Question about JBL Toyota Tundra Sequoia 6 Disc Cd Cassette 2003 04 05 A56829 - Cd Not Working
A56817 connector It has two male connectors in the back. One connectors has 20 pins (two rows of 10ea), and another connector with 12 pin (7pin upper row, 3 and 2 second row.
I need 7pin connector wiring diagram for a 2006 F150. It seems I'm not getting 12 vcd to charge the trailer battery.
The correct wiring sequence for a seven pin connector is on the back of the packaging packet This diagram is the standard for plugs in you area.
Sep 28, 2013 | Ford F-150 Cars & Trucks
Ms 7613 ver 1.1
http://bizsupport1.austin.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01946060&printver=true
View the motherboard photo at the Top, and also the Motherboard layout illustration, at a little over halfway down the page.
1) In the motherboard photo, all the way to the right side. View the Yellowish/Whitish connector, that has two columns of 12 socket holes.
This is where the 24-pin ATX main power cable plugs in.
In the motherboard layout illustration it is labeled - ATX1.
Here is a general example of this power cable, and respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Note that new Power Supply's, generally come with a 20+4-pin ATX main power cable.
This is so it can be used on the older computers that used a 20-pin ATX main power cable, and newer ones that need a 24-pin ATX main power cable.
Do not mix it's extra 4-pin power cable, with the 4-pin ATX +12 Volt power cable.
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20plus4
Note the Lock on the side/middle. It has a hook on the end. The hooked end goes over a Tab, on the motherboard's connector.
The Lock works on the same principle as a see-saw on a playground.
You squeeze the top near where the wires come in, and this brings the hooked end away from the Tab, on the motherboard connector.
With the top of the Lock still squeezed in, the power cable is then removed USING the connector. (NOT the wires)
When assured that the power cable is plugged in tightly, and correctly, the hooked end of the Lock will be over the Tab, on the motherboard connector.
2) Look to the left of the Processor socket, and halfway in-between it, and the outside edge of the motherboard.
Whitish 4-socket hole square connector.
This is where the 4-pin ATX +12 Volt power cable plugs in. Power for the Processor. Note that it also has a Lock, with a Tab on the motherboard connector.
In the motherboard layout illustration it is labeled - PWR1
General example of power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
That's it for the motherboard as for power cables that plug into it.
The rest of the power cables from the Power Supply, plug into the optical drive/s, harddrive, and card reader if used.
4) If your harddrive is an IDE (PATA) unit, it will use a 4-pin standard Peripheral power cable. Same with an optical drive that is an IDE (PATA) unit,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
The computer case fan plugs into SYS_FAN1 connector, which is below the PWR1 connector. You may also have a computer case fan that uses the above power cable.
5) If your Harddrive, or optical drive/s are SATA, they will use a SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
6) A Card Reader uses a power cable, that is also used for a Floppy Drive.
It is a 4-pin Small Peripheral power cable.
Has the same voltage wires; (Yellow - 12 Volts, Red - 5 Volts), and two Black ground wires, but a smaller connector, than a 4-pin Standard Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
The front of your computer is the Front Panel.
The area of wires on the motherboard, that the main wires from the Front panel go to, is the Front Panel header.
Although the Front Panel header has NOTHING to do with the Power Supply, I will include it also,
Motherboard positioned in computer case; Processor to the Top, Ram Memory slots to the Right;
The Front Panel header is at the bottom/right of the motherboard.
Black rectangle with 9 contact pins.
In the Motherboard layout illustration, JFP1 is marked under this header.
There are 4 pins across the Top row, 5 pins across the Bottom row.
The pins on the Top row are numbered EVEN.
The pins on the Bottom row are numbered ODD.
Starting on the LEFT side going towards the Right, Top row;
Pins 2, 4, 6, and 8. There is NO Pin 10.
Starting on the LEFT side going towards the Right, Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light Emitting Diode)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. Reserved for factory use.
D) Pins 2 and 4 are for the Power On LED.
Pin 2 is for the Positive ( + ) wire.
If the PWR ON LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) Again, there is No Pin 10.
For additional questions post in a Comment.
Regards,
joecoolvette
Aug 15, 2012 | HP Computers & Internet
Need diagram for connection on motherboard 4006272r
Gateway 4006272R motherboard;
Foxconn (Bengal) RS780 motherboard.
