Question about Coffee Makers & Espresso Machines
Nespresso CitiZ keep blinking on the "tall" button but no light on "short" button and no water pumps out
I just got this brand new Nespresso CitiZ machine, type C120 RE. The problem is the "tall" button is always keep blinking but the "short" button light does not turn on at all. I tried to push the both buttons at the same time for few seconds, but it did not work. The water can not be pumped out. I desperate how to solve this problem. There is no service center in my country.. Please help me.... thanks.
  • 39 Answers
SOURCE: The espresso side of the
The clue here is that the problem involves the hot wate and the single or double espressos. These three functions require accurate water measurements and they are programmable. It appears that the flow meter is not sending the correct information to the control unit. This could happen if you have blockages or if the flow meter is not working anymore. Most likely you need a new flow meter which only costs about $20 and should not be too difficult to replace. It is located between the water tank and the pump.
Posted on Dec 31, 2009
  • 5 Answers
SOURCE: We have a Nespresso Citiz C110 which today decided
Sounds like it needs to be descaled. If this has not been done for a very long time, the scale will have affected the thermoblock and I may not return to full function. I only use Nespresso descale kit (not vinegar).
Posted on Sep 12, 2010
  • 21 Answers
SOURCE: Machine stopped working and both buttons are
May be busted, but before you take it to the shop try these few things. 1. Unplug machine for 30 seconds 2. Then plug back in, (lights should still be blinking) Take silver handle that you lift when you put in coffee pods and gently push back handle as far as you can for 3 seconds. This should reset your machine,back to factory settings. To then reset coffee cup settings to your personal taste by: 3. You can adjust the fill of coffee by holding the large coffee cup down for as long as you want to fill it. Try holding the button down for 20secs., next cup of coffee should automatically fill for 20 seconds. Do the same for small coffee side. Hope this works,it has for me; just not sure because of the cold water pumping out issue. good luck
Posted on Nov 12, 2010
SOURCE: nespresso clitz's light is keep
It sounds like you've put it into descaling mode. Hold down the "large" button for a second or two and water should start coming through. Press the large button again to stop it. Lift the capsule eject handle and put it back down. Then hold down both buttons for about 3 seconds to exit descaling mode.
Posted on Jan 09, 2011
SOURCE: My Nespresso citiz lungo button will only give
Ok, what you have done is programmed your machine. If you hold down the button for 3 secs you get 3 secs of coffee, so turn on your machine wait for it to warm up then without using a capsule press and hold the button until you get 110mls for a lungo and this will be stored in the memory. If this doesn't work there is a on/off switch on the right handside turn it on with your finger down on the lungo button for 5 secs and then release the button and this will take it back to factory settings.
Posted on Jan 25, 2011
HOW TO ADJUST WATER QUANTITY AS THE LONGER BUTTON WILL NOT ADJUST, SHORT CUP IS OK
Try resetting to factory settings by holding both buttons down while turning the machine on - hold till lights stop flashing. Then programme both espresso and lungo buttons again in the usual way.
Hope this helps!
Mar 13, 2015 | Nespresso CitiZ & Milk Espresso Maker
CitiZ swap outside casing
I've stripped the casing from this model and it isn't difficult, though you do have to be careful. You should check out the Service Manual for the machine to first to decide if you're up to the job. The service manual is readily available online, just Google, 'Nespresso Citiz Service Manual' and you should get it in PDF format. The manual explains the process for dismantling and re-assempling. It also conatins wiring diagrams for all versions. It looks like the casing is the same, regardless of country. When I stripped mine, I didn't have the specialist Nespresso tools for the job, but carefully inprovised using small pliers instead of the special oval screw driver. BEWARE...any remaining warranty will be invalid if you carry out any work on the units!
Jul 23, 2013 | Nespresso Citiz C110
Nespresso not making any noise, water not coming out
return it to place of purchase as defective w/ receipt
Oct 06, 2017 | Krups Nespresso Citiz And Milk
Nespresso citiz won['t exit descaling mode
I had the same issue, and took it to the repair shop, where the guy did the same thing, just pressed both cup buttons for 3 seconds. It worked. He said the Lungo button had to be pressed a little harder, as it had some connection problem, and thats why it didnt work for me. If you have the same problem, the machine will start buzzing for about half a sec if you press the lungo button while in descaling mode.
Nov 29, 2012 | Nespresso Citiz C110
No water, flickering lights
might have a lose wire inside the unit, do the wiggle test, take the unit apart and wiggle the wires they should all be attached firmly if you find one that is lose that's the one and he needs to be tightened up or replaced with a new terminal.. jay the pool pump motor repair guy in longwood Florida
Feb 03, 2012 | Nespresso Citiz C110
Nespresso clitz's light is keep blinking. I pressed both button but not working, I turned it on and off and make sure wate container is placed correctly.
Dec 10, 2010 | Nespresso Citiz D110
We have a Nespresso Citiz C110 which today decided to start having problems. It starts its cycle perfectly but as it is filling the cup the water goes cold and after a few seconds switches the pump off...
Jun 21, 2010 | Nespresso Citiz C110
Blinking orange light on model D290 and it is not full of capsules
I solved this problem by realizing that I had forgotten to insert back a certain piece of plastic, that I had taken out to clean. this caused the blinking light
Jan 04, 2010 | Nespresso Coffee Makers & Espresso...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
