Question about Car Audio & Video
Sea worthy mbb126
My sea worthy mbb126 radio in my boat is 2 years old. Suddenly it won't turn off. All that happens when I hit the power switch is it goes to "mute"; same thing when I hit the "mute" button. Any suggestions?
  • 3 Answers
SOURCE: Clarion M5675 won't turn on
Take the stereo all the way out and hook the black wire to the negative terminal and the yellow and the red wire to the positive terminal on a charged car battey. If it still does not turn on you may have fuse in the back of the deck. If not it's probably fried.
Posted on Apr 19, 2009
SOURCE: after dead battery radio has no power
I have same problem and I have no idea how to fix it :(
Posted on Dec 28, 2009
SOURCE: I have this radio on a 2001 sea ray boat with the
I know this isn't going to help you but I have a similar issue. The remote will function IF I first turn on the radio from the radio unit itself. Yours should turn on when the boat turns on, as mine did once. Now, my remote will not turn on the radio but will control it once I take the step mentioned above. I suspect I have a faulty remote. Coincidentally my battery now loses it's charge after a couple weeks of no activity. Perhaps a short in the remote unit causes a slow drain.
Posted on Jan 13, 2011
kenw392
  • 2226 Answers
SOURCE: I've installed my JVC KD-S17
Do you have power going to the red wire?
Posted on Jun 06, 2011
kenw392
  • 2226 Answers
SOURCE: hi suddenly my car radio
There should be a button labeled ATT that is your mute button. Att is short for attenuation.
Posted on Sep 26, 2011
My Solara Dsc radio, which has worked well for several years, suddenly began blowingthe 2 amp fuse on the red power line whenever the transmit button was pushed on the mic. Why?
No worries here.
According to Uniden, the 6 amp fast blow fuse is the correct one.
Not entirely sure why there'd be a 2 amp with your old radio, but I suspect the radio is good.
-Steve
Uniden VHF radio fuse Google Search
Dec 04, 2013 | Uniden Solara DSC VHF Marine Radio
I have a Panasonic HDTV 1080p and it won't turn
You have a 5 year old projection TV with power supply trouble
Jul 13, 2013 | Televison & Video
Installing amp on sea ray boat
remote wire is in the wrong location most likely
Jun 17, 2013 | Car Audio & Video
Intermittent starter won't engage on mercrusier7.4 1988 boat engine
might be a burned spot on the starter contacts where the brushes power the motor.
tap the starter to see if problem goes away.
sometimes you can clean the contacts but that is a temporary fix.
Mar 11, 2013 | Cars & Trucks
Where can i find the computer on my 2001 chevrolet cavalier
The computer can be in the engine compartment or behind the dash inside the passenger compartment.
But I doubt the problem is the computer. I would check for power at the ignition switch first. If you have power in and out of all circuits with the switch on, next would be the relays.
Sep 03, 2012 | 2001 Chevrolet Cavalier
How do I wire this radio into my boat? The wires coming out of the harness are one red accessory/switch, one black ground, one yellow constant power, and a blue power antenna.
Red goes to the battery.
Since this is a boat, the yellow will go to the battery too, but I recommend you put a toggle switch on this wire, so you can turn it off and it won't drain you battery. The black wire goes to the ground on your battery. The blue wire can be used as a remote turn on for an amplifier.
Thats' It.
Aug 31, 2011 | Car Audio & Video
No power seaworthy marine amp 400
Do you have anything plugged into the "REM +" slot on the power side of the amp? You need either a signal from a Stereo head unit or another power source to get the amp to actually turn on. If you are using a switched setup for the amp, you can make a little jumper from the Batt+ to the REM+. It doesn;t draw anything significant, it just needs power to signal the amp to turn on. If you aren;t using a headunit, make sure that you wire in a switch inline between ther power source and the REM+ port on the amp, otherwise, the amp will be on all the time.
Mar 30, 2009 | Sea Worthy SEA / AMP 400 Car Audio...
Sea worthy marine cd player sea 2300 + esp
Need help finding parts for a marine radio I bought at a rummage sale, It is a Sea Worthy,Sea9504 AM/FM cd player. Just have the radio,need wiring harness, and a antenna .Don't know what else i need? Don't want to buy another one. Have speakers to. Besides E-Bay taking a chance that the parts might work. Went to sites on the internet.Do you know where i can get these parts cheap,If you could help me.looking to purchurse by check not by credit card.
Oct 06, 2008 | Sea Worthy 9001G Marine Casseiver...
My car radio, Pioneer DEH-P4750MP, 2 years old is connected to the 12v battery system on our boat, and has just suddenly started flashing when turned on. We cant turn it off or input anything. Have to take...
well, it might have something to do with the fact taht it was designed to be installed in a car. theres no waterproofing or weatherproofing. you probably got water in the unit somehow and it shorted. i did the same thing with my pioneer FH-P404 and it cost me more to repair than to replace.
Aug 23, 2008 | Pioneer Car Audio & Video
Car Audio & Video Logo
56 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