[ In otherwords the motherboard chipset is an AMD RS780 series,
http://en.wikipedia.org/wiki/AMD_700_chipset_series#780G.2F780V
http://en.wikipedia.org/wiki/Comparison_of_AMD_graphics_processing_units#Radeon_R600_series
Scroll down to the bold black subheading - IGP (HD 3xxx, HD 4xxx ]
This motherboard,
http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rnv.shtml
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
In the list click on -> Product Views
Now click on -> S - Front Panel Connector
Motherboard installed in the computer case, the Front panel header is at the Bottom/Right corner.
It has -> F_PANEL <- silkscreened in white underneath it.
Two rows of pins.
Starting on the LEFT side, coming across to the Right;
Top row;
Pins 2, 4, 6, 8, No pin, 12, and 14.
Bottom row;
Pins 1, 3, 5, 7, 9, 11, and 13.
Pins 11, 12, 13, and 14 are NOT USED.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
These pins are in the Orange blocks.
These pins are in the Blue blocks.
Black block.
D) Pins 2 and 4 are for the Power On LED. (Light)
These pins are in the Green block.
These pins are in the Red block.
F) There is NO Pin 10.
Black block.
Again, Pins 11, 12, 13, and 14 are Not Used.
B- CPU Power Connector is at the upper left corner of the motherboard. This power cable is power for the Processor.
MUST be plugged in.
A general example of a 4-pin ATX +12 Volt power cable, and it's respective connector on the motherboard,
Note the Lock on the side of the power cable's connector, and matching Lock Tab on the motherboard connector.
F- Main Power Connector also has a Lock, and Lock Tab.
General example of a 24-pin ATX main power cable, and it's respective connector on the motherboard,
D - CPU Fan Connector is above the processor socket, and near the top outside edge of the motherboard. ONLY plugs in one way.
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 10, 2012 | Gateway Computers & Internet
DID this HDD (Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive) can atach in ASUS K8U-X, Thank you, Nikola
ASUS K8U-X - motherboard - ATX - Socket 754 - ALi M1689
1.0 x PCI - Socket 754,
2.0 x Processor - DIMM 184-pin,
4.0 x AGP 8x,
1.0 x Memory
  • Storage Interfaces ATA-133 - connector(s): 2 x 7pin Serial ATA - RAID 0 / RAID 1 / JBOD,
    Serial ATA-150 - connector(s): 2 x 40pin IDC
  • Interfaces 1.0 x Keyboard - Floppy interface - RJ-45,
    1.0 x Hi-Speed USB - SPDIF output - 6 pin mini-DIN (PS/2 style),
    4.0 x Network - Generic - 34 pin IDC,
    1.0 x Audio - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25),
    1.0 x Audio - Ethernet 10Base-T/100Base-TX - 9 pin D-Sub (DB-9),
    1.0 x Parallel - Generic - 4 pin USB Type A,
    1.0 x Serial - RS-232 - 6 pin mini-DIN (PS/2 style),
    1.0 x Storage,
    Mouse
  • Power Connectors 20-pin main power connector,
    4-pin ATX12V connector
  • as long as the PSU and motherboards power and lead connections are the same as the hard drive
    hope this helps
    May 10, 2011 | ASUS K8U-X Motherboard
    Missing power supply. First, thanks to fredtmccoyjr for the boot fix. the BIOS update from A06 to A09 actually allows me to enable boot from harddisk in the settings, instead of settign a useless tick on...
    It was the 1996 to 2000 time frame, that Dell was proprietary with the 20-pin ATX main power cable, and the matching connector on the mobo. (MOtherBOard).
    Standard 20-pin ATX main power cable, and it's corresponding connector should work, then add the 4 power wires that are missing, in a separate connector.
    To expound:
    View this standard 20-pin ATX main power cable, and it's respective connector,
    The power wires should be in the same place as your P3 units.
    (Match the color codes.
    Use the lock tab on the 20-pin ATX main power cable connector, to base where the pins are.
    Pins 1 though 20. Match the color code of the wires to the pins, and use the chart to compare)
    Here is a view of a standard 24-pin ATX main power cable, and it's respective connector, so you can see what power wires are missing, from the 20-pin ATX main power cable connector, that are present in the 24-pin ATX main power cable connector.
    Note the missing power wires, and what pins they line up with.
