Question about Garden
BOLENS PUSH MOWER MODEL#11A-074E065
WILL NOT STAY RUNING FOR MORE THEN 30 SECONDS
jj505
  • 195 Answers
SOURCE: Wont stay started
pastorcheri,
I found this site if you can not find plug behind engine/blk wire with black cover boot/ pull off.
http://www.webcrawler.com/webcrawler301/ws/results/Web/Cub%20Cadet%20Online%20Part%20Lists/1/302349/RightNav/Relevance/iq=true/zoom=off/_iceUrlFlag=7?_IceUrl=true
Please rate. Thanks. jj505
Posted on Mar 30, 2009
SOURCE: How do I replace the starter rope on a YArd
Thanks for your help, but my friend fixed it today.
Posted on Jun 30, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Bolens 5.5-Torque 21
Does it have compression? If not.. remove the spark plug and squirt some WD 40 in large quantities into the spark plug hole. You may have a valve stuck open. Let it sit for a while with the plug removed for the WD 40 to soak. Then turn it through with the recoil. After that Place your thumb over the spark plug hole and check for compression.
NO compression... soak with WD 40 again let it sit then turn the engine thru for sometime. At least until your arm gets tired. Check for compression again.
Once you establish compression....
Fill gas tank and make sure the fuel selector is ON. BRIEFLY Remove the fuel supply hose from the carb connection and check for fuel flow. If you have flow then reconnect the hose.
Remove the Oil dip stick and make sure the OIL level is FULL. Service if necessary... the LOW OIL level sensor will kill the ignition if the oil is low.
Still no start?
Spark YES
Remove the air cleaner and add some gas into the throat of the carb. Attempt a start. If it starts then dies the carb needs serviced. If you have a bowl type carb:
This is how to clean the fuel passages in the carb.
Here is what you need to do:
1. Fuel selector off
2. Remove float bowl mounting screws and nut
3. Remove the BRASS Jet / Orifice in the very bottom of the venturi tube inside the pickup tube. (Flat blade screwdriver) Hold the Orifice up to the light. You should see a pinhole. If it is not clear clean the orifice but do not force anything through the hole.
4. Underneath the Orifice there is yet another BRASS tube that you need to remove. (Flat blade screwdriver) Make sure all of the holes in the tube are clear. The tube will be over 2 inches long. Clean it and reinstall it.
5. Reinstall the Orifice.
6. Using a catch fuel container turn on the fuel selector. Fuel should flow at a good rate. GENTLY lift the float assy level and make sure fuel flow shuts off. When you drop the float again fuel should flow.
If you do not have fuel flow at this point the needle and seat will need to be inspected. Fuel selector OFF.
(The following procedure is to be done only if there is no fuel flow with fuel selector on.)
a. Remove the silver float pivot pin retaining screw
b. Drop the Float down (The needle will come off with the float. NOTE the position)
c. Inspect the tapered rubber of the needle If should be pointed. If it is not pointed then the rubber tip is stuck inside the seat.
d. Clean the seat hole ONLY if obstructed. (Easily damaged)
e. FUEL Selector on then off fuel should rapidly flow through the needle seat.
f. Renistall Float and needle making sure to get the pivot / hinge pin installed correctly and reinstall the silver retaining screw.
g. Fuel selector ON. Raise and lower float checking for free movement and fuel flow.
7. If there still is no fuel flow at this point remove the fuel hose from the carb and check fuel flow. If no flow check that gas tank exit hole, fuel filter (if installed) and the selector valve assy for obstructions. Reassemble connections.
FUEL FLOW IS GOOD
8. BEFORE you install the float bowl inspect the bowl nut. There are 2 holes in the side of the nut where it screws in to the bottom of the carb that must be clear.
9. Install Float bowl mounting screws and nut. Check for leaks.
10. Test engine.
That should do it. (carb cleaning 101)
Thanks for using FixYa.
Kelly
Posted on Apr 14, 2010
SOURCE: I have a yard machine
Your carbs main jet is blocked. Using the primer supplements the fuel input and keeps the engine from becoming fuel starved.
You need to remove the main jet and run a strand of fine wire through the jet to clear it.
Posted on Aug 18, 2010
kel1guy2002
  • 3740 Answers
SOURCE: need repair manual for briggs
After a very extensive cross reference session your engine is model number
10H902-0285-E1 (not provided by you so it took a while)
Your engine is covered in this repair manual:
http://www.mymowerparts.com/pdf/Briggs_&_Stratton_Service_and_Repair_Manuals_Spec_Charts/270962%20Single%20Cylinder%20L-Head%20BRIGGS%20&%20STRATTON.pdf
If there is a problem that your having I can help you if you would just elaborate. I could save you lots of time. The 2 most common failures of this engine is on the carburetor. The parts that fail are the diaphragm (Item 394) and the primer bulb (Item 976) of this link:
http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=10H902-0285-E1&dn=57160004
Carb data is in section 3 of the first link.
Thanks for choosing FixYa,
Kelly.
Posted on May 10, 2011
I have bolens model 11a-b06r765 mower and the carburerator primer bulb in split, wat is the replacement part number and where can I get it ?
you will need the model number off or the engine and possible the number off of the carburetor. if you can take it to your local mower parts repair store they would probably do it for you in 15 minutes and would'nt cost that much it is an easy fix.
Sep 19, 2017 | Garden
My yard machines by mtd mower model number 11a-b13l029 won't start?
Fuel must be less that 30 days old! Air filter OK? oil level OK? Is the shut off cable streteched, If it is then is makes contact and will not allow the engine to start.
May 15, 2014 | Mtd 22" Yard Machine Push Mower
Bolens 11a 074e065
Empting the gas tank and filling with fresh gas may take care of the problem.
Sep 28, 2013 | Mg International MasterCut 20" 123cc Push...
Bolens push mower
Bobbi it's most definately the spark plug. Change it for a new one
Sep 09, 2013 | Garden
I can't get my mower to crank. To me, the spark plug wire looks a little corroded, but since my Owner's Manual has VERY little info and I've never worked on a mower before, I don't know,...
Have you been using old gas or did you let it set the winter with old gas in it. Today's ethanol additive in our gas causes the fuel to go bad after about a month. Bad gas may not let it start or make it hard to start. Letting it set over the winter can cause corrosion in the carburetor or deterioration of carburetor components.
To check if the spark plug is working, remove the sparkplug and ground it to the engine while turning over the engine, if you see a good blue spark your problem is elsewhere, like the carburetor (single most common cause of engine start problems).
What is the make of your mower? Is it a push or rider? What is the make and horsepower of the engine? What is the model number of the engine?
I hope I am able to help.
Jul 22, 2011 | Briggs & Stratton Garden
I have a yard machine mower model number 11A-549R729 that will not stay running. Have replace plug,drain fuel tank and clean carb. If you push the primer bulb it will continue to run. But once you stop...
Aug 17, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
How to tight my drivimg belt in my push mower honda
The model shown 11A-034F200 is not a self propel mower. Now if you have a self propel mower, most of the time, the only way is either replace the belt or there may be a spring. I will not be able to tell you further without the proper model number.
Good Day.
Oct 09, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Garden Logo
280 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
