Question about Dell Computers & Internet
NVIDIA image distoration
My computer keeps distorting images for every website I go on, this has been going on for maybe a month now every time this happens a little pop-up at the bottom of my screen tells me the my NVIDIA has crashed but successfully recovered and although it may have recovered for the moment, 15 or maybe even 10 minutes later it would distort again and sometimes even shut my computer off. why do I do to stop this?
    Master:
  • 663 Answers
I suggest that you scan and update the drivers in your computer. You can use RadarSync so that you don't have to search the web to find the updates. It would save you time.
David
Posted on Jul 24, 2013
36YearVet
  • 24 Answers
SOURCE: screen image display distortion
Hello.
What you are reporting is a problem in the pincushion circuit in the horizontal section of your CRT monitor. Usually this is from an electrolytic capacitor that is no longer willing to play nice with all the other components.
It is repairable, but get an estimate first. If the repair bill appears to be around $100, you would be better off to put a few more dollars with that and buy an LCD TFT monitor.
If you are quoted $25 or $30, it is probably worth having repaired. Just keep in mind that these older CRT monitors have age on their components, and once repaired, it will still be an old monitor.
Only you can decide which choice is right for you. At least now you have a few facts to help make the decision.
I hope this helps.
Posted on Nov 06, 2007
bammbammfran
  • 159 Answers
SOURCE: distorted images due to wide screen
Hi
Your entire desktop is probably stretched left to right.
You need to adjust the resolution of your computers video card in the display properties to one that the widescreen will accept correctly.
There is a chance that your video card may not have the correct resolutions available. If this is the case then you may be stuck with this view until you change coputers or video cards.
to get to display properties based on win2k or xp
Right click in the center of your desktop, choose properties, go to settings and there you should see the resolutions available. Try different ones till you find a good one, you may have to settle for one that is close to your monitors setup if the exact one isn't available.
If using a laptop with a standard screen with the wide monitor, you may need to disable the laptop screen and use just the monitor to get the correct resolution on the monitor.
Fran
Posted on Oct 13, 2008
SOURCE: Display jumping vertically
I had same problem.
Narrowed it down to C637 on logic board.
Replace C637 or logic board.
Posted on Oct 10, 2009
Testimonial: "I don't know what a c637 is or how to replace it or the logic board and I can't find anyplace on the net that has instructions or even information"
  • 732 Answers
SOURCE: Screen image appears fuzzy, jumpy and broken up into lines.
gardenman13, I would certainly complain to HP about their w22 monitor!! Find out if the units warranty is still valid and can be swapped-out for a REFURBISHED unit. Your w22 shouldn't be hazy, distorted, or flicker for any reason. My best guess is that it (w22) has problems inside with it's "cold-cathode-fluorescent-lamps" and electronic ballast circuit called an INVERTER circuit, which could also cause the main "switch-mode-power-supply" to go a little NUTS upon STARTUP!! FYI you are dealing with a technology similar to the curlie-Q CFL screw-in light bulbs. Their ballast's are called CONVERTERs (ac to ac) and are cheaper. Your lanps are thinner and straight, hung on rear of your LCD panel. I hope this was informative. Please rate this on fixya. 12fixlouie
Posted on Nov 02, 2009
  • 157 Answers
SOURCE: screen stretched out horizontally and distorting
There are adjustments in the size of the items on a screen under the screen properties, settings. If you right click on the desktop screen and then properties you can get there. There is at least one size which causes a distortion of images being displayed. This may be your problem.
Posted on Feb 28, 2010
Hi,i actualy bought an aoc 2243fw2k led monitor,i hav a nvidia geforce 220gt graphic card,even though i installed the latest drivers for both graphic card n the monitor,i stil cant experience high...
1920x1080 resolution is the starting point for HD video. If you have set your desktop resolution to that or anything avove then you should be running at HD resolutions. Maybe the image/video you are watching is not at a HD resolution, therefore it will appear distorted and streched (poor quality). To fully experience HD playback use video files and imaged that are at the 1920x1080 resolution and above.
Dec 16, 2011 | Computers & Internet
The picture is showing a double image and is distored.
The problem you are refering to is more than likely a convergence problem. The convergence circuit in your tv is controlled by an IC (integrated circuit) stk392-110 and it makes the 3 colors (red, blue, green) line up/converge together to create a clear picture. You'll know when this part needs to be replaced because the picture you see is 3d looking and possibly bowed on the top or bottom or on the sides in any or all 3 colors.
Jan 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Tv pic has redbluegreen images pic distorted
This is a convergence problem that can be as simple as poor solder connections at the convergence ICs or defective ICs. If you feel that you want to attempt the repair yourself, please update this with that indication and additional details and instructions will follow. The parts for this repair will run about $40-$60.
Dan
Dec 10, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Image distorted
This is causes by a defective ccd sensor the optical unit needs replacement. If you're out of warranty, you will have to send it to a third party camera repair service. Expect the price to 40-50% of a used equivalent.
Apr 24, 2009 | Olympus FE-170 Digital Camera
Very bad graphics Sharp angles whle palying a game whats wrong?
you will need a better gxf card, preferably something better than AGP cards. But since thats what your pc has try getting a 7000 series card. ex 7300gs
Apr 20, 2009 | XFX GeForce 6200 Graphic Card
Distorted sreen when full size images and games.
if video for everything else looks ok, it might just be a driver issue... hopefully, you have Nvidia graphics as they are the easiest to find drivers for, you can go to their web site and basically have them scan your machine for the correct one.
for non Nvidia, i would just make sure you're current with your windows updates, usually they will patch your system with relevant drivers.
Jan 15, 2009 | HP Computers & Internet
The picture comes out distorted and is also distored through the screen on the camera.
This is probably a CCD problem that is a free repair from Canon - they might charge $15 USD for shipping. Go here for more details: http://www.imaging-resource.com/badccds.html
Contact Canon to find a service center near you.
Nov 25, 2008 | Canon Cameras
Distorted Image
if it records the distortion then i suspect the guides are out of adjustment or your capstand roller is pushing the tape to high on the guides. need to have a profession serviced.
Feb 07, 2008 | Samsung SC-D23 Mini DV Digital Camcorder
Computers & Internet Logo
80 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