    The P4, or also stated as the 4-pin ATX +12 Volt power cable, uses two Yellow (12 Volt) wires, and two Black wires, (Ground)
    Since you don't have the male connector, be sure to orient in your mind where the Yellow (12 Volt) wires go, and the Black (Ground) wires go, by looking at the lock tab on the side of the female connector, on the motherboard, and comparing it to the photo.
    Transfer this info, to the P4 connector you are going to make.
    Where to get the power wires you need? Connect to any extra 4-pin Peripheral power cable wires, or splice off of ones that are in use, is one suggestion.
    The links given are near the middle of the page. Scroll back to the top. Left-click on any power cable connector, that you wish more information on.
    More info,
    http://en.wikipedia.org/wiki/Computer_power_supply
    Scroll to the bottom of the page, and look at the chart under the heading -
    24-pin ATX12V 2.x power supply connector
    (20-pin omits the last four: 11, 12, 23, and 24)
    One more link,
    http://www.smpspowersupply.com/connectors-pinouts.html
    Lastly Dell Support > Optiplex GX260 > Service Manual,
    http://support.dell.com/support/edocs/systems/opgx260/en/sm/index.htm
    Just in case it's of any use.
    Have questions regarding what I have stated, or need more clarification of anything I have stated, simply post in a Comment.
    Jul 06, 2010 | Dell OptiPlex GX260 PC Desktop
    Pulling check engine codes on 1984 el camino
    Locate your aldl connector under dash near steering column. It should have 12 pin connector. Older cars had 8 pin connector. You can do either one. On 12 pin connector jump the last 2 pins, on top row, in connector with paperclip or wire. Turn on ignition till check engine light turns on. Count & write down how many times it flashes. It will flash for example 3 times stop then 1 time = 31 code. In older 8 pin connector jump the 2nd & 4th pins on top.
    Jun 15, 2010 | 1984 Chevrolet El Camino
    Came with 2 cables for attachment - on longer type with 2 sets of pins to middle and one side and another smaller with 2 rows of pins - problem is monitor has 2 places to attach but the smaller has 3 rows...
    The monitor comes with DVI and VGA (DB15HD 3-ROW HIGH DENSITY) connectors. If your PC only have VGA (DB-15HD) output for the monitor, then you need to use VGA cable (DB-15HD Male to Male) for connection. Hope I explained clearly.
    Apr 01, 2010 | ViewSonic VA712B 17" Flat Panel LCD...
    Orange & white power sw cord needs to be connected to mother board need to know where it goes
    Count the number of hole that the SMPS female connector has. It would be in two rows. Look for an opposite male connector with pins in two rows. Number of pins should be the same. There is only one such male connector. Set the female connector on its counter partin such a way that the locking pins of one go into the locking slot of the other.
    Aug 23, 2009 | EliteGroup P4VXASD2 Motherboard
    4pin blue modular plug under dash for brake controller to plug in
    You should be able to access the Prodigy Instructions ie Wiring Diagram At google. Maybe an install video on You Tube. Make sure everything you do is properly fused. Any thing as far as color codes will need to be Prodigy specific. Prodigy may have a 1-800 Tech line. They should be able to E-mail you a PDF file.
    Feb 28, 2017 | 1999 Dodge Ram
    Mother Board connection
    Go to the site below. Its a manual for the 800/i65GV group. Go to page 67 and zoom in. You'll get a nice look where everything goes. Two rows of pins. Upper row and bottom row. Real close to each other. Do not place connectors up to down. Connect only left to right.
    The reset connector has two pins. One will be white or black. These are - grounds. So connect it to the bottom row onto the most right two pins. Moving to your left. Skip one pin. Take the Power Switch a two pin connector. Remember Black & White is ground & ground goes to your right for both rows of Mb pins.
    http://dlsvr03.asus.com/pub/ASUS/mb/sock478/p4p800/e1324_p4p800.pdf
    Go to IDE_LED next. Its the last two pins towards your most left of the bottom row of pins. Move to the upper row & the power LED. Same as the bottom row keping the grounds to your right. Lastly is the speaker. Its connector holds four pins but you only use two. One in each end.
    Good luck & please vote....
    Dec 22, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
    JBL Toyota Tundra Sequoia 6 Disc Cd Cassette 2003 04 05 A56829 - Cd Not Working Logo
    114 people viewed this question
    Top JBL Car Audio & Video Experts
    hoyzee1
    Rob Beech
    Steve Sweetleaf
    Steve Sweetleaf
    Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
