Question about Konica Minolta Bizhub C280 Color Copier
Life limit What does Life Limit mean?
3 Suggested Answers
SOURCE: yellow iu over life limit
The imaging units have a chip inside.
This one counts the number of copys/prints made with the unit.
Once the chip has reached his number, he gives a signal to the machine that it needs to be replaced.
There are ways to reset this chip with a resetter (kosts alot and is only good when you use a whole lot of units.....)
I think its better to order a unit and to replace it yourself, so you dont have to pay the technician costs.
greetz,
Marc
Posted on Jun 26, 2009
  • 32 Answers
SOURCE: Alert comes up that says yellow IU over life limit
what machine do you have?
si
Posted on Jul 03, 2009
Short battery life
There are several options to save battery life. You could set the brightness lower, which will help conserve battery life. Others would be: turn off wifi when not in use, turn off Bluetooth when not using it, and limit the number of active apps running in the background.
Then again, your battery may just need to be replaced.
Feb 09, 2015 | Cell Phones
WHAT CAN I DO TO SAVE BATTERY LIFE ON MY SAMSUNG GALAXY ATTAIN SCH-R920
There are many free apps on the google play that can assist in saving battery life. Each one is slightly different and it really depends on your preference. For example, JuiceDefender can help you maintain proper profiles for your phone so it uses the least amount of power possible depending on the situation. Or ES task manager which helps your delete running processes and apps.
Other than apps the best way to save battery is really to change certain settings.
1. Do not use live wallpaper. Although they look nice they **** up a lot of battery life.
2. Turn off Wi-fi, data, gps, bluetooth when you are not using them. They also drain battery like crazy. you can get a simple widget to easily control them on your front screen.
3. Turn down the brightness of the screen and amount of time it stays on because typically the screen is one of the largest battery hogs.
4. Disable apps that automatically sync like email or certain games.
5. Limit the amount of storage space used. so uninstall things you don't need.
6. If your phone is rooted, there are even more options and apps to limit the things running on your phone to increase battery life.
Oct 26, 2012 | Samsung Galaxy Attain 4G for MetroPCS with...
Can i disconect the hi limit switch and still use fryer
Hi there.
Hi limit switch/ device on fryers acts as safety device. It cuts gas supply on burners when it is triggered by high oil temperature in case the temperature regulating device failed to avoid further damage on equipment, property or life.
It is not advisable to operate the equipment with bypassed hi limit device.
I suggest to have it replaced first before putting the fryer back in operation.
For parts inquiry/ ordering, you can visit http://www.pitco.com
Regards.
May 29, 2011 | Pitco Frialator 35CS Deep Fryer
Won't play DVD , it plays VCD, CD , AM , FM
All DVD players use a twin laser pickup. One wavelength is for CD/VCD and the other is for DVD.The one that is used more often tends to fail first. Typical life span is about 750 to 1000 hours. If you have crossed this limit the Bose must be due for a replacement. Even if you have not crossed this limit the laser could have failed . They are unpredictable at times.
May 01, 2011 | Bose 3·2·1 Entertainment System...
ERROR CODE 000008-000001 WHAT IS THIS ERROR?
E008 0001 fixing roller life detection error
Description: The reading of the fixing roller life counter has reached its upper limit
Remedy: Turn off the main power, and replace the fixing roller or the fixing assembly;
then, set '0' to the following in service mode: COPIER>COUNTER>MISC>FX-UPRL.
Jan 21, 2011 | Canon imageRunner C3100N Copier
Service life expired
How long have you been using your printer? and how many pages have you printed and the quality of it?
The reason am asking is that it could be that your printer has reached a certain limit of its parts based on the no. of pages it has printer. Please take note that each part of your printer, especially the mechanical parts has certain limits based on the no. of pages it has printed. Based on my experience with epson printers is that, first to reach its limit is the porous pad, if it reach it limits it will disable your printer from printing further to protect it from further damage. Everytime you print some ink goes to waste and goes to the porous pad which means it could get full. Please bring you printer to an authorized epson service center to have the pad remove or whatever parts the limits reach first. After parts replacement the technician will use a software tool to reset the counter and voila :) Your printer should be working fine until it reach another limit. Note: All printer brands uses counter to protect their unit.
Jul 29, 2010 | Epson Office Equipment & Supplies
My srs light is on
Hi the srs light being on means your air bag system needs servicing, the reason being is that air cannistors that fire the air bags only have a certain life limit, once they reach this limit they need replacing as the air bag system wont be working properly until you get this serviced.
its not a job you can do yourself as the general public cant get the parts to do the work nor the machine to reset the system.
May 04, 2010 | 1997 Honda Civic
83 itu maintanece
You replace the ITU it has reached its end of life cycle.
Jan 22, 2009 | Lexmark C762 Laser Printer
Canon Error Wrench pops up on screen.
drum unit life out or toner unit life out, u try exchange the drum or toner unit to reset the chip
Jan 30, 2007 | Canon imageRUNNER C3200 Color Printer
Konica Minolta Bizhub C280 Color Copier Logo
116 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
