Sony 55 inch wega lcd problems
Lamp turns on, fans are working no picture on tv though. And the green power light blocks multiple times before going to solid green
  • 84 Answers
SOURCE: Sony Wega problems help please!
the first place to start is change the lamp
Posted on Apr 06, 2008
  • 41 Answers
SOURCE: Sony Grand Wega 55 inch
6 blinks is an indication of a missing voltage. It's not the lamp or balast. It may be an indication of a thermal or heat trouble. These sets have thermal protection because of the heat created by the lamp. The thermal fuse may have opened. If this has happened you should have professional check it out. This set has 3 or 4 fans. These should be checked out or replaced. I suggest a Sony authorized repair. This is not a repair I would recomend for you to attempt. This set keeps a record of it's falures and the pro can check for any other trouble also.
Posted on Apr 24, 2009
SOURCE: Problem with Sony Wega 50 in kdf-50we655 light blinks 55 times
I fixed my problem by removing the lamp and vacuuming the hell out of the hole where the lamp lives and also getting all of the dust out of the rear ventilation grids with my vacuum. I put the old lamp back in and what do you know the TV has worked perfectly ever since. My lamp was over a year old and did not show any signs of hazing on the lens that you might see on a lamp that has a ton of hours on it. I just thought I would try to put it back in before I spent a couple of hundred bucks on a new lamp.
TA DA problem fixed.
Posted on May 05, 2009
SOURCE: SONY WEGA 55 INCh
maybe you should change the light bulb
Posted on Jun 17, 2009
  • 556 Answers
SOURCE: Sony Grand Wega 60 inch LCD Projection TV goes dark.
most likely, buy you a lamp and install it yourself, the owners manual tells you how to do this.
Posted on Sep 11, 2009
55 " sony wega projection tv
Overheating? Check fans working near lamp
Dec 08, 2013 | Televison & Video
My sony grand wega 55 constantly will turn off picture and sound, green lamp light stays green and then after about 30 seconds the picture and sound return, it has the original bulb in the tv and is around...
The LED light "LAMP" indication stay on or flashes in this problems?Yes,the projection lamp is the causes and problems.Change the projection lamp,should solved the problems.
Jan 30, 2011 | Sony KDF-E55A20 55 in. LCD Television
I have on Sony KDF55E2000. 55 inch projection. Power wont stay on
It is clear symptom that lamp is near to end of its wroking life and tv needs lamp replacement.
Please replace lamp in tv to get it back in business. Lamp replacement procedure would be written in user manual and its easy.
Please buy Sony original lamp for good picture.
Let me know if you have additional question.
Thanks.
Apr 17, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
My Sony Wega 55" LCD TV will not turn on, the standby light just flashes
if the light flashes 6 times over and over it is the power board. butcheck the lamp
Dec 08, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture will come on and then go off after a couple minutes
This usually means the Lamp is failing. Replacing the Lamp usually fixes it. I would only use a Sony Replacement.
You can order one from Sony at 1800-222-SONY or you may be able to pick one up from a local Sony Retailer.
Skyassoc
Nov 25, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Reset lamp hours on sony grand wega
hello
  1. Press "Display" on the remote, followed by the 5 button, then the sound up key, and "Power On." Do this while the TV is in Standby mode.
  2. Step 2 Then press "Jump" 3 times to enter the DE Service menu. The TV screen will display the total lamp time hours.
  3. Step 3 Reset the lamp time by pressing channel 3, then mute, then enter. This will put your lamp counter back to 0.good luck
shaun
Nov 05, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Symptom shows that TV needs Lamp replacement.
Sony TV Lamp is available in Part Store and lamp replacement procedure is written in user manual of TV.
Mar 27, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Grand Wega 55" LCD ml # KDF-55WF655 goes protective shutdown
This is the lamp going bad. For some reason, it doesn't spit out that lamp error, it just keeps refiring the lamp and it just cycles forever. When the lamp totally fails, you will get the lamp led lit. Replace the lamp to resolve.
Dec 07, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
