark
this gen has a oil level sensor that will short the "primary" of the ignition coil as well as a spark enhancer that is called a CDI unit but the drawing does not show a Capacitor in or near it?
I hope this helps
Where did you get your replacement coil Colin?
Peter
Posted on Feb 14, 2010
i know its out of date but it sounds like the on - off (stop - run) dial at the front which is connected to a switch that make a curcuit that make the plug spark
Posted on Feb 18, 2013
Clarke 2200kw generator will not start Have changed spark plug checked flters put in fresh petrol
are you getting spark , is the on switch on , some people forget to do this
Jan 19, 2015 | Electrical Supplies
I have a clark g900/700w generator.i started up today.started ok but when i turned the choke off it started to cut out.it will only run on half choke thanks
Is the gas fresh?
Possibly stale gas is the problem
http://www.clarkeservice.co.uk/manuals/generators/g900.pdf
Has engine been serviced: clean air filter, fuel filter, spark plug.
Clean out fuel system with carburetor cleaner. Place about 12 oz. in fuel tank and run engine.
Oct 29, 2013 | Clark Electrical Supplies
Can not get a spark
Check internal fuses and breakers first. Then see if the contactors are closing. If they are not check the 24 volt contacter for coil continuity. If that is okay, check for voltage at the wire feed motor with an analog meter. Put it in a plstic bag and tape the bag where the test leads come out- there is a big magnet in the movement. Keep the meter in the bag to protect it, but check the motor to see if it is seeing power impulses from the control board. If it is not gettin pulsed power when trigger is pressed, suspect a failure of the SCRs on the control board.
Feb 07, 2012 | Clarke Power Products Clarke 130EN...
Saw motor is sparking
Most of the time sparks in these tools come from where the brushes make contact with the armature. Some causes for sparks are: The brushes are worn down to where they don't make firm contact with the armature. Brush springs overheated and no longer push the brush down on the armature. The comutator on the armature is damaged and causes the brushes to spark excessivly. You can take it apart and try to find which parts are hurt but I don't know if any Clarke Power Products parts are still available. The company went out of business around 2009 so you'd have to find someone with left over parts. It may be easier to buy new and go with a name brand and new warranty.
Jan 22, 2012 | Clarke Power Products Saws
Clarke/Honda 700 watt generator ronning slow, cleaned carb,air & fuel filter, spark plug, noticed air coming from air filter, is it a sticking valve problem
Either the intake valve is not sealing like it should, or the rings are worn, and crankcase vent is dumping the pressure into the carburetor.
Jun 23, 2010 | Electrical Supplies
Hi, i have a clarke generator g900 ,no spark
I hope this helps
Peter
Jun 22, 2009 | Electrical Supplies
Where can i buy replacement spark plug for clarke generator please
Go to your local saw shop. Hope this helps you, Rick
Apr 27, 2009 | Electrical Supplies
Electrical Supplies Logo
51 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
