Question about Electrical Supplies
Omron 21911c test a relay
2 Suggested Answers
SOURCE: FUSES/RELAYS
2002 Dodge Grand caravan Front lights when the lights are on onlly the rigth one lights when i put the hi beams on the right goes out and the left turns on high. tried switching relay but not working
Posted on Nov 10, 2010
Replacement part for Omron G3J-S245BL-MS Soft start relay for Mitsubishi MSH A30WV Airconditioner
Go to parts dept at dealer, if they don't carry it find an electronics store like Digi-key or Allied on-line, they probably carry Omron relays or can order it.
Nov 22, 2014 | Mitsubishi Cars & Trucks
Relay diagram dash
relays are often used for many different applications, with same part number, the location of the relay determines its function
Sep 01, 2013 | 1996 GMC Sonoma
How to connect an omron h3y timer into a circuit
I see your comment to ignore:
To protect timer, read following:
1) Max load on this timer is 5 amp at 240volts
http://waterheatertimer.org/pdf/Omron-H3YN0302.pdf
2) If load exceeds 5 amps, then use timer to control contactor.
Here is crude drawing showing basic wiring for pin timer controlling heavy amp load.
http://waterheatertimer.org/images/10-pin-wiring2-1000.jpg
3) If amp rating on incoming wires exceeds 5 amp, for example is circuit breaker feeding circuit is 20-30 amps etc, then protect wires to timer using busman in-line fuseholder with fast-acting 5 amp cartridge fuse.
Dec 03, 2012 | Omron Healthcare Omron H3y-4 5 Second...
Wiring diagram for Omron off delay timer
Which Omron timer?
The model and wiring diagram appear on side of timer.
Add a comment with more details and I can track down the information.
http://waterheatertimer.org/How-to-wire-pin-timers.html
http://waterheatertimer.org/Woods-timers-and-manuals.html#Omron
Sep 07, 2012 | Amperite Dayton Solid State Timer On Delay...
Insturctione how to use omronHEM432CN2
Taking your blood pressure is easy with the lightweight and convenient Omron HEM432C blood pressure monitor. Simply wrap the cuff around your arm and squeeze the bulb to begin inflation. In seconds, your blood pressure and pulse readings are displayed on the large digital panel. The Omron HEM432C has been tested, evaluated and proven to meet the rigorous safety and accuracy standards set by independent organizations.
Dec 05, 2011 | Omron Healthcare Omron Hem432cn2...
FUSES/RELAYS
Jun 22, 2009 | 2003 Dodge Neon
Omron Portable Ecg Ekg accuracy problem
Hello Josh. You will need a EKG simulator. I suggest you contact your local community (junior) college electronics class or a local Bio Medical services in your local hospital. When locating one kindly walk in and ask very nicely with the portable in hand if you my perform a operational test for you on benefit.
Aug 27, 2008 | Omron Portable Ecg Ekg Handheld Hcg 801...
Error code F dL, then F11
F/DL is indeed a door lock error. I had this on my machine, did a lot of research and getting some idea of how it works. The code is generated when the CCU can't lock the door. Possible causes are door latch mechanism, connecting wiring, or the CCU. I could hear clicking from the CCU on my machine which indicated to me the CCU was trying to lock the door. It tries 6 times before setting the F/DL code. I tested the latch and wiring from the CCU - OK. The clicking I heard had to be relay(s) so I figured the problem was relay contact failure. I removed the CCU board, determined which relays were suspect (there are two for lock & unlock). I changed them both and saved myself spending $300 CA on a new CCU. The relays cost just over $2 each. I found replacement relays @ Electro Sonic (www.e-sonic.com; minimum $25 order plus shipping $7.50). Relay made by OMRON part # G5LE-14-DC12 replacment for original G5LE-1-VD 12VDC. I'm not impressed to have to change a $300 CCU because of a $2 relay failure. For me this was worth the try as I have some experience working with circuit boards. The relays would be a quick repair for anyone with similar experience. Hope this helps someone.
May 06, 2007 | Whirlpool GHW9400 Front Load Washer
Electrical Supplies Logo
110 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
