Wireless network can't connect
Cannot connect wireless on laptop
  • 230 Answers
SOURCE: wireless connection in dell laptop
have you installed the driver for the wireless ?
Posted on May 13, 2008
daytona600
  • 10 Answers
SOURCE: setting up wireless connection
First check to see if your windows can see the wireless router. Does it see the router? Click view wirelss networks to see a list of available networks. If you cant see any make sure your wireless network is switched on.
Also which manage s your wireless network, the windows or the wireless cards own software?
Posted on Aug 14, 2008
vincent721
  • 240 Answers
SOURCE: wireless network is not connect to local network
what wireless router are you using?
second pls check the wireless card's internet protocol properties if set to : obtain IP address automatically..
try also to release and renew your IP
click Start>>>RUN
type cmd and press enter
type ipconfig /release then press enter
type ipconfig /renew then press enter
Posted on Mar 16, 2009
  • 36 Answers
SOURCE: cannot connect via wireless network.
stupid question : is Wifi turned on ?
Go to your administration environment of your router ( typically : http://192.168.1.1 ) and check the config of the wireless settings
Posted on Aug 14, 2009
chocoberry
  • 94 Answers
SOURCE: Cannot connect new laptop to wireless network. Belkin Wireless N
The wireless settings on the laptop and the router should match. To check the settings on the router you need to access the setup page by typing 192.168.2.1 in a web browser's address bar.
By default the password is blank.
Click the Wireless tab. And take note of the SSID or wireless network name.
Go to Security, then Wireless. If the wireless security is enabled, copy the network key or security key.
On the wireless computer, you should detect SSID and if wireless security is enabled, connect to it with the correct security keys.
Hope this helps! Good luck!
Posted on Feb 08, 2010
D-link DIR-625 wireless router is setup and wired to laptop
First of all make sure the Wireless switch in your Laptop is turned on.
Now Disconnect the cable from the Laptop to the Wireless router
Now go to your Wireless Network connection and search for the available network. Select the appropriate network and connect.
Thanks
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
How can I connect my notebook to another pc without installing LAN??
A Local Area Connection, or LAN, is generally a small home or office network used to link all the devices in the area. With the advent of wireless technologies, LAN networks are no longer limited to the amount of cords you own. Laptops can connect to wireless LAN easily with their built in wireless adapters. Connecting two laptops together over wireless LAN is also easy, but requires a few special steps to give the laptops access to each other.
1Connect both laptops to the wireless network you wish to use. Once connected, click the "Start" button and navigate to the "Network" menu.
2.Click the "Network and Sharing Center" link. Press the "View Computers and Devices" button. A list of devices currently on the network is displayed.
3.Check the list for the names of both laptops. If both laptops are displayed in the list of devices connected to the network, the devices are connected wirelessly to a LAN network.
Sep 06, 2011 | IBM ThinkPad R50e Notebook
Have a medion laptop that wont connect wireless
click on start >> go to control panel >> double click on network and internet connections >> right click on wireless network connection >> click on properties and go to wireless tab >> check the box at the top that says use windows utility >> click on ok and than right click on wireless network connection and click view available wireless networks. It will show you your network name. click and connect to your network.
Feb 26, 2010 | Medion md40298 Notebook
Cant get wireless router to work on laptop
First, try to connect your laptop hardwired to the router, if it works fine, its just the wireless configuration. Make sure you are using the correct wireless network key to connect to your wireless network. Go to the Control Panel > Network Connections > Right-click Wireless Network Connection > Properties > Wireless Networks Tab and delete all the names listed under Preferred Networks box. Click Ok. Right-click on Wireless Network Connection again > View Available Wireless Network > Choose your own network and click Connect. If it asks you to type the network key, type in your WEP or Wireless Network Key and press connect. That should do it.
Oct 06, 2009 | Computers & Internet
Can't connect to netwoork
Just configure the wireless settings your laptop. Go to Network Connections > Right-click on Wireless Network > Properties. Go to Wireless Network tab and look for Preferred Networks. Just remove all of them and click OK.
Now, On the Network Connections, right-click on Wireless Network Connection > View Available Wireless Networks. Connect to your own wireless network and enter your wireless network key if it tells you to type it. That should fix your wireless connection. Now if your wireless network is not showing, you need to change the wireless channel of your router by accessing the router's setup page using your wired computer.
Apr 18, 2009 | NetGear WGR614 Wireless Router
Unable to connect my wifi laptop to my existing wireless b/band
Your wife's laptop is setup to connect to another wireless network. It must be set up now for the wireless network that you are trying to connect to. This means that your wife's laptop is trying to connect to the wireless network somewhere else. You need to let the laptop look for available wireless networks. It should be able to see your wireless network. It will then require you to enter the password that you have set in your Zyxel. If you don't know the password, call Zyxel.
Feb 23, 2009 | Zyxel Prestige P-330W Wireless Router...
Cant connect to my router through laptops built in wireless/ps3
restart your wireless router and try again...
check the settings on your wifi router and on your desktop....
Jan 28, 2009 | D-Link DI 514 Wireless Router (DI-514)
Network key
Its like a password thats needed to connect to a wireless connection, this is only needed if you have a wireless connection
Jan 14, 2009 | Dell Inspiron 1150 Notebook
Cant connect 2 laptops through linsky wrt54g is this possible
are you connecting the laptop hard wired or wirelessly?
for wired connection, just plug the ethernet cable from the router to the laptop and it should work fine.
for the wireless connection, check on the wireless network connection. for xp, click on start> control panel> network connections> right click wireless network connection> then click on view available wireless network> then select your network.. for secure wireless connection, type the security key then click connect. :-)
Dec 13, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
